Looking for a replacement motor?
no704
My old Maytag commercial dryer motor died. Looking for a replacement. AO Smith SN: 327P380 SER: 2E98. Matching one is crazy $$. What would be an affordable substitute?? Thanks!
Just to be sure, does anyone know the wiring on this. Have red, blue, and white wires. Showing 120V between the white and the either of the others.
Norcal
A lot of commercial dryers use a proprietary motor design, the shaft is longer for a drive pulley for the drum & a blower at the end, they are stupid expensive, like $800 expensive for a fractional HP motor.
rsanter
visalia ca
Can you look at the used appliance dealers and see if you can find another machine to pull the part from?
How about a rewind?
How about a picture of the motor, we may think of an option?
N
no704
Like $1500 for the exact motor. For a dryer I paid $50 for 20 years ago.
N
no704
Stopped working just after we had a flickering power outage. Tried a new start cap that a friend had on hand. Slightly lower rating on it. How would I wire it direct to the wall to test? The three wire hook up I’m not quite understanding.
N
no704
Might just pick these up. Hate to junk the old Maytag units.
American Locomotive
Rhode Island
You would need to look at the wiring diagram.
was it running when the power outage occurred?
I doubt the motor is dead. probably blown fuse or some controls issue in the dryer.
i would check the motor first before doing anything else
mogandave
Bangkok
I've put three capacitors in my dryer in the last ten years.
Bench test the motor.
The capacitor may be remote from the motor, mine is.
BillK
Beautiful Southern Maryland
For that kind of money I would definitely take it to a motor shop and have them at least look at it. I dont know where you are located but any big city should have at least one place nearby.
dogdog
It says thermally protected. I would check the thermal fuse that is embedded inside the winding, usually. Or you can hunt for the 56 frame motor and see if you can transfer the rotor over.
N
no704
Was not operating during the power outage, Could be coincidence. Would like to just plug it into a pig tail into the 115 wall outlet before further disassembly. Not sure on the 3 wire hook up though. Have a red a blue and a white. I would like to believe the white is neutral as it shows 120v to both the red And blue. Out of town. Will get pics tomorrow.
As previously stated, cap may be external. Grounding done through frame, white may be neutral, one of the others may be start winding and third may be run winding.
Milton Shaw
The motor switch in GE dryers also controls the safety leg of the 240 volt to the heating elements on the dryer. Shaft lengths are also special so only a GE dryer motor would fit, They used the same motor for something like 20+ years so a lot of used ones are in scrap piles sitting around appliance rebuilders/resellers. Motors were 120 volt with a 240 switch in it's multiwire start switch.
BombShelter
State of Hockey
I bought a dryer motor for another project at Axe Man, we have a few stores around here. The stores are amazing if you haven't been in one, lot's of old NOS stuff.
N
no704
Thanks to everyone for all the support. Finally came to the decision to let it go. Paid $75 for the washer and dryer 25 years ago. Think I’ve gotten my money out of them , was also $1 a load where I had roommates so I owe these machines nothing. Just got these for now AB0059E3-4B5E-4982-8B2D-B4054B481609.png
