Looking for a used drill press
wdfwguy
I'm trying to replace my HF 10" drill press, hopefully with a nice older one
How does this look? Owner says it works fine, just needs cleaned up.
BD1
north side
How much you want to invest determines what you are gonna get.
The Delta are nice but most made in Taiwan. I would get a two belt setup. This has a front pulley set, a middle set, and a rear set. This will provide a greater choice of slow speeds for metal.
The older Rockwell and Powermatic are nice but not cheap.
Davefr
OR
Early Taiwan machines were OK. (pretty well built, table lift/tilt/rotate, wide speed range and decent TEFC motors).
The machine you're looking at looks pretty rough. I wouldn't be comfortable going much over $100. These machines are not hard to find.
The Cobbler
You're looking at a Taiwanese import from the 80's
Two things seem to turn up here. Recent chinese presses like Ridgid, Porter Cable, HF, etc. Or, 70s and 80s Taiwan presses like this one.
I have one probably identical. it was given to me with a bad motor, I don't recall what was wrong with it, but I think it was a bad capacitor. it is a decent machine, it needs a new chuck and there is a fair bit of runout, haven't tried to identify what the issue is, .
Davefr
OR
