Looking for a workbench recommendation...
Snip's
I'm in the process of doing a makeover in my two car garage 20' x 22'....
I'd like any suggestions on recommendations for a workbench,,,
I'm thinking a wood top, mount a vise, grinder and table top drill press...
Drawers on the side...
Suggestions?
rayra
Escaped from Los Angeles
A lot of details and use options left unsaid. What do you need said workbench to do? How sturdy does it need to be. What abuse or solvents must the surface resist? Would a movable bench be of interest to you? Or does it need to be strongly attached to the wall studs? Are you a woodworker? Do you need access to more than one side?
Most of my stuff is on wheels, I'm able to rearrange the workspace and expand or contract it as needed or desired. Only my hobby / reloading bench is fixed / anchored to the wall.
nadogail
Coronado, CA
I managed to acquire a previously owned Hallowell workbench in 1976, I had all the attributes you mentioned, except wheels. The top is a composition wood product that stands up well to hammering.
Shiftless
East Bay SFO
You could start with a solid-core door on sawhorses.
That’s a good starting point.
My main bench is a ladder frame of 2x4s lag screwed into wall studs on the back and supported in the front by recycled redwood 4x4s. Topped with 2x6s then a 3/4 inch layer of particle board with an IKEA butcher block counter top on the top. No welding here but it’s plenty solid.
My second bench is on locking castors. 4x4 wooden legs. Recycled plywood door on top. 2x8 framing lumber for a shelf underneath. Moveable benches are quite handy when you occasionally need a work table out in the middle of your shop for a project that needs 360 degree access.
southalabama
Brewton AL
Dillon blue 😍
Killer95Stang
I would build that to be a heavy workbench on casters so it can be moved around. Incorporate a truck hitch receiver, so you can put different tools on a vise plate. That way you can switch out from vise, grinder etc. I only mention th is, because I have a small garage like yours and I have a 9ft by 2ft workbench at the back of the garage that seems to get in the way. I also built a 2ft x 6ft welding table on casters that I can move around, use with my drill press, grinder, second vise.
  • TT-RM4-GV-COMBO-trick-tools-versa-mount-swiveling-vise-and-grinder-plate__87017.jpg
exmaxima1
Midwest
For a garage workbench that will not need access on all sides (unlike a woodworking bench) I would procure a tool chest and build a bench around it. The drawers come in extremely handy.
sz0k30
Suggestions?
Do some searching on this site, probably more likely in the general tools forum. There have been a lot of "Show us your workbench" posts.
NUTTSGT
Northern Central Ohio
20x22 ? Do you actually park in here? One or two small vehicles? What else fits in the garage would dictate how big to make it.
Snip's
Excellent suggestions guys....
Had no clue there was something like EAA Chapter 1000 benches....
Followed the thread about the Stevo bench... This I really like...
Thanks!...
PDang
If youre not going to be using it for alot of metal forming, I used a SS food prepping table with 2 in walls above the table. the one I got has an adjustable shelf underneath and is really sturdy.
Chickenpants
Midland Georgia
The EAA Chapter 1000 benches are great basic or starter benches. Plans are online and free.
It’s EAA chapter 100. I can endorse their bench. My father gave me his mechanical and carpentry skills. Unfortunately he was a horrible carpenter and I’m worse.
That being said I have used the EAA Chapter 100 plans and approach and have used them to build a workbench and reloading bench. Won’t be your ultimate bench but you can build it in a day.
ericlar80
California
I put down 1-1/8” playwood from Home Depot and then topped that with hardboard. It’s been great and was not very expensive. The hardboard can be easily replaced whenever it gets damaged, but it is actually very durable.
Everything lays very flat and smooth, too. Just don’t spill water on the hardboard otherwise it will tend to deform.
gearhead1
NC
Old thread, but documenting for those searching looking for ideas. Attached is my spin on the EAA 1000 bench.
Alchase
Harrah, Oklahoma
I did something similar. I used 3/4 ply topped with hardboard. That was 8 years ago and it is still going strong. I purchased enough hard to replace the top three times, thinking I would have to and should have it ready. Well that hardboard has been taking up space in my shop now for……. 8 years, LOL.
I found the easiest way to decide what type of work bench to make, is first decide the size. Once that is determined, the rest is just how elaborate you want to make it.
I tried to like zones, but found I used one area 80% of the time no matter what I was doing. I do love a portable X-Bench I use as a layup table. Best purchase I ever made.
Edit- I would also love to put a Stainless Steel top on my work bench. Do I need it?
No, but I do want it 🙃
RoninB4
Under My House
Size of workbench is important (it's always about size isn't it?) for a stationary/portable/collapsible design. So is the expected type of work being done. Welding and a wood top don't mix very well. Neither does wood and solvents/oils. Wood top for woodworking or fragile components is ideal. One thing I've tried to do is have different benches for different types of work but it takes up a lot of precious floor space. For general assembly work that's messy I try to use discarded kitchen/bath counter tops. They're fairly flat, clean up spills real easy, non-staining, sturdy, and often free if someone is remodeling. The shops/stores/contractors that do remodeling often haul the old ones away to throw them out, they might be happy if you offer to take some away. Any plywood, MDF, or wood top is going to need sanding/sealing or it will generate splinters/fibers as it absorbs humidity/liquids. A Formica countertop is already smooth, no finishing required. Some may not like the appearance but it depends upon what you use. You could try to incorporate wood, Formica, and a SS panel into the top and have all 3 surfaces for welding, assembly, and woodworking or just have removeable sheet surfaces that can be stored under the bench.
PoorUB
Fargo, ND
Suggestions?
IMO, you need to separate the dirty work from the general work bench. My grinder, welder, bench vise and drill press are in one corner of the shop. My work bench and hand tools are in another. I don't want grinding dust all over my tools and work area.
If I were to buy a workbench today, something like this would be it.
https://www.homedepot.com/p/Husky-7...d-Top-in-Matte-Black-HOLC7218BB1MYS/302255876
Garcky
Twin Cities Metro Area, Minnesota
There are so many ideas available. A lot depends on how you plan to use it and for what kind of projects. That's the first, and most important, factor. You'll get lots of good ideas here. Think about the suggestions and consider your own needs.
RaisedByWolves
SE PA.
Grinder, belt sander, bandsaw and surface grinder in one spot, everything else everyother where.
