Looking for advice buy it or build it slugging tools
Finky198
North East
So I and my shop partner have a large assortment of impact tools and sockets but Im always looking for those cool tools that I think can be of some use
In comes the slugging wrench but specifically one of these
But I just can't understand the price gouging when a typical slugging wrench is under $100 so why are these so much $350+ Any one ever made one. I was think of Buying a wrench and an adapter tacting up then preheating welding and cooling it in sand to hopefully keep it from getting brittle
Any Though or ideas or cheaper alternatives are welcome
F
Finky198
North East
for some reason the 1" drive version is cheaper than the 3/4 idk why but I don't own any 1" impacts : (
rsanter
visalia ca
At that price I think I would give building one a try.
If it was me I would buy a short impact extension and a piece of 1" steel.
Drill the hole to press fit the extension into. I would then drill two holes right on the joint between the extension and the steel and insert solid pins.
Then I would weld the joint on both sides and put it to work
Bob
F
Finky198
North East
I was thinking of somthing like that but not sure about welding as I know the drive end will eventually snap off and then the whole tool is shot maybe just like u ^^ suggested 2 large steel pins this way the heads are replaceable... similar the snappy breaker bar heads with pins
