Looking for advice on some roof damage
b-boy
Buffalo NY
I live in an old balloon framed house from the late 1800s. It's a 3 story home with a full attic. It has a hip roof with a 12/12 pitch.
The attic was partially finished by someone, probably in the 60s, based on the old wiring and wood paneling. I tore it out in order to insulate and redo the walls.
When I opened up the walls I found some repaired structural damage in the front corner of the home. I assume maybe a large tree hit the house or there was damage from a very heavy snow load. The repairs looks like they were done a while ago. The lumber used for repairs is dimensional. The sistered wood was just nailed into the main rafters. There are no through bolts of any kind.
For the most part, the jack rafter repairs look OK. The repairs extend most of the length of the rafter. I'm concerned about the Hip Rafter. It is 4"x8". It has a significant crack in it. It was repaired by sistering 2 pieces of wood on both sides of the break. The wood used appears to be 2x6s. Because of the proximity to the jack rafters, short pieces of wood were used for the repair. At most, they extend 2 ft beyond the repair on each side of the split. Obviously, whoever did the repair did not want to deal with the jack rafters. Again, there are no through bolts.
I assume it needs to be fixed correctly. I'm having a hard time getting anyone to come over and look at the issue.
Any experts out there. How would you approach this?
Zeke
If it doesn't interfere with your finish plans, add angle iron to the bottom leg down. If that doesn't work, add it leg up. You may have to make some clearance with the leg up. I would think a 4 to 6' piece of 1/8 x 2 x 2 with heavy screws from the bottom would provide plenty of piece of mind.
b-boy
Buffalo NY
Thanks. Never thought about adding angle iron.
I think my main concern is that the sisters only extend about 24" across the crack. Is that sufficient?
I'm planning on adding some lag bolts to the repair as well.
RoninB4
Under My House
Angle iron looks like a good solution here, no rip-out-n-replace project. Find a decent metal scrap yard and get a lower priced length as posted above. Yes it will be a bit rusty, so will many "new" metal places. Just clean/sand/wire wheel any rust off, paint, pre-drill holes and you're almost done with the job.
To the OP- Would like to see photos of the house itself if you don't mind. I like seeing older homes from that era.
mike93lx
Richmond, VA
The only time you can really fix that is when the roof decking is off.
Aside from that, you can add more wood or steel if you'll feel better. I'm not surprised you can't find someone to do that work.
