wkeene
Hi everybody,
I just picked up an Ammco 2002 brake lathe and I'm looking for a pdf of the operators manual. If anybody has one or has a lead, I'd much appreciate it.
The lathe is in need of repair also. The control board seems to be mostly dead; it doesn't light up like it should and the lathe will only start to turn and turn about a 1/4 turn and stop. The shaft turns ok by hand and there are no bad noises or smells at all. Also, no popping fuses or anything. I may very well just bypass the computer and install toggle switches. The lathe was cheap enough.
Thanks a lot, Wade
Thanks a lot, Wade
