Looking for good quality air couplers
jeffharbert
Julian, NC
One of my projects is to replace all my crappy air tool couplers with ones of much better quality. All I can find locally at Home Depot, Lowe's and Harbor Freight are ****. The couplings all leak when a hose is hooked up. So, I'm looking to spend some money on some better ones and get rid of the leaks.
Can you guys recommend a specific brand I can buy online? Thanks!
geko29
Milton is most people's top choice, brand wise. Is it possible the problems you're having are more to do with style rather than mfr? The ubiquitous M-type (the only kind HD and Lowe's sells, except for the occasional old-school T-type) fittings are by far the most prone to leakage, regardless of brand. The professional A-type provide the best seal, but you get a pretty good seal from the high-flow V-type (HVLP). And the V's ARE available at Harbor Freight--they're called "high flow couplings". I have a bunch, and none of them leak. IIRC the plugs are 4 for $5, and the couplers are 2 for $6.
evintho
Santa Rosa, CA.
I just replaced all my fittings with Miltons. Picked them up at my local auto paint supply store. Spent $30 and got 6 couplers male and female and a bunch of matching *******. No leaks at all!
I was told that each company makes their ******* and couplers to match. It's not wise to mix and match other companies hardware.
Vinko
Los Angeles
Parker air hose, made in USA, 3/8 ID and 11/16 OD:
1/4" NPT end w/ferrule - stainless steel.
CEJN 310 series couplers, high-flow, regular and safety. Made in Sweden.
CEJN 430 v. 310 ******, both industrial interchange:
