TheCodeMan
- Joined
- Aug 26, 2021
- Messages
- 9
I just had a 24 x 41 metal building installed. About half of the electrical is complete and I'm now looking to run my low voltage. I'm including a couple of pics. I have a small Legrand structured panel mounted on one post opposite my electrical box. I've already run my low voltage lines from the house to the buidling through 1 inch schedule 40 PVC - two Cat6 and a single shielded coax.
Now I'm looking to branch out and run the coax and Cat6 cables in the building. I thought about using the same PVC but wonder if it's overkill? Flexible corrugated split loom would be much cheaper but mounting is a concern. The 3/4 PVC I'm using for electrical already droops slightly between the steel support posts - a little less than 5 ft. apart. I thought about using cable ties to attach the loom directly to the electrical PVC but I'm concerned about interference. If I use the loom away from the conduit I'm not quite sure how best to support it between the supports.
I do plan to terminate the cables in surface mount boxes with wall plates and jacks.
Any suggestions would be great.
