Looking for mag drill recommendations
slodat
Central-ish, WA
Like the subject says.. I’m looking at mag drills. Originally I thought I wanted a Haugen. Then I realized only a couple models have reverse. I want to do drilling and some tapping with it. I’m leaning toward the Fein JMU 137-2QW https://www.zoro.com/fein-magnetic-drill-press-110vac-120a-9-l-jmu-137-2qw/i/G0993190/ It is two speed, has reverse and includes a 3 jaw chuck and coolant setup. It’s toward the upper end of what I’m able to spend at $1329.
Interested in feedback and recommendations. Thank you!
rmack898
Honu Grove NE Florida
I just bought a Fein short slugger. I know this model doesn't meet your needs because it does not have revers but the quality of the tool is very good and I'm quite happy with it.
strength_and_power
Does the model you are looking for accept the square shank annular cutters or is it strictly a 3 jaw chuck? I have a hougen and it came with a 3 jaw chuck. From using it, i am really impressed with the performance of the annular cutters. When I’ve had the 3 jaw swapped in, it works but definitely not as well as the annular cutters.
slodat
Central-ish, WA
It uses the 3/4 weldon annular cutters. I mentioned the chuck because I know I’d like to have one and it’s an additional cost option on most mag drills I’ve looked at.
lis2323
I have a Hougen two speed with the Jacob chuck attachment and coolant tank. No reverse though.
f150skidoo
Ontario, Canada
I also have a Hougen HMD 904 and I absolutely love the drill.
lis2323
I sold the 904 and kept the 905.
I should have done it in reverse. The 905 is too heavy to lug around for piddly hobby work. I thought I would benefit from the two speed gearbox but I obviously didn’t think the situation through for my particular needs. [emoji15]
lis2323
Saving up for a Tapmatic to use on the mill and drill press. Hard to find them used.
MJD1
The drill chucks that go in the weldon adapter are pretty much useless. Between the play in the hex and extra length there is a lot of deflection and tons of runout.
dr_clyde
Holland, MI
I have two mag drills, and they each serve a different purpose.
My Hougen 904 is an outstanding machine for drilling holes. That's about all it does, but it does it damn good.
I have an old as balls Milwaukee heavy duty heavy weight SOB. It was my grandpas. High and low range, forward and reverse, and the best part, a Morse Taper #3 spindle like a regular drill press. That means I can put pretty much anything that will fit under the spindle nose in that thing. I normally run a 1/2" Jacobs Superchuck in it, but I have put in taper shank drills, reamers, and a few other random odds and ends. It taps great with a decent size Jacob's chuck on it. I've tapped 3/4"-10 without much fuss in steel. Despite all it's horsepower, I don't use annular cutters with this tool. The Hougen is better at that.
If I could only keep one, it would be the Milwaukee. It truly is a magnetic base drill press and not just a hole maker.
04chase
SO CAL
I also have a 904s and it has its place in the shop.
I also have the cordless fuel milwaukee that I use pretty much all the time outside the shop. I prefer it. It does everything 2 speed and has a quick release chuck for the annual cutters square shank. Also has a separate 3 jaw chuck with a shank that fits the annular cutter chuck. So install is very quick and runs pretty tight for what it is. It also has a coolant setup with a magnetic attachment so you can run it on the drill at any angle or on the work piece.
No swivel base like the hougen is the only downside
Sent from my SM-G981U using Tapatalk
Steve from Socal
Hutchinson Ks.
I have a big Milwaukee with reverse and two speed motor, it also has a variable speed control for the motor. As dr clyde mentioned it is HEAVY about 80 pounds with a chuck
For heavy work it is great, I use my crane to position it when able. For jobs where portability is important this is not the ideal tool. The small lighter mag drills are better suited for a lot of jobs. One thing on many of the smaller drills, the depth of cut is limited to 1 or 2".
The chuck on the big drill spindle in that picture is a Jacobs 20N.
Steve
slodat
Central-ish, WA
I’ve had plenty of success tapping with a cordless drill. Maybe reverse isn’t as necessary as I’m thinking..
How does the Hougen 904 do with the drill chuck and twist drills?
jeepinerdeep
South Central PA
I picked up this Milwaukee on eBay, it was gov't surplus, and unsurprisingly, not used very hard. I like the fairly compact nature of it, 2 speeds and nice handle. I paid $450. It was between that model of Milwaukee and the 904. This is what came up on a good deal. I've since jettisoned the enormous case.
I wouldn't hesitate to tap with it on low with the correct power tap, even if I had to back the tap out by hand on account of no reverse. The correct power tap all but eliminated the need to do anything but run it home.
slodat
Central-ish, WA
It’s hard to find info or reviews on the Fein I linked to above. I found this video that shows more than their stock photo.
I think it does what I need.
f150skidoo
Ontario, Canada
The 904 works great with a drill chuck but its not a quick change like some of the other makes. To remove the 3/4" weldon shank chuck you have to remove the two bolts connecting to the mag base and back off a set screw on the motor. The drill chuck with its adapter connects directly to the motor. The few times I had to tap a hole with the mag drill I just put a tap guide in the chuck and used a T handle wrench to hand tap the whole.
Monza Harry
Windsor ON
I have used numerous Milwaukee in both 2 speed and single speed versions at work, these are the industrial "gold standard" they will tap 3/4-10 x 2" dp NP! probably bottom tap 1" if you have a way to hold the tap. Yes very heavy but really these are "Heavy Duty" tools and they will require a 14Ga. cord for best performance/longevity, all of the failures I have seen with these have been motor related from what I wholeheartedly believe is from excessive use with long, small cords. I want a two speed one but they don't seem to come up for sale often around here and aren't for sale for long when they do! These do command a premium used as they aren't even near cheap new. I know this is pushing your budget numbers a little, but watch for bankruptcy auctions, CL, FBMP, etc. and be patient these drills do perform as mentioned above by the Doc and Steve. I recommend the 2 speed if available, but either way you should feel like a winner if you get one! Harry
https://www.mcmaster.com/milwaukee-magnetic-base-drills (That is $3000+ in Canada) I don't see the 2 speed one listed here and I have never seen the 20* tilt feature either.
lis2323
The good news is that the "brand name" units will always hold their value. [emoji106]
Monza Harry
Windsor ON
Haven't done it yet but close.
Put a tap into the Master Grind and surface grind 3 flats into the shank at 120 degrees apart.
https://www.subtool.com/st/mg5cvs1_master-grind_spin_index_fixture.html
Matt- I mean tapping with a mag drill or tapping in thick steel.
What Matt said, the chuck will turn smaller ones but it will usually start slipping around ~1/2 up, 3/4 will definitely need help, or a proper drive system. I use my collet blocks but I have regularly done what Matt said before I had the blocks. Harry
slodat
Central-ish, WA
I doubt I’ll tap bigger than 1/2-13.
I appreciate the info guys. I think I’m going with the Fein I linked in the first post.
lis2323
This isn’t in answer to the OPs question but while we are on the subject of mag drills this is what I like to use ..
A magnetic wand placed nearby to catch most of the swarf
ttpete
Dearborn, MI
Some of the tappers use a Jacobs Rubberflex collet setup.
slodat
Central-ish, WA
Despite there being very limited info, the Fein JMU 137-2QW is exactly what I was looking for. It came with a very nice 3/4 Weldon Rohm three jaw chuck. Two speed gear box and electronic variable speed in those two gear ranges. Reverse is a momentary pushbutton. Should work really well for tapping. It’s about 50 pounds lighter than the Milwaukees with similar features and it’s everything I’ll need in a mag drill. Excited to put it to use!
lis2323
Wow. Nice features.
slodat
Central-ish, WA
