LOOKING FOR MAKE AND MODEL FOR THIS FLOOR JACK
Ricky62
I CAN'T SEEM TO FIND ANY INFO ON THIS FLOOR JACK ON THE INTERNET. I THOUGHT MAYBE IT WAS A MAC TOOLS BRAND (see pic of red jack ) BUT THEY SAID NO IT WASN'T . I ALSO SAW A PIC OF A BLACK HAWK JACK BUT THERE IS STILL NO INFO TO BE FOUND BY INPUTTING THE SERIAL # OR #'S STAMPED ON THE BLOCK. I'M HOPING SOMEONE ON HERE HAS SEEN THIS JACK BEFORE AND CAN SUPPLY ME WITH THE MAKE AND MODEL SO I CAN REBUILD IT. THANKS
Oil leak
Home
Looks like a Napa jack. They were made by Sunex. A copy of a walker Lincoln jack. Walker/Lincoln didn't use springs on the pump handle but the Napa/sunex do.
MovingAlong
Welcome, you and @AndrewTheBoy should get together as you're both going to be rebuilding similar jacks.
Be sure to post up pictures of your efforts along the way. :thumbup:
Should be interested to see which new member finishes first. :coffee:
R
Ricky62
Thanks for the input. I looked online for Lincoln/Walker - Napa/Sunex and there are no pics or info relating to my floor jack.
However, I did manage to find another pic of a Mac Tools floor jack and using a magnifying glass on my screen, I was able to get a model # JSA250MA. I then found the the instruction manual and parts diagram and I think my jack is indeed a MAC TOOLS jack but painted black, I don't know why. You can even see the serial # sticker located on the left side bottom above the castor. I also used the info from the instruction manual and measured my jack and its pretty close. (LxWxH ). Also, the MAC TOOLS jack has the double return springs on the handle. Even the cover plate/parts holder is the same. What do you guys think ??
ajchien
Los Angeles, stuck on the 60 freeway.
I think your jack could be an import that was made under the Shinn Fu America (SFA) umbrella. It looks to be one of those single pump quick lift systems (I think they used the term ”magic lift”, supposedly 1-2 pumps to reach load height). The breather vent on the top of the jack reservoir is the same style as the ones SFA is putting on the current day Hein Werner jacks. I would suspect that they provided the same, or similar jacks under different brand names such as Omega, Mac, NAPA, craftsman and more which could explain the color differences. it looks blue and yellow to me, which are colors NAPA has used. Black and white/yellow is a color scheme that Omega has used.
Heres a stock picture of the SFA breather vent:
