looking for motor brushes
The Cobbler
I've been going thru some stuff that's been laying around trying to resurrect it.
I have a small portable compressor in need of brushes. Canadian Tire Job Mate no name made in China POC . looking for brushes like in the picture ' they measure .0213 x.0213 or 5.5 mm x 5.5 mm
any ideas?
spent way too long searching on ebay
any help appreciated
Old Guy 1
Goldsboro NC
Try this seller on E-Bay.
http://stores.ebay.com/Guadalupe-Valley-Sales?_trksid=p2047675.l2563
The nice thing is they give the dimensions on all there brushes.
If you cant find the exact size,find a set that is close and do a little work on a belt sander or a good flat surface and a piece of sandpaper.
Also if you find some that will work but the leads have the wrong kind of terminal,they are easy enough to change.
Hope this helps.
T
The Cobbler
Thanks for that!
I'm not concerned with the terminal on the lead so much as I am with the orientation (coming out the side rather than the end) and I can re size but if I could find direct fit it would be great.
Davefr
OR
They can be kind off tough to find. Here are two suggestions:
1. If you have good Ace Hardware they often have assorted carbon brushes.
2. Try McMaster.com. They have a pretty good offering.
You can always buy a larger size and sand it down. These things sand down very easily.
Steinmetz
Washington State
any ideas?
Find a brush that is dimensionally close and sand to fit.
