looking for outside led security light
sweetk30
finger lakes area upstate ,ny
led unit.jpegi use to buy these from honeywell . there a wall pack 2000 lumen with photo cell in them for auto on/off . there just right not to bright or huge or ugly .
well they seem to have stopped making another good thing like normal and now i need some more i am stuck trying to find one like it if possible .
i dont like the look of most of the options out there and rather find something close to this clean simple smooth look . and help would be great thanks .
sweetk30
Here's 15 of them.
looking more like all atleast 4k lumen and up . i like the 2000 better .
but those do look like a good close match up thank you .
sparky 1971
Central Iowa
Good luck finding a wall pack that's only 2000 lumens in this day and age. I was in a similar situation a couple of years ago and wound up buying 28 NOS wall packs from several different ebay sellers. I bought everything from 70 watt HPS to 250 watt MH, it didn't matter because I put 60 watt, 2200K (150 watt HPS equivalent) LED conversion kits in all of them, the only important thing was that the fixture had a certain look, and all of them had to look the same. You could do the same and bypass all of the innards and use a screw in LED lamp. When it fails, it's just a matter of changing a lamp and sometimes a photocell.
Here's one that's new, open box. There are plenty more, just do a search for metal halide wall pack.
Norcal
Better to buy a fixture with a medium, or mogul, base lampholder & retrofit a LED lamp then buy a LED fixture, if a LED lamp fails, just replace the lamp instead of dumping the whole LED fixture.
