Looking for reciprocating saw attachment to absorb shocks
jimjdm
I am scraping a concrete foundation to remove peeling paint and joint compound that was put under the paint. Scraper blade attachments for a reciprocating saw (e.g., https://www.amazon.com/Reciprocatin...n-Cleaning/dp/B0B1HC5B3Q?tag=atomicindus08-20) are making the work a lot faster and easier than the manual scraper I was using initially. However, occasionally the scraper hits an irregularity in the concrete that causes it to get caught, which jars the scraper blade, tool, and operator. Eventually the tang on the scraper fails from the impacts. I am looking for an attachment to go between the saw and the scraper to absorb the shock of these occasional impacts. Is there something on the market to do that?
What I want is a piece that functions like the one in the sketch below.
The spring would be tensioned enough initially that this shock absorber would normally act as a short extension only, but when the scraper got caught, it would allow motion to absorb the force. Thanks for any assistance.
dnschmidt
Phoenix, AZ
The tool you're looking for is an SDS hammer. These blow away floor tiles every day. If they can do that a little paint and joint compound will not be an issue. Also, most SDS hammers currently have shock absorbing features built into the tool.
neophyte
Pennsylvannia
As far as I’m aware, no shock absorbing system like this exists for a reciprocating saw.
There are scraper attachments for rotary hammers to do a similar job, and quality rotary hammers routinely have shock absorption systems built in nowadays.
RAS61
Low Country, SC
The Bosch Bulldog is a hammer drill that can be used in chisel only mode and is about the size of a recip saw. I have an older one, not sure it has the shock absorber feature, but the action is better suited to the task, an would probably just shear off any irregularities and keep moving
