Looking for recommendations for high lift door track conversion in Toronto
Relax
GTA, Ontario
Can anyone recommend a good contractor in the GTA that can convert a standard height residential garagae door to high lift for a reasonable price? Thanks in advance!
dbonne
Southern Idaho
I recently had 2 highlift doors installed in my current shop project. The Tracks, winding drum and springs will need to be replaced to convert your door. All of the lift and guiding hardware is different. Also if you are thinking of an electric door operator, you will have to go with a shaft drive unit with a electromechanical locking system. On the upside, you will not have any hardware in the middle of your space, I like the open space above the door, uncluttered look!
All
Are these sectional roll up doors that can have windows that simply track up higher, closer to the ceiling? Or are they corrugated roll up doors with no windows that wind up into an 18" diameter roll?
Can someone post pictures of their "high lift" two car garage door? Thanks!
