Looking for small drive screws or rivets with large heads ??
geomagno
Indy
Trying to replace a mushroomed rivet I had to drill out (on the right of 1st pic). I can use this washer head screw on the left with no problem but I want it to look original with a smooth, flattened head. Tried grinding the phillips slots down but I can still see them. A drive screw would be ideal (2nd pic) if I could find one with a bigger, wider head.
The hole I drilled is 5/64 and the washer head screw is M2.6 with a 6mm wide head. ---- Any suggestions?
wssix99
Chicago, IL
Search for "book binding screws." You may even be able to find them at your local Ace Hardware.
You can also find 2mm and 3mm carriage bolts/coach screws.
G
geomagno
Indy
Thanks for all of the suggestions.
The outline of an added washer shows even if I grind down the screw head really flush.
I looked on McMaster: doesn't look like they have a hollow rivet small enough. And the same with the carriage bolt. I do have small chicago screws on hand as I've used them for other projects, but I have the same issue - size.
While searching for rivets I did happen upon some solid aluminum craft rivets on Amazon. They should fit the hole but not sure if the head is large enough. Hoping I can flatten the aluminum head enough to make it look good. I'll try to update when I get them.
Thx again crew. Your ideas helped in the search process.
G
geomagno
Indy
Being an Electrical Engineer.. with stuff on hand i may fake that with two tinned copper washers and solder through hole. Then some strategic tappy tap tap to get the look. Assumes a solder strength joint would suffice.
Tinning the phillips grooves might work if I can direct the heat. For that matter I might be able to hit it quickly with the mig welder and then file it down....or I could end up blowing a hole in it. This is a harsh learning curve. I might have to practice on some scraps first.
LeeG
Phoenix, AZ
If you don't need many, maybe someone could just turn something on the lathe to do what you need. I made some custom rivets from some brass bar stock to fix something for my neighbor.
Lee
