Milwaukee alsoThe newer DeWalt 20v brushless 1/2" impact will do that without issue, if you want to stick with DeWalt.
Wow the Dewalt website specs that at 1,740 in-lbs (145ftlbs)
If that one won't work they were on WAY too tight.
I have a Dewalt 18V and it works just fine. When lugs are torqued correctly to 100-120ft/lbs.
Yes the 20V brushless has better torque - my father has one and it will out perform mine but it works fine 99% of the time on lug nuts.
Those older "first-generation" 18v cordless impacts (from any brand) were never particularly powerful, unfortunately. That DCF894B is a far more powerful impact.Torqued to 100 lbs... They bought it on Amazon and I read the reviews this AM. I wasn't the only one complaining about the lugnuts. One guy called Dewalt and he said the unit was "marginal" and recommended the DCF894B instead.
Is that a 3/8 or 1/2 version. I'm looking for a compact 3/8 alternative to my M18 high torque.I have the Ridgid Gen 5x cordless impact (450 ft ibs) and I so far I really like it. I actually sold my Milwaukee impact (rated at the same 450 ft ibs) and went with Ridgid. One of the cool features is that it has a setting that automatically stops tightening when the impact begins to hammer so that you don't over-tighten lug nuts. I've only found one bolt that it couldn't budge (and not even a 250 pound man with a breaker bar, penetrating oil, and brute force could move that bolt).
Plus it comes with a lifetime service agreement. The new Ridgid Octane impact wrench has a little more power and may be worth the look.
Personally I have never liked using an impact for loosening and tightening wheel lugs of any type. I use a long breaker bar and a socket to loosen them and then a 4 way to spin them off and back on. That way you have a feel for messed up threads etc. With an impact, especially a powerful one, you will mess up a stud or nut before you feel anythingI have a 14v 3/8 drive Snap On that is good for running bolts in and out without chancing anything because it will let you know if there is an issue. I use it at the shop for disassembling engines after breaking bolts loose with a ratchet.
In a perfect world, I agree with you and used to do just that. However, I found that I would get tired before I even began a job like brakes or tire rotation struggling with 5 lug nuts per tire x 4 with a breaker bar.That is pushing it though depending on the vehicle. I think the lugs on my Tahoe are 140 lb ft ?
I bet 90% of the fastener problems I have seen on engines and on cars are because of someone using a crazy 1/2" drive impact wrench
That's my opinion,
The Harbor Freight 20v earthquake is crazy strong for the money. I haven’t found a fastener that it won’t remove with minimal effort. First time I used it to remove lugnuts it made me wonder if they were tight.
Only downside is the battery platform is pretty much just for that one tool. Would be a good buy perhaps for people that aren't invested in a battery platform or don't care to expand into different tools.
Sticking with the major cordless players gives you an excuse later on to buy more bare tools.
I just picked up a Dewalt 1/2 20volt mid torque gun. It has a feature to tighten the bolts and stops for a sec before impacting. Its rated at 330 lb ft which for me will cover most of my needs. I really like the size of the tool. If I need anything stronger, I'll get out the air impacts.
This!!
