rallendude
- Joined
- Jan 13, 2010
- Messages
- 4
I have a new garage going up. Well, it's a little bigger than a typical garage. It grew every time I talked with the building manufacturer.
What I have is a 54' x 60' garage with 16' eve height. The center of the building is about 22' or so. It's all open. Here is the general layout I'm looking for.
My question is, what do you guys suggest for lighting. I was thinking about using metal halide fixtures because they are free to me. I'm told the power consumption is huge. Is it enough to justify me going out and buying my own? If so, what do you suggest?
I was going to go with 9 metal halide from similar ceiling height shops at work. I would put them in, in a 3x3 pattern with one run down the center truss and them two more runs about 20' to either side in the direction of the roof line.
I plan to build motorcycle race engines here in the work areas. The camper area really won't need nearly as much lighting. I'm also planning on splitting it up into three circuits probably along the same line as the roof line so I can turn on just what I need.
I was thinking of also putting 4' T8 fixtures down the divider wall above the work benches and along the left, outside wall in the work area as well. These would be wall mounted and aimed out in the direction of the work areas.
Thoughts?
Maybe I can make a build thread one day. It's taken nearly a year to get from clearing land to having a carcass to mount doors in. BTW, it's all metal with three main structures. Insulated top and sides. One 4-0 walk through door, so the bikes don't scar the door frames, two 10x10 drum style roll up doors on the front wall, and along the back are two 14x14 drum style roll up doors for driving the camper through.
Thoughts?
