I just moved into a new home where I can finally build out my woodshop. This home has a separate area in the basement with a wall seperating it from the rest of the home. There are double doors that goto the outside only. My plan is to upgrade the lighting first so I can see as I repaint a darkly painted cement wall and epoxy the floor before I start configuring it. Currently there are 7 60watt incandescent bulbs on the same circuit that do not provide adequate lighting (see the top of crude drawing).
I am leaning towards replacing them with 7 2-light 48" T8 fixtures and was considering the following configuration (see bottom of drawing). Any advice or tips would be greatly appreciated.
I was also wondering about the ceiling mounted gas heater and since I will have a light very close to it if the heat will cause special issues with the fluorescent bulbs?
