Looking to brighten things up
CraigNB
New Brunswick
As I have mentioned in previous threads, I have a part time auto detailing business that I operate out of my detached 24x24 garage with 10ft ceilings. It has white OSB walls, a floor drain with a sloped floor (drains very well, water NEVER gets close to the walls), and 4 overhead lights at 7200 lumens each.
I am looking to clean and brighten the floor and make it easier to keep clean. I am going to be offering high end services so I want my customers to feel like they are walking into a high quality shop. I rarely pressure wash inside and I use rinseless washing. However, I would want something that would hold up to cleaning chemicals and would be easy to clean afterwards if I needed to do everything inside (carefully) in inclement weather. I love the look of epoxy but I think there is too much moisture in the slab for it to last.
What does everyone recommend? Deep clean with muriatic acid then seal? I would prefer something high gloss for the "wow factor" that won't be too slippery.
Thanks in advance!
Shiftless
East Bay SFO
Porcelain tile.
Buy some that has some texture rather than smooth. I put tile in our hall bathroom that looks like granite. Lots of compliments and not at all slippery when wet.
JakeKohl
Greenville, SC
Porcelain tile is a "forever floor". Select a through-body tile (no glaze on top - color is through and through) and something with an outdoor traction rating. Install with backbuttering and shoot for 95% thinset under the tiles (very little air gaps!).
Garage Flooring
Grand Junction, CO
Thanks in advance!
Two coats of clear polyurea creates a very cool look.
Garage Flooring
Grand Junction, CO
Would polyurea last on a detached slab? I always heard/read that if there is moisture in the concrete it won't last. I LOVE the look of that stuff though!
A coating would not be suggested if you have hydrostatic pressure but our Polyurea products are used in detached garages all the time.
MJK
Tucson, AZ
Outdoor rated (non-slip) PEI 4 or 5 (durability rating) porcilain tile, and install it with a lip going up the side walls. You can pressure wash to to your hearts content and not hurt a thing.
I found clearance and 'special buy' deals from Floor and Decor to be the best place to get them. I think I paid about $1/sqft from the web store, which they delivered to my local store for free. Don't forget to budget for proper prep and install which are not cheap.
Cheap epoxy a la Home Depot is false economy and a PAIN to get rid of. IMO, don't do do that.
Polished and sealed concrete seems worth checking out in your shoes, as do those plastic snap in overlays. I have no personal experience with either.
Good luck.
