Looking to buy 110v mig welder.
SDBOB1
I'm thinking to add a 110v mig welder without gas to my tools. I have ac/dc Miller and large 220v miller mig with gas. Any suggestions quality price. I was looking at tractor supply. Thanks.Bob
rhandwor
I think you need a 220v mig. I have a 120 v mig and the duty cycle shuts it down and it needs a 1/2 hour time tool cool.
American Locomotive
Rhode Island
The best bang-per-buck IMO is a refurbished Lincoln 125 or 140. For $550 you can get a complete 140 setup and ready to go for flux-core or gas, and it comes with a cart. You can find ones without the cart for cheaper.
Even though they're refurbished they still come with a three year warranty and any part that is even remotely worn is replaced.
I've never had an issue with hitting the duty cycle on max power with my 125 and flux core wire. It has an automatic temperature shutdown, but I've never hit it.
lbhsbz
Long Beach CA
I wish I'd never gotten rid of my Lincoln SP135 when I got my bigger unit.
I've used several of the older and newer lincoln 120A (SP135T, SP125, the newer 140) class machines and I've been happy with all of them.
bobcatdan
Kaukauna,WI
140 amp Hobart or Miller. Big enough to do something. Go too small and you can't weld two paper clips together with the thing. We have a tiny Lincoln at work and I'm pretty sure I could weld better with a soldering iron.
Kenskip1
Missouri
I will second this nomination for the Lincoln 140. I just recently purchased this welder new. It has made even me into a good welder. My Longevity is now collecting dust.
montanafordman
Meridian, ID
I'm amazed at how many people aren't reading the OP's post thoroughly enough to see that he already has most of the bases covered and just wants a portable 110V mig for simple small jobs. I think you're right on track looking at tractor supply. I have the Hobart Handler 140 that I purchased at Tractor Supply. Occasionally they go on sale for just under $500 and I think they're a solid buy. I'm very happy with mine and it seems to produce a nice solid, stable arc (however I use mine with gas) The nice part is that it comes with the regulator in case you ever want to use it with solid wire for some reason but it would work well with flux core for small and simple fabrication jobs out of the box too. It seems to be built better than the box store welders too with metal drive parts for the wire etc.
Vicinity
WA
Hobart 140 is on sale at Northern Tool for $479 and with coupon 252521, it knocks it down to 429. I just bought it as my first welder.
Also if you have a Discover card, they're doing 5% back at tool places for another $25 off, making it about $400 for a brand new unit.
tclark
Another vote for the Hobart 140; I only use mine occasionally but it works well and I've never had any trouble with it. I use both gas and flux core depending on the project.
speed bump
Butte Montana
Unless you need it now I would just wait until one from Lincoln, Miller, Esab, Hobart, Etc comes up cheap via either refurb or used. My little century 110v welder cost me $25 at an auction and welds nicer than my Miller Sidekick (basically the same thing as a hobart handler 140).
If you need it right now the Hobart handler 140 is pretty much the way to go.
barracudadave67
Southeast Wisconsin
Another vote for the Hobart 140. I have been using one for a long time, and it just works good. Done lots of body work with it. Good all around welder and machine, specially if you have to go some where, and 240 volts is not available.
barracudadave67
Jazzman442
Tampa Bay area, FL
I never have welded but I am wanting to learn. So the Hobart 140 is the best all around unit? Any others? Not trying to hi jack just wanting to learn.
Vicinity
WA
Through all my research it's the best bang for buck (with the sale I listed above) on a new unit at 110v. More expensive ones have more features and better internals, but this one seems to chug along well enough with not heavy duty use (though I have read some people used it pretty heavy just fine).
Rustypigeon
USA
The Hobart 140 is an excellent choice IF you are looking for a 115v welder. A 230v welder will give you a better duty cycle and be able to weld thicker material.
I weld mostly thin sheet metal body panels and make small tools with my Hobart 140. It is perfect for that.
If I need to weld thick material, I have a Miller AC/DC 230v stick welder.
If you anticipate welding thick materials or need a long duty cycle, get a 230v welder.
ejkuhl
Southern IL
My northern industrial (now Ironton I think) 110v flux core has served me well. Can weld 1/8+ with no problem. I put some decent .035 wire in it and a better longer ground clamp on it. It's a 110 flux core so you will never get pretty welds but it does the job.
Sent from my Moto G Play using Tapatalk
wagon
calif
If you want new, get a Hobart Handler, or a Millermatic 125 Hobby.
I've known [plenty of people with clones of that Eastwood 110V and have blown boards, failed drive motors, etc. They're junk. On the plus side, a board is $22. My Miller's board is likely over $500.
If you want used, see if you can find a Lincoln SP-100. That was a bad *** little machine.
The cost difference between new and used in this class of machines is pretty slim. It might be an extra $100 or $150 between a nice SP-100 or a brand new Hobart. One comes with all accessories, and a factory warranty, the other doesn't.
