Looking to make simple plastic hinges for birdhouses.
Captain Spaulding
Southern Indiana
I have a bunch of bluebird houses. The doors are hinged at the bottom. It’s basically a live hinge, a two inch wide piece of plastic with a thinner section at the hinge point. Rather than being a commercial hinge, it really looks like a piece of vinyl building material adapted for the job.
I need to replace several hinges after 15+ years. Anyone have any ideas of something cheap that would work off the shelf?
C
Captain Spaulding
Southern Indiana
lots of options to buy.
Little steep to pay $10 for a hinge on a $15 birdhouse. I have 39 of them, though not all need replacements yet. I’ve looked online a bunch and haven’t found anything reasonably priced that claims UV resistance.
MovingAlong
I’ve thought about that. I’m a little concerned it might make it less **** resistant.
I'm with @cgrutt on the strap idea. Pics might help, but not seeing how it would make it less **** resistant...
mike93lx
Richmond, VA
A $300 3d printer, a week to learn cad, $20 bucks in filament?
Or maybe find a model on a site like thingiverse, maker world or printables and have someone print them for you. Material would be under 50 cents each
Here's an example
C
Captain Spaulding
Southern Indiana
C
Captain Spaulding
Southern Indiana
I’m not sure there wouldn’t be a little more play on the hinge end to let them get a paw in to get the door off. I’ll get a picture tomorrow. Got chased inside when the storms rolled through this evening and the last one is hitting now.
bugnut
Central Ohio
with the need for that many someone on ETSY will print them for you, can use an design you like and probably fairly cheap
BurtEggley
maybe a piece of stainless wire wrapped around a screw and washer. Not a true hinge but inexpensive and it would work. Or some small chain with a screw and washer thru the links.
Smilodon
Titusville, FL
Hey, this is Garage Journal. You'll need a 3D printer... A dedicated computer would probably be recommended... Some sort of roll-around cabinet/work surface to put it all on... Someplace to put the whole setup that is climate controlled... Some time and experimentation to learn how to use it...
Sure, it *might* be a little bit more expensive, but it'll *pay* for itself over time. Think of how cheaply you could run off a batch of hinges next time. Not to mention the job will be done right and the birds will thank you for the lack of shoddy construction!
You could also use it to print small "no *****" signs to post at the birdhouse doors...
rooster59
Land of the Pines
old bike chain + chain break tool. chain should be about 110 links long or so. break pieces of chain x links long, screw through the tooth gaps in each end. 1 chain should make a good number of hinges.
nadogail
Coronado, CA
You will get a Chain Tool out this project
C
Captain Spaulding
Southern Indiana
Sorry I dropped off the thread. The night after I last posted, some good friends’ house was damaged when a tornado dropped their neighbor’s roof on their house. Spent several days getting their house watertight, and then we headed to Florida for a while. Finally got a picture of one of the hinges in case anyone has a thought.
southalabama
Brewton AL
Interesting design. Have three different types of bluebird boxes and none have hinges.
One the top held by single screw. Second the side opens and the third the front opens. The opening mechanism is simply a nail driven in for the pivot and screw on the bottom.
Your request. I’d probably cut a small length of water hose and split it down the middle lengthwise for a hinge. On the bottom should survive the elements.
