Losing a tiny part
benjamintmiller
IA
So nobody else here disassembles assemblies with springs and small parts inside a gallon zip lock bag?
Lassen Forge
I always thought the "Jesus clip" is the one that holds your drive chain together that you absent-mindedly put on backwards... If you're lucky, the chain goes out behind the bike, as you slowly come to a halt in the middle lane of a freeway. If not, the chain wraps your rear axle...
Pathfinders
Upstate SC
Many years ago when I was a broke E-2 in the Army I was working on a 73 Nova. Lost one of the needle bearings in a U joint. Bad part was I was working in a dirt driveway. I thought its only one out of the bunch, should be ok. After a test drive I spent about a hour looking for it. Found it.
crasher
Bedford, Virginia
With a nod to BenMiller (above) - For the guys that do this stuff more than once, and can sit/stand at a table or bench:
When you disassemble/assemble the tiny springs into stuff like R/C cars and AR15s, try to do that part inside of a big/clear plastic bag.
It really cuts down on the trajectory when they launch.
When you disassemble/assemble stuff with lil-tiny setscrews and nuts and pins and stuff - remember that there exists a method that jewelers and watchmakers used to employ.
It's an upper body apron that fastens behind your neck like a bib, and extends to a tablecloth over your work surface. Anything that falls will fall onto/into the tablecloth or the part of the cloth that covers your lap, where it comes to rest within reach instead of somewhere 'down there on the floor/rug' area where you either have to stop and fetch it or you lose sight of it completely and usually forever.
And don't forget the magnetic bowl where you can drop the stuff you're disassembling, so it's all in one place, and not rolling around.
goingtoarizona
Central Valley California
My well is under the floor in my garage. It's covered by about 6 six by twos. Small parts just love to fall between the six by twos into my well room. I gotta put down some 4X8 sheets of plywood before I really loose something important!
