lost power to 3 outlets??
m.breen
So 3 outlets no longer have juice. I don't know which breaker they are on, so I re-set all of them twice. Still nothing. What could have gone wrong? I left a radio turned on and plugged into one of the outlets in case the power mysteriously comes back. Thanks for any advice.
PCustoms
VT
Gfci tripped?
Outlets daisy chained and bad connection/bad outlet?
manwithtools
Lebanon, TN
Could be a neutral loosened up too. Look at all the connections for that circuit. If you are not comfortable doing so, call an electrician.
Where are these outlets located?
Its either a bad splice in a pig tail or a back-stabbed outlet that gave up the ghost.
larry_g
oregon
One in kitchen, main floor. 2 in basement close to each other.
Any reason to believe that the ones in the basement were stubbed off the kitchen circuit, or do they look original to the house?
Is the kitchen one near the breaker box, or could there be an outlet between it and the breaker box?
My guess is that there is an outlet or two on that circuit between the dead outlet and the breaker box and the circuit has opened up at the dead outlet or the one just upline from it.
Does this house look to have original wiring or has it been retrofit and added onto? age of the house?
lg
no neat sig line
Marctrees
TX/LA border - Toledo Bend
Very good Idea w the Radio.
Good thinking.
Larry sed - "My guess is that there is an outlet or two on that circuit between the dead outlet and the breaker box and the circuit has opened up at the dead outlet or the one just upline from it."
Yup., well explained.
WHERE in the house are these recepts?
I still wanna make positive they are not off a GFI.
IF it is not a tripped GFI issue, then your problem highly probable is in.........the closest to these three other recept that is hot, or.. in the dead recept closest to the closest hot one, as per Larry.
And so it's a poor connection like said above, very likely a backstab as Wylie said.
If you are not used to going into boxes, You COULD start by first finding the closest hot and the closest dead one to each other, and plug in a tight fitting 3 wire cord into them, put a small reasonable sideways wiggle on the cord end.. WHILE your power is on and you know the radio is "On" and loud.
You very well may get radio action, found the box w the loose connection.
Obviously, the faster the radio puts out after being energized, the better for this.
If it not fast, plug in a lamp w fast on old school lightbulb in it you can see.
Anyway, it would help us to know - Approx age of house... WHERE..what room these are in. Marc
tfi racing
Cedar,BC
Another vote for a backstabbed receptacle.95% of the time it is behind the hardest piece of furniture to move...
m.breen
The house is around 60 yrs old. The breaker box was upgraded, (i assume from fuses), and the outlets appear to be original. Two of the dead outlets are in basement close to each other and the other is in kitchen on main floor. The breakers are in the basement. I will check the wires, starting with the closest to the box. Thanks everybody. I will try that tight fitting cord trick first.
