My 20 X 50 garage has a fairly low, dry-walled ceiling. I think the floor to ceiling height is about 9'
I want to install a 4 post lift which needs another 2-3 feet.
If you can picture the garage in quadrants, I'd like to install the lift in the right, rear quadrant.
It's a two story garage with the upstairs used for storage.
What I'd like to do is cut the ceiling drywall out a little larger than the lift dimensions. Once the drywall is removed, I have to deal with the joists.
There is a steel beam running length-wise through the garage. It's visible from the ground floor.
I know this is a tough question without you seeing the garage but what issues would I face cutting the joists but still reinforcing the area where the lift would go up?
Ideally, I would rebuild the higher ceiling with drywall and lights. Just like it is now.
Any suggestions are appreciated. Clearly I need an engineer to look at this but figured I'd go to you first to see if anyone else has dealt with something like this.
Attached is a poor picture but it might give you an idea how low the ceiling is.
Thanks
Thanks
