Low level heat in a Garage?
Rich5ltr
Hampshire, England
Has anyone on this forum got low-level heat in their garage? I am thinking of fitting some oil filled tube heaters connected to a thermostat to keep the temp at around 5 °C / 40 °F approx. However, I have no idea how many watts/btu output I would need for a brick built triple garage and all the BTU calculators are to keep a living room warm not a garage frost free.
Your thoughts?
p.s. If a mod can move this to the Heating sub-section that would be appreciated.
matt_i
I would do one of two things.
1) Start with a heater value and turn it on to tstat control.
Place temp monitors or plastic bottles of water across the shop, as far away as you can get them. Check bottles for freezing, if needed, add more heaters.
2) do some basic calculations, but you have to measure areas and estimate R-values and pick an exterior temp. Use classic conduction equation, Q (heat) = A (area ft^2)/R (R-value) * (delta T) .....Q=A/R*(deltaT)
In English/SAE units, BTU/hr = (ft^2)/(ft^2 * deg F *hr/BTU) * (degF)
You have to do this calculation 6 times, to consider all 4 walls, floor and ceiling, estimate R values for each, concrete R = 1. I'd use something like an exterior of 20F although if you know it regualrly gets colder, then use that. I'd estimate ground temp as 50F. When you reach the total you will have a number of BTU/hr that have to constantly flow to maintain your temp. Can easily convert to kW if you are going to heat via electric. This is a quickie number and can't account for factors like north wind blasts and air leakage all which steal your heat faster than the basic simple conduction equation.
3) You didn't ask but: There's nothing wrong with getting say a 30K-45K-60K-80K BTU/hr natural gas heater which is way overkill for the "above 40F" you desire, but put it on a "garage" thermostat, it will run here & there, but only as needed. When you want to work or occupy the shop, you dial it up to 65F and you'll be happy in 15 minutes or less.
R
Rich5ltr
Hampshire, England
<clip> There's nothing wrong with getting say a 30K-45K-60K-80K BTU/hr natural gas heater which is way overkill for the "above 40F" you desire, but put it on a "garage" thermostat...
Thanks for the reply, I'll get that calculation into an Excel sheet so I can play with it!
Your point about overkill is a good one and something I hadn't thought about.
p.s. I'm in the south of the UK where most years, in the winter months temps hover around just above freezing to 50F, so I am looking for some residual heat and don't have to cope with the extremes of some regions in the US!
u2slow
BC
Your thoughts?
Watts are watts. Free used 240V baseboard heaters are your best bet if you have a basic grasp of how to wire a circuit. I'd bet you can keep the frost away with a 15-20A 240V circuit.
R
Rich5ltr
Hampshire, England
Thanks chaps, sounds good.
p.s. Doesn't look like 'Thermocubes' are available in the UK for our 240v system. So it needs to be a wall mounted thermostat.
