thrytis
I'm planning on putting epoxy on my garage floor sometime in the next month. I figure i should be able to keep above the minimum temperatures if i heat the garage for a day in advance with a propane heater and then use a couple of small electric heaters off the floor to help maintain the temperature for some time while the epoxy cures. I won't be able to have an outside door open during this time for ventilation (and i don't have windows), so i need something with fairly low odor/fumes. From reading manufacturers' websites, i've found a few that look like they could qualify. Does anyone have experience with any of these and can comment if the fumes would be too much in a mostly closed environment or issues you've had applying them at near minimum temperatures?
Most water based seem to fit the bill:
Others:
Thanks!
Eric
- UCoatIt (min temperature 60 F) - without topcoat.
- Original Color Chips (min temp 50 F)
- Rustoleum Garage Floor Epoxy (min temp 55 F)
- Quikcrete (min temp 50 F)
Others:
- Epoxy-Coat (min temp 45)
Thanks!
Eric
