Low profile 3/4 drive ratchet?
Cap'nJake
Mid-MO
I know it is a weird one, but I work in an industrial setting and I have a machine that has low clearance but have to use sockets up to 1-3/4 it would be a lot easier if something like a low profile 3/4 drive ratchet existed. Does such a thing exist? Or am I just dreaming?
C
Cap'nJake
Mid-MO
It doesn't work because I don't have enough room to the side of the nut I have to turn to fit a ratcheting wrench on it
LXCam
Btw, if the ratchet wrench will work check out northern tool clearance area. I got all mine for $20ea. But the last time I looked the sizes were limited and I think the price was at $25.
Oops, never mind :)
C
Cap'nJake
Mid-MO
Does anyone make a 3/4 square drive end with a hex end I could fit to the socket and then to a ratcheting wrench? That would work.
kunkernator
US of A
I have clearance for a socket tho but can not for a typical 3/4 ratchet
I have a very similar situation in an industrial setting that I work in. I use these 'tubular' wrenches. Snap On makes them, and brands them under Snap On and Williams. VERY heavy duty, and versatile. I use them in combination with a torque wrench that PI makes, they are designed to slide in to the end.
http://www.tooltopia.com/precision-instruments-c4d600f.aspx
http://www.snaponindustrialbrands.com/cat-19-1-130/tubular-wrenches-and-handles.htm
jlipsky14
Northern NJ
How much torque is being applied to the bolts? Could you get away with using a high quality 1/2 inch? They will take a lot of torque before breaking and under 2" should be doable.
Wes J
Peoria, IL
What's the budget? Hydraulic torque wrenches are the cats meow for this kind of app.
Otherwise get out the welder...
C
Cap'nJake
Mid-MO
I hadn't seen the tubular wrenches before. I now need to get some of them. Thanks! Idk if they will work 100 percent with this problem but they do solve a couple other difficult spots I have.
C
Cap'nJake
Mid-MO
Not a ton of torque usually not more than 50 to 80 lbs at the most. Who makes a 1-3/4 half inch drive socket tho. I have seen only up to 1-1/2 inch
kunkernator
US of A
Not a problem. And dont be afraid to put some torque on them. I use them to torque bolts to 460 ft lbs on the daily!
You can order all the Williams ones from Amazon, or get Snap On ones from their website. The Snap On ones are IDENTICAL, just a different stamp, and double the cost. Get the Williams ones, and you wont be disappointed.
C
Cap'nJake
Mid-MO
I don't need anything that big and welding isn't an option. It's not really a nut. It's actually a hex shaped die holder on a press.
LXCam
Why don't you get a machine shop to get a piece of hex tool steel and machine you one, then get it hardened. I have to assume if you're working in that environment, there's at least a mill to be had.
espyking83
Hell hole of a King Air 200
Looking for a low profile 3/4 ratchet seems to me like looking for the ketchup in a Chinese food restaurant. In my experience just two completely different concepts. Sorry I couldnt help.
T45
1": bolt; Cut the shank to 1 " long or so; square off the remainder to 3/4"? - use with the 3/4 drive socket and Ratchet wrench solution.
If it works you can drill a hole; get a close fitting steel ball bearing (ace hardware); and a backup spring; and peen it in with a punch.
Also check for older Wright, I have one in 1-5/8, - bigger than the current line up that stops at 1-1/2
Strouty
Southern Maine
Another thought would be to have a socket custom made. They could cut it down to the shallowest possible dimension, then weld a 3/8" square on it. If the torque is really low, that would get you the most clearance.
48548
Phoenix
A t72 1/4 snap on can meet those torque specs. Get a special socket and a little pipe.
geartow
ohio / pa border on I80
Had a simiar issue uset a 1/2 to 3/4 snapon adaptor and 2 inch wide by 3/8 thick 3 ft long piece of flat stock. Drilled a hole into an end then welded it and ground it down. And you have a 3/4 inch drive tool that is just over 1/2 inch thick. Rounded the ends it has had tons of torque on it holding up well.
Davefr
OR
Plomb (and maybe Proto) had 3/4" Ratchets where the male socket attachment was actually removeable. You were left with a female 3/4" square drive. (very low profile).
If you could somehow attach the socket to the ratchet's female square drive that might work.
Dave, I'm not following how this helps? the scoket sits against the rachet pretty much flush anyway...
just cut your socket down. that would slim your whole setup much more than a low profile 3/4 ratchet.
This has possibilities if the socket height is a major factor. Tt sound like some height is necessary (Or he'd have gone with the ratchet wrench)
Davefr
OR
You're right. He'd need to modify a socket so it's O.D. fit's into the ratchets I.D. (round socket in square hole). Probably a silly idea.
