I have searched this forum for similar threads but haven't been able to find an answer. So sorry if this has been asked before.
What I want to do is install interior walls in my metal shop building. The current framing is C-channel for the horizontal wall girts that are spaced roughly 3' apart vertically. The vertical steel columns are square tubing spaced 12' apart. I really like the look of the sheet metal low rib AG panels and have seen some people use this for interior walls. I think the ribs are spaced 9" apart with a depth of less than 1" This paneling is what I would like to use but have a couple of questions before I go spend a bunch of money on it:
1) Are the three horizontal girts sufficient to attach the AG paneling to using self tapping metal screws? Or do I need to install some kind of structural support behind it such as 2x4's on 16" centers or plywood?
2) If I don't have any kind of structure behind the panels other than the girts, is it sufficient to attach metal conduit, metal boxes, etc. just to the sheet metal using conduit clamps and self tapping screws? I'm afraid the 29 ga steel panels may not have enough thickness for the screws to sufficiently bite and hold up over the test of time.
I appreciate any advice you all can offer up.
