Low voltage fan timer options?
slowtwitch73
Hellgate
I'm trying to replace toggle switches that operate our whole house recirc system. Switches are in the bathrooms and have low voltage (28) thermostat type wires coming in. I am pretty sure the various digital timer options won't work with the low voltage. Is my only option a mechanical spring loaded type timer switch?
Photo is whats there currently.
dogdog
Low voltage means what voltage... once you know plenty of Ebay/amazon options from wireless remote to other things. I don't think there are any rules what you can use as low voltage control.
slowtwitch73
Hellgate
I test 28 volts. Most of the timers I can find are 120+ vac and req a neutral/ground. I searched around quite a bit...
I tried an Eaton digital timer and no dice.
The Cobbler
a spring wound timer would be an option, without getting fancy & running 120v and a relay .
perhaps you could find a wireless timer and install the reciever at the circ system . again a relay & wiring probably required
infinkc
slowtwitch73
Hellgate
Yeah I may. I see I can get them that max out at 15 or 30 minutes which would be good. Way cheaper, and I would venture longer lasting.
nadogail
Coronado, CA
I use a spring wound timer and a relay to control the electric heater in the garage. Nobody accidentally leaves the heater on.
alfredeneuman
Fullerton, CA
Almost all electric heaters with a fan run the fan after the heating coils turn off (to cool the housing and avoid overheating).
Suddenly turning it off like that can damage the heater.
popbigguy
Lincoln, NE
Try this web site:
Go to their catalog. Page 370, part number SS910, 24VDC & AC. Also page 374, part number SS410 is 24VDC & VAC. Now finding where to buy them is another story.
