willlgord
switching lights with relays
I recently installed 11 2x4 4 bulb t8 light fixtures in my 32x24 garage. I wanted to be able to switch each one on or off independently without a huge bank of switches and a ton of romex so I decided to try using low voltage relays. I installed a 24vdc relay in each fixture which is controlled by a pushbutton switch. Each light fixture draws about 1 amp and the relay contacts are rated at ten amps, the power for the relay coils is supplied by a 24vdc switching power supply I mounted in the first fixture which is controlled by one regular light switch (also powers up all the lights). The amp draw on the 24v relay circuit is very low so I used runs of 8 conductor plenum wire I had laying around. I bought the relays and switches off a site called electronics goldmine, the relays were 99 cents each and the switches were 79 cents each. The 24v switching power supply was bought off a site called all electronics for under $5. So far this is working like a charm though the switch plate was a soldering challenge but it was worth the trouble. I also added an led indicator light to show the 24v is present. Has anyone else controlled their lights this way?
