Low Wattage Dimmer Switch
Fix Until Broke
SE Wisconsin
Does anyone make a low wattage (small physical size) dimmer switch for 120v AC lighting?
I've got a room with 3 rows of 3 can lights with 13 watt LED's in each one. Each row is a separate circuit and goes into a double wide switch box on the wall.
The problem I'm running into is that all the dimmer switches I find are rated for 600 Watts and therefore are physically large and don't fit in the switch box. Since I only have 40 watts of load, I'd like to find a smaller dimmer switch so I can fit them in the box.
Lots of them rated for 300 Watts for LED's but still rated for 600W on incandescent/halogen bulbs so still physically large.
I had a pair of these in the box (so I know these fit) before realizing that I needed the dimming functionality. Ideally, they'd be this size, but able to both switch an dim.
Anyone know of any solutions for something like this?
F
Fix Until Broke
SE Wisconsin
Thanks - I'll have to see if any of these are in stock locally or if I can find any dimensions on them to see if they will fit.
Ultimately I'm looking for a smaller unit and assuming that a lower wattage rating will provide that.
