I recently had a 30' x 40' with 12' walls post frame building put in for a garage. Since then, I've added walls and insulation to one half followed by adding a ceiling. Unfortunately, clearance for the overhead door was not taken into consideration when adding the ceiling. Now the door only goes up a couple of feet before running into the ceiling. Being that the ceiling was installed using 2x4's laying flat and the steel for the ceiling having ~3/4" ribs, I'm figuring ~2 1/4" minimum needed to lower it enough for the door to clear.
Is it possible to lower the track just by shifting the track down? My father-in-law thinks it's doable and he almost has me convinced. I figured it'd be best to check with others though. If anything needs to be done with the torsion bar & spring...I'll hire a professional. I have no intention of adding a door opener but, if I ever do, it'll be a wall mount version.
