Lowest tooth count ratchet
Neoumlaut
I've got a little bit of an unusual question regarding ratchet tooth count. It seems like every company these days has 80+ tooth ratchets, and it got me thinking. What is the lowest tooth count used in a ratchet? As far as I know "normal" coarse ratchets have somthing like 32-36 teeth, but companies don't really advertise tooth count if it isn't a fine tooth ratchet.
I'm not particularly interesting in actually using a ratchet with coarser teeth, this is more of a "tool history" question.
Revere Cycles
Rochester, NY
Jim C.
I don't know how many teeth my RP CM ratchets have, and "feel" can only be described as summer teeth of various sizes and shapes.
Reference this link for the meaning of summer teeth: https://www.urbandictionary.com/define.php?term=summer%20teeth
The standard Craftsman Teardrop raised panel 1/2”, 3/8”, and 1/4” ratchets, produced between about 1956 and 1993, had 32, 24 and 24 teeth respectively. The early version of the 1956, 1/2” drive ratchet, came with 40 teeth, but was eventually reduced to 32 teeth.
Jim C.
Lassen Forge
Or a Car crank.
One right,
No Left.
Wow! Mine has 4... must be the new, improved version!
And it's the only nut I know of that will turn backwards all by itself and bust your arm, or at least cause great pain.
That *****.
American Locomotive
Rhode Island
I believe Koken still makes a bunch of low-tooth count ratchets - but they try to make up for it with having a very smooth, low back-drag mechanism.
On a side note, what's the strongest tooth count for ratchets?
It's complicated with modern ratchet designs. Modern ratchets typically engage multiple teeth at once. For example, the new SK 90T ratchet engages something like 10 teeth at once. So 10 teeth of a 90T ratchet is probably going to be stronger than 1 tooth of a 24T ratchet.
ReggieR
Vinton
I'd have to say the early S&K and Wrights which were around ....40 tooth. It you manage to break one by hand, no pipe extension, no two drunks jumping on them,check into a mental institute or lay off the 'roids. It's about build quality.......not just counting teeth. Those original Proto pieces are up there too as are the very old Waldens.
You'll wreck a breaker bar as easy or easier than an old Wright or SK ratchet
