I have a question using smartside as interior walls. In my region they only sell the 3/8", it says it's 0.315" so not even 3/8".. How is it holding up for you guys.
http://www.homedepot.com/p/LP-SmartSide-SmartSide-48-in-x-96-in-Strand-Panel-Siding-27874/100055901
They use this to side sheds and seems "hard" enough. It's does not feel like 3/8" of any other wood products. I was fixated on 1/2 ply for a while but this has the T&G so I think it would look more finished.
As far as baseboards and outlets go. Do you think I just need to caulk the cover plates around the grooves it is different thickness. I don't think I can plan carefully enough to have every outlet in the middle of the "plank". Baseboards, I don't know, they install side trims across it so it must look ok with plenty of caulking. I am going to have a floor installed so I plan on having baseboards.
So this is the kind of thing that needs to be decided since I either install the electrical box at 0.315" or 0.5" depending on the material used.
