AntonLargiader
I recently got this tool grinder; it's a K.O. Lee B803 and I suspect the rest of the model number indicates that it's from 1952.* It needs a lot of cleanup but specifically the old GE motor; it squeaks at speed.There are no oiling holes so I assume it's a ball bearing motor.
Do I just clean up the shaft and slide one end cap at a time back to access the bearing? I'd rather not dismount the grinding wheels.
It looks like I could also pull seals away and probably access the bearings without disturbing anything else, but I would damage the seals in the process. And if the old grease is hardened, my experience is that it needs to be completely cleaned out.
The wheel turns very smoothly but there is some drag.
* EDIT: I think that's actually wrong; the model is B803-9-52 and I have seen a few others like this so it's probably all the model number.
