SK2003TypeS
What do you guyz use to lube the garage door hinges, tracks, etc. with ? I just installed a Chamberlain belt drive opener. The door is ancient and creaks like crazy.
Dry lubes, maybe silicone...no oil or grease...abaran said:It's my understanding that dry lubes like graphite are what door manufacturers recommend. Their reasoning is, wet lubes will attrack dirt and other "stuff" that will hinder the door.
Of course, I didn't listen to them and I used white lithium grease on my last door and it worked just fine. Mind you, I didn't go overboard when I applied it. Use an acid brush or something similar and you'll find that it goes a looong way.
Hope this helps.
Andy
krooser said:Dry lubes, maybe silicone...no oil or grease...
