Lubricant for 4 post lift
albaran
Stratford, Ct.
What is the best lubricant to spray into the column of a 4 post lift? Some people say WD-40 and some say Pledge. The reason I ask is that I have an Eagle lift that works fine if there is a car on it but drags/ hangs up with no weight on it when it is lowered.
gungatim
west mich
WD-40 is not a lubricant...not saying you can't use it, but it will evaporate rather quickly...I use a can of teflon dry slide spray lube. works well. I only use it because I scored a damaged case of them for $10 at an auction, but have come to like the stuff for nearly everything.
Bondo
Greenfield, Maine
Ayuh,.... Fluid Film,..... ;)
LuvAZ
Scottsdale, Arizona
Not sure where you're coming from insofar as saying that WD40 is not a lubricant and evaporates rather quickly?
http://wd40.com/uses-tips/lubricate
Anyway, to the OP, my lift mfr recommends WD40.
HTH,
Will
BillK
Beautiful Southern Maryland
Thank you ! I was going to say the same exact thing. I have engine blocks and crankshafts that I sprayed with WD40 probably 5 years ago and I assure you they still feel pretty oily to this day.
If you look at the MSDS you will see that a good amount of the ingredient is Petroleum Distillates which sounds like oil to me.
I think some guys just don't like the product for some reason or "read it on the internet" that it is not a lubricant so they have to keep repeating the bash :(
Just another worthless internet opinion ;)
gungatim
west mich
WD-40 is a thin film extremely low viscosity water displacing solvent...essentially naptha. Regardless of what they tell you, go spray some bare metal. it will rust in a matter of days. I'm not a WD-40 basher, it has its uses, but lubricating anything for more than a day is not one of them.
Wizzard
I like silicone spray lubes...they tend to have good moisture resistance as well.
peryan
chicago
My Bendpak HD7W did something similar. It studdered going up and down. At firts without a load and then later with or without a load. It turned out that is was suffering from cylinder stick/slip.I bought a Caterpillar Tractor hyd. additive for this condition from a local cat dealer. Problem solved!
