How do I take care of an air ratchet? I am just a DIY'er and would be using the ratchet maybe a few times a month. Do I just dip the head in oil and wipe it down?
How do I take care of an air impact wrench such as an IR 2135? Do I need to lubricate it like an air ratchet?
An air compressor should be drained daily, correct? Once it has drained, should I leave the drain plug closed or open? Will moisture build up inside if I leave the drain plug open?
Thanks
Thanks
