Lufkin 7172 - An odd Ruler
PsRumors
Cartersville, GA
This was in my grandfather's stuff and I've never been able to figure out its use nor found any reference on line.
From left to right each section measures
0 - 2 ft 2 inches
6 ft - 4 ft 1 inches
4 ft 1 inches - 2 foot 2 inches
At first I thought it must be assembled incorrectly but there is no way to assemble it where it would run 0 to 6 feet.
Any thoughts on why it would be set up in such a fassion?
My guess is you’d telescope the right side out (the reverse reading side) into a jamb or opening, two points, then the number at the joint is your measurement. Kind of like using a caliper for an inside measurement
Great for door jambs, windows etc, but wonderful for making sure something is square, by measuring the diagonals.
Beerhippie
Far NE Oregon
For inside measurements for door or window casings, I use a sliding rule as a story pole--just transfer the measurement directly from the rule to the casing. Using numbers always means compromising, whereas directly transferring is accurate to sub-RCH levels.
