lugs in elect box
Ray Adams
I have a 100 amp shut off box for my garage tried to use but the main lugs are galled they used alum wire. so I cut the wire off is there anything I can use to get the screw lugs out thanks. Ray retired trying to use if I can Ray
sberry
Brethren, Michigan
Spray a little weasel pee on them for a while, it tends to work on some alum. Some lube on them BEFORE tightening would have solved the issue but they can pretty much be ruined once seized.
alfredeneuman
Fullerton, CA
Ray,
Just replace the lugs. They're cheap insurance to some potentially costly failures.
It's like an ounce of prevention vs a pound of cure.
Once the threads become galled there won't be any way to properly re-torque the lugs.
Aceman
Eastern Oregon
I agree with the others just replace the lug. I wouldn't mess with lubricants,etc since it's galled up. If it's the type of lug that has the screw behind the wire holding the lug on, just drill out the galled up set screw until the wire is released. Then you'll have access to the screw behind it so you can remove the lug.
sberry
Brethren, Michigan
My take on this is if they are seized so are most of the rest of the screws and by the time a guy figures out how to r&r the lugs, buy a couple parts that cost the same as a new box on sale he might as well replace the thing. Probably about 50 difference in cost and someone that doesn't know how to do this probably shouldnt be working on panel chassis anyway.
Mustang51js
Haskell nj
I've had luck before pulling one strand out at a time. Once the wire comes loose behind the lug you usually can loosen the screw. It really depends on how corroded it is
