Lump
Today (Saturday 9-24-11) I was a vendor at the Troy Swap Meet at the Miami Co Fairgrounds in Troy, Ohio. I usually spend at least 1/3 of any day during which I am supposed to be a "vendor" shopping for myself...especially during the blacksmith show. But today my own booth was really busy, and I couldn't get away until the day was nearly over.
Anyway, when I did finally get a chance to shop, I found two of the biggest bench vises I have personally ever seen. One seller was away from his booth, so I don't know his price. But his anvils in that same booth were priced...and they were out of my reach. So I ASSUME that vise is too high for me. (pics of that vise tomorrow night. I'm outta time now.)
However his neighbor had a really big vise for sale for sale too (nearly as big as that first one), and I need advice from our GJ vise gurus on this one, please. The seller is leaving at noon tomorrow, and I will probably pass on this cool vise, unless you folks tell me it's worth snagging.
This one is a MASSEY brand vise...not a name I was familiar with. (Do you guys know that brand?)
It is really, really big. Look at the 2nd photo, below, with my glasses resting on the slide for size comparison... This is a BIG honker, in my opinion! It must weigh nearly a hundred pounds, and the jaws are either 7 or 8 inches wide.
Note, however, that the handle appears to be nothing more than a really big bolt.
Below is a pic of the side with the mfr name cast into the side:
The shot below shows you my concern, and demonstrates my dilemmna, with which I need your assistance, please. The vise is obviously repainted, and the dynamic jaw has obviously been welded on top. I scrutinized the sides and bottom of the dynamic jaw carefully, and found no evidence that the jaw had cracked all the way through. But I'll bet that the jaw insert has been welded in place, and then ground smooth. You can clearly see grinder marks on it, and I see where "bubbles" in the welds are still visible. I'll bet that someone tried to weld that insert to the jaw, without using the correct rod/alloy, and had trouble doing it. ALSO...there appears to be a tiny crack at the right side of the dynamic jaw...right where the weld-bead edge must have been. Can you see it in this photo? It's right where the dark red color of the vise meets the area where the light of the sky overhead adds a whitish tint to the red color...at the right edge. It MIGHT be only in the paint? If not, it may be because the cast iron was welded without the benefit of an oven to provide even heating and controlled cooling? Your opinions, please!
Below is a another angle view of that dynamic jaw.
This vise has no swivel base, and never did. You would need to notch the front edge of a bench to mount it. Also, note that the slide has many small dings in it, but nothing serious. And in the shot below, you can see his "asking" price of $225.
Ok, so as I said before, unless you folks tell me that the problems I've pointed out are likely no big deal, and unless this guy drops about $75 out of his price, I will pass on this vise tomorrow. (If all the above things DO happen, I will of course insist on scraping that red paint away so I can see beneath it. And the seller is a long-standing member of SOFA, attending every year, and offers to stand firmly behind this vise if it fails.)
But either way, I would really appreciate hearing your opinions about it. I would be lying if I said that I didn't think it is REALLY cool looking vise, and it is definitely the biggest one I've ever found offered for sale.
One more thing....below is a photo of that other, even-bigger vise. But it seems to be strange...and may be incomplete...maybe part of a machine or something? Note how the screw at rear is exposed, and too much of the vise seems to hang out in front of the bench-mount area...with not enough area visible to mount it. So I ASSUME that it must be part of some kind of machine? Anyone know for sure?
Once again, thanks SO MUCH to the smart vise folks of Garage Journal!
I really appreciate you all.
