LUXAIRE furnace problem
pudgybear
Brooklyn Michigan
I have an LUXAIRE attic forced air furnace, last night it appeared cold in the living room area, after checking the thermostat i realized the furnace had not come on according to the thermostat, it is normally set for 68 degrees and the room was now 62, i went up into the attic and removed the side panel and the red light on the circuit board was blinking ( 7 times ) i turned off the power switch - checked all the wires for loose connections all appeared to be ok, turned the switch back ON and the furnace started right up,,,, any ideas i can check out?????? LUXAIRE Model G9T06012DHB13D
