white91formula
Hi guys. I recently had my water heater go and flooded my finished/carpeted basement. As a result the carpets were removed. The wife wants to do the luxury vinyl plank flooring instead of replacing the carpet. We are looking at the 100% waterproof ones that do NOT have the MDF/fiberboard backing. We live in central new england, have a walk out basement and dont get a lot of moisture down there and live on a hill so flooding isnt a concern.
We would be taking the tile section out shown, and one other not seen in the picture.
A few questions for you guys on that.
* The concrete slab has some variation wtih high spots and low spots. How do i determine if it is good enough or needs to be leveled.
* The concrete is painted in the room pictured and has carpet glue in the far room. Do these need to be stripped to put leveler down or can i go over them ?
*I dont want transitions between spaces, main room to the back room pictured. Once i get into that room, can the planks be clicked/snapped together in reverse to back fill that room ?
* Does anyone have experience with this in their basement ? Its marketed at below grade and good for basements. I talked to one flooring contractor and he basically called me stupid and said he wouldn't even quote putting it in because its only going to results in lots of mold under it and even with a vapor barrier there would be "rubbing" between the floor, barrier and concrete over time putting holes in the barrier causing moisture to come up and mold.
Thoughts ?
Thoughts ?
