LVLP gun vs Rattle Can
guy2600
Northeast
I have some motorcycle fiberglass bodywork that I need to paint. Know next to nothing about painting though I am mechanically inclined with patience. It's race bodywork so it doesn't need to be perfect, but hoping for decent. I would more than likely clear coat it. If both options were done with the same prep work, is there a reasonable difference in outcome between rattle can and a LVLP approach? I would source all supplies from a local automotive paint supply store. The compressor I would buy would be a 20 gallon 6.5cfm@40psi. A more powerful compressor is not an option, unfortunately. I would get a sprayit SP-33000 LVLP gun (seems to have decent reviews). Thoughts? Not sure if investing in a compressor and gun would produce better results.
Mandres
The results aren't different enough to justify the cost of all the equipment if you don't have a compressor. For race bodywork a spray can will work fine. You can get catalyzed clear coat in a rattle can nowadays too.
d.mcfarland
Western PA
Spraymax 2k clear coat in rattle cans works fantastic. Coverage isn't as much as you would hope, but price isn't terrible. $21 a can or so.
rust in the eye
Chicagoland
I've seen nice results with rattle cans on smaller items like motorcycle bits. A friend did a fade job on his motorcycle with rattle cans that got lots of compliments and raised eyebrows when he told them it was done with rattle cans.
Nessism
Torrance, CA
I'm a big fan of automotive grade paint and a spray gun over rattle can. It's sort of like the difference between sandblasting to clean parts, vs. using a wire wheel. Unfortunately, automotive paint is quite expensive these days. And even the smaller quantities are typically more paint than most people need for one project.
lilredex
Toronto
A couple of my rattle can projects.
MileHighRover
This was a rattle can job using cans from the local auto supply store and 2k clear. I was very happy with the results. For your smaller project, that's the route I'd go.
P0234
NoVA
Fancy paint jobs on race bikes are a magnet for wrecks. Plus you can get great results with a spray can. The hardest thing is keeping dust/dirt from messing up the paint, otherwise they can lay down really flat paint with a little practice.
