M12 Must have tools?
Yankeefarmer
Connecticut
Reading through this thread, it becomes obvious that different people have vastly different uses and expectations for these tools. One of my favorites and most frequently used is the Fuel cut off tool. Yes, it’s protective logic stops it if you load it up too much, and it can drain a battery quickly, but it’s reversibility let’s me always direct the sparks/chips in an appropriate direction, and I’m mostly using it on Small diameter fasteners, rods, or short cuts in sheet metal that is too thick for snips or my small shear.
For me, the M12 line is great for its compact size, light weight, and plentiful power for small, quick jobs where I’d spend more time setting up and stowing an extension cord or air line than actually running the tool. If long run times are involved, I already own powerful corded or pneumatic tools to get the job done without trying to replace those tools with cordless.
Received a few new M12 4.0 batteries for Christmas. I currently have a 3/8 ratchet, a basic drill, the right angle die grinder, and the inflator. Bought the ratchet years ago with the drill, so both are non fuel.
I like M12 for light jobs. I also have a non-Fuel 3/8 drill. Perfect for drilling a few smaller holes. Keep it !
My M12 right angle grinder is my new "go to" tool ! Make sure you have a good supply of all the different attachments for it (Rolloc Scotch-Brite disks, carbide burrs, wood/plastic burrs, etc.). I even have a 1/8" collet for it !
My second M12 "go to" tool is the Rotary Tool. Replaced my Dremel.
I have an M12 3/8" impact (perfect for small engines). It gets used a lot with a 3/8" to 1/4" hex adapter for Phillips screws.
mepstein
How’s the power compared to pneumatic? How much runtime do you get out of a battery? I’m guessing multiple batteries to get a quarter panel off, right?
I actually bought it for the metal guy at my shop. He liked it right away. We have lots of batteries so being cordless was a bigger deal than run time. Not having a cord in cramped quarters is great. We don’t have a pneumatic version so I can’t give you apple to apples.
GeoBruin
I'm not exaggerating when I say I own every m12 tool mentioned in this thread so far (and then some).
Standouts for me are the stick pump, rocket light, band saws (both of them), RA die grinder, and few that I don't think have been mentioned: the stapler, jobsite blower, and the nibbler.
Turds are the right angle drill and the (non-brushless) rotary tool.
Multi-tool is a meh.
Everything else is serviceable.
SRU1436
Bay Area, CA
I was just looking at the Milwaukee Tools website, and I had forgotten about the M12 band file, did that turn out to be a good tool, or will it leave me disappointed like the die grinder does?
I have this tool and it’s handy for so many things. So far I haven’t seen it for sale very often, but still a great tool. Worth the price for me.
Aileron
outside
M12 sprayer. The m18 has a history of tanks leaking. I bought the m12 and although not a back pack, its worked great. I bought it on a HD special with 2- 2 gallon tanks.
AEAdam
SE PA
My only 2 M12 tools are the stapler and the PEX tool. Both pretty awesome. Like to get the caulk gun.
Southernbuild
North MS
I've had great luck with a ton of M12 tools, with two exceptions.
- The non fuel jigsaw is terrible. I threw it away, rather than subjecting anyone else to it.
- This is more subjective, but I'm not fond of the non fuel oscillating tool. A hex key is required to change the blade, and speed is adjusted via a thumb wheel, instead of a varable trigger. DeWalt has me spoilt on that feature.
In short, the lineup is perfect for most of my uses, and I'll continue to expand my lineup.
Black300zx
Elkton, Md
Agreed on the jigsaw. I got it because I needed to do a bunch of rough-cutting before routing the material to a template. Got the job done, but WOOF was it incredibly mediocre
tarmy
Nor Cal
I was putting in a few thousand feet of Joint trench and decided to by the M12 conduit cutter. That was the best tool for the job I have ever purchased. My hands would have been destroyed doing the cuts with a manual cutter.
I have a lot of M18 and various M12….but that is the best task specific tool I own for an M12.
setfocus
rust belt
Most used for me would be a toss up between the older fuel impact driver (non-surge) 2553 and the 3/8 stubby impact for automotive work
Also have the fuel hammer drill and high speed ratchets in 1/4 and 3/8 at work. Next purchase would probably be a 1/4 long neck ratchet
At home I've only got the tower light for M12, long run time with 6.0 batts. Was great for a half a week power outage last winter after an ice storm
whateg01
doo dah, kansas, usa
- This is more subjective, but I'm not fond of the non fuel oscillating tool. A hex key is required to change the blade, and speed is adjusted via a thumb wheel, instead of a varable trigger. ...
I have mixed feelings about the knob thing. The way you described it, maybe it's different than I'm thinking. My old old craftsman jigsaw, a rebadged DeWalt, had a knob that limited the max speed. It still had a variable trigger. When cutting metal, it was nice to be able to set the max speed and then just pull the trigger to the stop. With my new 20v DeWalt jigsaw, I find it harder to maintain the slower speed. I don't have the m12 oscillating tool, so maybe its function is different.
tak1313
I got the M12 inflator to replace my old Ryobi one, and it has been great for me, but I just have a Prius and Tacoma to take care of, and occasionally my daughter's Civic, so can't make a comment about any heavy duty use.
I have both the Fuel and non-Fuel 3/8 ratchet, but for some reason (I don't know why), I grab the non-fuel first.
I have both M18 impact wrenches and the M12 stubby. I always grab the M12 first unless it can't handle the job - so much lighter and easier to handle, and gets most things done (though as stated, I'm not a pro (my wife says so too...)).
Although I have the 15ga and 21 deg framing M18, I also have the M12 pin nailer, and it works better than any of my pneumatic pin nailers.
I also tend to use my M12 impact DRIVER more than my M18 (for the same reasons as the impact wrench).
I have the M18 drill, but not the M12, so can't compare. If I did have it, I would likely use that more often too (see impact wrench and driver reasons). I DO have the quirky "installation Driver" (2505-20) but I actually use my "regular" drill and/or driver more often. I got the installation driver more for the different heads in case it's needed. It's supposed to be a great tool though (other than the weird handle setup), and I've had no issues when I have used it.
I also have the M12 right angle die grinder, and it's true what people say about the lack of power/cutting out if too much pressure is applied, but I've only used it a few times, and mostly use it for Roloc stuff on hubs and brakes. I wouldn't buy it again. In fact when I decided to get a cutoff tool, I just went with the Ryobi because I read that the cutoff off tool has similar limitations.
The M12 palm nailer works great - better than any of my pneumatic palm nailers, but it's bulky as h*ll and heavy (compared to pneumatic).
Other M12 that I have but have not used enough (or not even used yet), so can't comment - right angle non-fuel drill, Fuel mini reciprocating saw, ProPex expander tool.
sparky 1971
Central Iowa
There should also be a list of "don't waste your money" tools. I am going to nominate the M12 dust buster type vacuum to be at the top of the list. I had one for all of about 15 minutes before I gave up and tossed it in the dumpster. Even though I don't have any experience with it, the M12 right angle drill should probably be on it as well. I have the M18 and it is the most gutless drill I've ever used, the M12 can only be worse.
Blackbyrd
TN
I hate the stupid squeeze things that never work. The M12 caulk gun has changed my life.
Oh I forgot about that one!! It's great!!! I got for automotive seam sealer, but used it with caulk also. It seems stupid but man it's so nice
whateg01
I have a DeWalt 20v I bought after watching the Safelite guy replace the back window in my srx. It is so nice for long continuous rubs of stuff from a tube. I only wish they were slightly less bulky.
drmarkr
Tucson
Well....I didn't have the transfer pump, the die grinder or the caulk gun, but damn you guys for me heading to CPO or Amazon to grab them right now!
As for favorites, the soldering tool is awesome - instant heat. The cutoff wheel, after you learn its torque limits, is amazingly easy to use (size/weight), the Fuel 3/8 ratchet is way faster than the regular so spend the $$ to get it, and the hackzall of course. The ProPex is pricey as hell, but is a godsend on a big job (I didn't buy this one....I borrow it from a buddy). I have a several M18's also, but the main one of those I use is the 1/2" impact.
GrayFlattop
Chicago
The inflator is awesome even if it seems slow. My service truck rear tires are supposed to be 80 psi, I don't remember the size but the standard 3/4 ton 16" wheels. I picked up a nail on a jobsite and by the time I noticed and got a plug in it, I was down to about 20 psi. It took everything a 3.0 battery had and about 15 minutes, but it aired it back to the 80 it was supposed to be.
I’d agree with your assessment- the m12 inflator is great, but can seem slow, but you just screw the hose on the Schrader valve and do something else while you wait a few minutes since it shuts off once you reach your set point. If you consider the time for your stationary compressor to get up to pressure, it’s fine.
I did get the M18 inflator a few months ago as part of a bundle. It’s faster and is probably butter suited if you have truck tires that require higher inflation pressures, but for standard car tires 35-40 psi, I don’t think the M18 version is needed.
whateg01
My compressor is always ready to fill something with air. But this is easier.
Your statement on the M18 supports my notion that one day I may spring for the DeWalt 20v inflator. For now this does the job and is smaller.
mepstein
Another nod to the stapler, it's great. My only turd has been the circ saw, the smallest amount of deflection instantly drains my largest batteries.
I have the m12 circ saw. I bought it specifically to cut vinyl siding. I keep the blade turned backwards and it works great. It’s never touched a 2x4. Just a one purpose tool that does its job - for me.
Yankeefarmer
Connecticut
I’m a big fan of the M12 circular saw. Used it earlier this year to shorten and chamfer some 4x4 posts, then later to shorten a bunch of bed slats for my brother-in-law who’s toolless. Again, a bunch of quick little jobs.
T
tyyost
Tunkhannock, PA
I’m in the same boat, may keep the M18 inflator on my good deal list. The caulking gun that keeps coming up is a great suggestion. I always forget such things exist and squeeze my way through jobs. The stapler is one I have seen before but forgot as well. May have an insulation job coming up where it would be a godsend.
bcradio
New Mexico
I would definitely step up to the Fuel version for the circ saw. they work great
As mentioned before, I have non-Fuel M12 3/8" drill. Yes, it has lower power. Yes, it will not drill a zillion holes. I knew that going in.
Beemer
Northeast
I like my M12 compact impact gun and various drills/drivers but hate the 5 3/8" circular saw that is gutless.
drboom
The caulk gun is great. However, one must be careful with it as it will easily blow out the caulk tub and it's not fun to clean up after. I wish I could say that I've only done that once.
whateg01
After I bought me yellow one, I hadn't had a chance to use it when my daughter and her bf were recaulking their tub. So they borrowed it. I don't think either had ever used a caulking gun before at all. And they forgot to poke a hole in the foil. And they made a huge mess of things. Thankfully, they were able to clean it all up. And they learned a lesson.
manwithtools
Lebanon, TN
Any circular saw, regardless of the blade size or power source, is **** without a carbide blade !
Do you seriously know of any circular saw today that comes without a carbide blade? I'm not sure where I'd even look to buy a non-carbide circular saw blade if I wanted one? :twak:
