MAC 1/4" drive ratchet problem
Joelfke
Mt Holly, NJ
I got a MAC 1/4" drive ratchet from an old mechanic CHEAP because he said it doesnt work. When i use it, it slips, like the gears are chewed up. Is there a kit I can buy to rebuild the ratchet gears? If so, where?
35mastr
Norcal
The drive gear or the pawl is stripped?
Got a pic?
Whats the number on the ratchet?
Paladin
Southern Utah
I take it you haven't opened it up to inspect the internals? It's likely there is nothing wrong other than dried up grease, gunk, etc.. causing the problem. ALMOST every "broken" ratchet I've bought for dirt cheap only needed a good cleaning and some fresh lube. :thumbup:
HandyManny
Out West
If it's slipping then there is likely something other than just dired up dirt and grease causing the problem. More like stripped gears. Take it apart and look.
35mastr
Norcal
There is going to be teeth missing off the main gear and they will be there for you to see.
This happens to these all the time.The problem with them is that the 2 screws that hold the bottom plate to the head become loose.
As you torque on the handle it causes the drive gear to lift to one side at the pawl.It just takes off a couple of splines and your done.Make sure to wash all that out with brake cleaner after its apart.If you miss any of them.They will wipe out you main gear immidiatley.
Best fix is when you rebuild it.Put some blue Loctite on the screws and you wont have this issue.
J
Joelfke
Mt Holly, NJ
thanks for the replies...
it looks like it is greased too much...i havent opened it yet
J
Joelfke
Mt Holly, NJ
i took it apart but the teeth seem to be intact...since its a 1/4" drive everything is very small....should i clean it out? what kind of lubricant should I put in it after cleaning?
Paladin
Southern Utah
I always spray out the inside and gear with WD or brake cleaner. Then use a light grease (I use assembly lube) or oil and put it back together. I'm curious to find out. It's entirely possible that it's stripped, but I almost always find cleaning and lubing fixes the problems. Just my humble opinion...
J
Joelfke
Mt Holly, NJ
the gears dont appear to be missing or broken...maybe worn but id have to see a brand new one to see the difference...
64merc
Texas
Interesting....the pawl and gear don't look stripped to me. The pawl looks a little worn, but it doesn't appear to be enough to cause a problem IMO. Maybe the slight wear, combined with poor fit causes a problem.
forceyoda
The rebuild kit has the pawl, gear, spring, bolts. detent ball, and plate-everything but the chrome handle. And its FREE, just call MAC and it will be on it's way. I rebuilt 6 ratchets last year and they were all FREE no questions asked.
PowderKeg
Little Rock, AR
Is that the Mac version of the Big Dawg? Looks like an awful lot of teeth - what was the count for a 1/4" Big Dawg? @50? Wonder if a rebuild kit is still available? And I don't know that I'd use the Red Lube O' Luv in that one - doesn't always mix well with high tooth-count ratchets. 3'n1 oil oughta work fine.
J
Joelfke
Mt Holly, NJ
im not sure how many teeth...they are way too small to count for my old eyes haha (im 22) ill call/email MAC tomarrow probrably...thanks for all your help guys
jerk_chicken
Germany
For lube, gear oil with a VERY small film of moly grease is my choice. I've tried slick-type (as opposed to sticky) teflon greases and they worked well, too.
jdcompman
South Dakota
In that first picture it looks like the Pawl teeth are in great shape but if you look at the picture of the teeth on the drive head they all look like the have no point left on them. Every tooth appears to be flat on the edge.
Merkava_4
Clovis, CA.
Fast Orange and a tooth brush for that handle - then go Fast Orange and an acid brush for inside the head. Rinse thoroughly with water.
PS. MAC says that ratchet has 53 teeth.
cruiser808
Hawaii
That's kinda the way they're made. This is Mac's version of the Proto Big Dawg and the gear/pawl design functions differently than a conventional 24 to 36 tooth style. I'll bet a good clean up is all it needs. :beer:
J
Joelfke
Mt Holly, NJ
sadly..i tried the above to clean out the ratchet and lube it up but it still slips. I tried tightening the outside screws, still slips...ill request a rebuild kit (hopefully available) and Ill just rebuild it. im studying for GMASEP (assuming theyre still gonna be around) so this will be a good beginning ratchet assuming i can repair it
wrenchr
Use brake cleaner and be done!!
Paladin
Southern Utah
Well damn! At least it was worth a try!
Merkava_4
Clovis, CA.
wrenchr
Messy but it's VERY effective - like a dedicated ******. :)
:shocking::shocking::shocking::shocking: Not suprised though.
Ah but the fast orange makes for a nice bonding session between you and the tool - not to mention the wonderful aroma. :)
Dude.....that takes all the fun out of it. :)
:headscrat:headscrat
J
Joelfke
Mt Holly, NJ
UPDATE:
Thanks for everyones assistance. I tried lubing it up but unfortunately it didnt help. So i emailed MAC and they said they didnt make rebuild kits anymore so I sent it back to MAC and they sent me this brand new ratchet! :)
[/IMG]
[/IMG]
