Mmfh
MEMBER EMERITUS
Hey there,
I'm having a problem with my automotive surface grinder, high speed for the cutter head is not working properly. This is a two speed cutter head and has a switch on the console for low, neutral, and high.
When you turn it to the high position it just growls and grumbles, and tries to turn but very slowly. I turn it off quickly as it sounds very wrong.
This is 220v 3 phase, I'm making the 3 phase with a Rotary Phase Converter, 25hp idler motor. Tested voltage and between the legs I have 212v. 214, 237v.
That's measuring between 1 and 2, 2 and 3, and 3 and 1.
I don't see what changes the speeds for this 6hp motor, its something in the console, but the console is full of contactors and relays and just basically crammed full of stuff.
What would you check first to see what's going on with this high speed problem? I just don't know what to look for, low voltage controller?
Any help would be great!
Thanks
Mm
Thanks
Mm
