Machinery & Equipment Catalogs
twertsy
Reedville, VA
Folks,
Yesterday I began inventory operations on my catalog hoard. For the vast majority of the catalogs, I have no use for them. That said, if anybody out there has relevant equipment, I want them to find a needed/wanted home. So, they are yours for the asking, just pay for the envelope. This task will take a long time but I'll use this thread to document the inventory. The boxes are all out of order, but I'll update the appropriate posts as I find stuff.
LINES IN RED TEXT HAVE BEEN ADDED SINCE THE INTITIAL LISTING
If you see something you want, contact me at [email protected]
Format of all listings is: MEDIA TYPE/COMPANY/PRODUCTS/YEAR
Company names starting with A:
Catalog/AAA Performance Tool/SPI Products, Baiter Files/1970
Brochure/A.-B. Industrimaskiner/Type AS 25 Electric Drill Press/1954
Brochures/A. L. C. Co./Sandblasters/1973
Catalog/J. S. Aber & Co., Inc. (Distributor)/1956 **Contains the Following**
- APPCO Hydraulic Power Check
- A. K. Allen Co. AllenAir Cylinders
- Husky Air Devices "Husky Pups" Air Cylinders
- Dukes Hydraulic Oil Valves
- A. K. Allen Co. Valves
- Marsh Needle Valves
- Humphrey 3-way Valves
- Pheu-Trol Valves
- Hush-Sheperd Co. Valves
- Versa Products Co. Versa Valves
- Tru-Flate Co. Couplers
- Le-Hi Champ Hydraulic Hose Assemblies
- Generant Regulators & Lubricators
- Lincoln Engineering Co. Multi-Luber Lubricator
- A. K. Allen Co. Dial Feed Table & Indexing Fixture
- Genesee Machine Builders Inc. Pumping Unit
- K. R. Wilson Hand Operated Hydraulic Pumps
- Keystone Compressor Co. Air Compressors
- Standard Instrument Co. Photo Electric Control
- Micro-Switch Precision Switches
- Electro-Snap Switch & Mfg. Co. Impulse Switches
- Automatic Timing & Controls, Inc. Automatic Control Systems & Components
Catalog/Aber Engineering Works, Inc./Curved Tooth Milling Cutters/1959
Catalog/Aber Engineering Works, Inc./Curved Tooth Milling Cutters/1952
Catalog/Aber Engineering Works, Inc./Curved Tooth Milling Cutters/1954
Catalog/Accurate Busing Co./Bushings/1947
Price List/Accurate Gear Works/Gears/1957
Catalog/Accurate Steel Rule Die Mfg. Inc./Dies/UNK
Bulletin/Ace Drill Bushing Co./Drill Bushings/1951
Catalog/Ace Drill Bushing Co./Drill Bushings/1954
Catalog/Ace Drill Bushing Co./Drill Bushings/1956
Catalog/Ace Drill Corp./Drill Bits/1952 TAKEN-Glen
Engineering Catalog/ACME Industrial Co./A.S.A & ACME ID's From No. 80 to 2"/UNK (Pre-1963)
Measurement Cards/Acme Industrial Co./Bushing Charts/1940
Catalog/Acme Industrial Co./Drill Jig Bushings/1950
Catalog/Acme Industrial Co./Drill Jig Bushings/1957
Catalog/Acme Industrial Co./Drill Jig Bushings/1963
Catalog/Acme Industrial Co./Piercing Punches & Die Bushings/1961
Brochure/Acme Steel Co. - Dexion Div./Slotted Angle Iron, Panels, Casters/1955
Catalog No. 44/Acme Tool Co./Tooling, Chucks, Flexible Shafts, etc./1944 TAKEN-Glen
Catalog/Acme Wire & Iron Works/Woven Wire Mesh and Steel Products/1948
Distributor Catalog/Acorn Industrial Products/Everede, Standard Parts Co., Huron Machine Products Co./1962
Brochure/ACRO Metal Stamping Co./ACRIFlex Steel Strapping/1957
Catalog/Addison Products Co./WeatherKing Oil Furnaces/1968
Brochure/Advance Car Mover Co./Porter Spring Winder & Spring Winding Tools/1981 TAKEN - Tom
Catalog/Aget Mfg. Co./Filters, Hoods, Piping for Dust Control Systems/1950
Brochure/Aget Mfg. Co./Filters, Hoods, Piping for Dust Control Systems/1957
Specifications & Drawings/Aget Mfg. Co./Dusktop Dust Control Hoods/1953
Catalog 52/Air-Mite Industrial Air Equipment Inc./Air Arbor Presses & Cylinders/1952?
Brochure/Air Conversion Research Corp (ACRO)/Coolant and Spray Systems/1954
Catalog/Aircraft-Marine Products Inc./A-MP Solderless Electrical Connectors/1953
Catalog/ALCO Tool Co./Tap & Drill Holders, Drill Chucks, Cut-Off Tools, etc./1950 TAKEN-Glen
Catalog/Alemite Div. - Stewart-Warner/Paint Spray Equipment/1971
Brochure/Alina Corp./Knurl Cutters/1954
Catalog/Alina Corp./Precision Measuring Tools/1962 TAKEN - Mark
Brochures/Alina Corp./Comparators, Bore Gages, Dial Indicators/1958-62
Catalog/Alina Corp./Precision Measuring Tools/1960
Brochure/Allan Mfg. Co./"DU-ONA-Lathe" Vertical Rotary Lathe Attachment/1951
Catalog/Allegheny Ludlum Steel Corp./Composite Die Sections/1946 TAKEN - Mark
Price List/Allegheny Ludlum Steel Corp./Tool Bits/1950 TAKEN - Mark
Catalog/Allegheny Ludlum Steel Corp./Forgings, Die Sections, Tool Steels/1953 TAKEN - Mark
Manual/Allegheny Ludlum Steel Corp./Methods Manual for Carbide Metal Tools/1948 TAKEN - Mark
Brochure/Allen-Bradley Co./Solenoid Motor Control/1959?
Catalog/Allen Collet Mfg. Co. Inc./Screw Machine Tools, Parts & Accessories/1955
Catalog/Allen Mfg. Co./Hollow Screw Products/1939 TAKEN-Glen
Catalog/Allen Mfg. Co./Hex-Socket Screws/1950 TAKEN-Glen
Brochures/Allied Metal Hose Co./Allflex Hose & Connectors/1960
Brochure/Allied Products Corp. - Richard Brothers Div./Clinch Nuts/1953
Brochure/Allied Products Corp. - Richard Brothers Div./Flex Mount Retainers/1955
Brochure/Allied Tool Products Inc./Grooving Tool Holders/1967
Brochure/Allied Wheel Products Co./Wheels & Tires/1959
Brochure/Allison-Campbell Div. of American Chain & Cable Co./ACCO Wet Abrasive Cut-Off Machines/1960
Engineering Drawings/Allison Equipment Co./Burgmaster Model 2A Drilling & Tapping Machine/1954 TAKEN-Mike
Brochure/Allison Equipment Co./Burgmaster Model 2A Drilling & Tapping Machine/1952 TAKEN-Mike
Brochure/Allison Equipment Co./Burgmaster Model 2A Drilling & Tapping Machine/1953 TAKEN-Mike
Brochure/All Precision Engineering Ltd./Mocroball Height Gauge & Ball Comparator & Accessories/1958
Brochure/Aloris Tool Co. Inc./Quick Change Tool Post & Holders/1955 TAKEN-Glen
Catalog/Aloris Tool Co. Inc./Quick Change Tool Posts & Holders, Micro-Adjustable Boring Bars/1966 TAKEN-Glen
Catalog/Aloris Tool Co. Inc./Quick Change Tool Posts & Holders, Micro-Adjustable Boring Bars/UNK (Post-1963
Brochure/Alpha Metals, Inc./SweTite Paste Solder/1955
Brochure/ALSCO Co./Tool & Die Makers Springs/UNK (Pre-1963
Catalog/Theo. Alteneder & Sons/Precision Measuring Tools, Spacing Dividers, Triangles, T-Squares, etc./1965 TAKEN - Mark
Brochures/Alvin & Co./Drawing & Drafting Tools & Products/1954
Brochure/Alvin Products Inc./Lab-Metal & Lab-Solvent/1970
Data Sheets/Alvin Products Inc./Aluminum Lab Metal/1962
Catalog/Alvord-Polk Tool Co./Reamers, End Mills, Mandrels, Arbors, Milling Cutters, Counterbores/1960
Catalog/American Brass Co./Anaconda Hose & Fittings/1956 TAKEN-Glen
Specification/American Brass Co./Anaconda Alloys Composition & Physical Properties/1950 TAKEN-Glen
Catalog/American Brass Co./Anaconda Copper & Copper Alloys/1945 TAKEN-Glen
Brochure/American Cam Co./Standard Circular Form Tools for Brown & Sharpe Automatic Screw Machines/1954
Catalog/American Clamp Co./Jorgenson Pony Clamps/1969 TAKEN-Glen
Catalog/American Crayon Co./Markers for All Surfaces/1954
Brochure/American Drill Bushing Co./Lasosal A.S.A. Standard Drill Jig Bushings/1951
Brochure/American Drill Bushing Co./Lasosal A.S.A. Standard Drill Jig Bushings/1952
Brochure/American Drill Bushing Co./A.S.A. Standard Drill Jig Bushings/1953
Catalog/American Drill Bushing Co./Drill Jig Bushings/1960
Brochure/American Drill Bushing Co./Taper-Lok Drill Bushing Tips/1961
Catalog/American Drill Bushing Co./Drill Jig Bushings/1962
Catalog/American Machine & Foundry Co./Wahlstrom Chucks & Tapping Attachments/1953 TAKEN-Glen
Catalog/American Machine & Foundry Co./Wahlstrom Chucks & Tapping Attachments/1947
Brochures/American Positive Grip Vise Corp./Machinist Vise "Mechanical Octopus with Tentacles of Steel"/2 Brochures, 1955 and UNK (Earlier)
Brochure/American Pulley Co./Hand Trucks & Dolleys/1963
Catalog/American Pulley Co./Middleweight Materials Handling Equip. - battery powered Trucks, Lifts, etc./1960
Catalog/American Schiess Corp./Machine Tools/UNK
Report/American Screw Co./Metallurgical & Engineering Report on Stainless Steels for Cold Headed Fasteners/UNK
Brochure/American Standard Co./Sine Angle Wheel Dresser/1981
Catalog/B. C. Ames Co./Gauges & Dial Indicators/1952 TAKEN-Mike
Brochure/Anchor Chemical Co./Anchorlube SS Machining Fluid/UNK (Pre-1963)
Brochure/Anderson Brothers Mfg. Co./Hand Scrapers/1957 TAKEN-Mike
Brochure/Edward Andrews Tools & Machinery Co./Tooling/UNK
Price List/Edward Andrews Tools & Machinery Co./Tooling/1969
Brochure/Edward Andrews Tools & Machinery Co./Turret Lathe Tooling/1960
Catalog/Edward Andrews Tools & Machinery Co./Turret Lathe Tooling/1959
Data Sheets & Brochure/Anker-Holth Div - Wellman Engineering Co./Square Head Hydraulic Cylinders/1957
Angle Computer Co./Studler Angle Computer/1951
Brochure/Anker-Holth Div - Wellman Engineering Co./Power Cylinders, Air-Grip Chucks & Collets, Air Valves/1954
Catalog/Anton Machine Works/Blocks, Parallels, etc./1971
Brochure/Applied Mechanics Corp./Die Stock Pushers/1955
Brochure/Applied Mechanics Corp./Die Stock Pushers/1959
Catalog/Arboga Maskiner/Drilling Machines/1958 TAKEN - Tom
Instruction/M. Argueso & Co., Inc./Finishing an Outside Contour of a Fragile Conical Part/UNK
Catalog/Arkles/Steel Bins & Shelving/UNK
Brochure/Armstrong-Bray & Co./Gear & Wheel Pullers/1962 TAKEN-Glen
Catalog/Armstrong-Bray & Co./Gear & Wheel Pullers/1965 TAKEN-Glen
Brochure/Armstrong Brothers Tool Co./Armide Carbide Insert Tool Holders/1956
Catalog/Arnold Gauge Co./Continuous Grinding Gages/1963 TAKEN-Mike
Flier/ARO Equipment Corp./ARO-PAK Air-Primed Portable Farm Lubricator/1953
Brochure/ARO Equipment Corp./Air Tools/1953
Catalog/ARO Equipment Corp./Air Tools/1961
Product Catalog/Arter Grinding Machine Co./Model B Hydraulic Rotary Surface Grinder/1956
Catalog/Ash Precision Equipment Inc./All Brands of Precision Tools, Gauges, etc./1966 TAKEN-Glen
Catalog/Ash Precision Equipment Inc./All Brands of Precision Tools, Gauges, etc./1968 TAKEN-Glen
Catalog/Associated Spring Corp./Thick Catalog - All Conceivable Typed of Springs/1973
Catalog/Associated Spring Corp./SPEC Stock Springs, Spring Washers, Retaining Rings/1982
Catalog/E. C. Atkins & Co./Metal Cutting Saws/UNK
Brochure/Atlantic Engineering & Mfg. Co./Atlantic Radial Reliever/1955
Brochure/Atlas Press Co. - Clausing Div./Clausing Lathes & Mills/UNK TAKEN - Tom
Brochure/Atlas Press Co./Atlas & Clausing Lathes, Drills, Milling Machines, Shapers/UNK TAKEN - Tom
Catalog/ATRAX Co./Carbide Tools/1954
Catalog No. 13/Auburn Ball Bearing Co./Ball Thrust Bearings & Engineering Data/UNK (Pre-1963)
Brochure/Austin Industrial Co./SAJO & VMA Swedish Milling, Shaping & Sawing Machines/UNK
Brochure/Austin Tool Co. Inc. (Formerly SKEE Mfg. Co.)/Anthony Cutting Off Tools for Lathes/1960
Brochure/Austin Tool Co./Vibra/Damp System/UNK (Post-1963
Catalog/Automatic Machine & Tool Co./5 Station Lathe Turrets/1943
Letter & Response/Automatic Machining Mag./1956
Company names starting with B:
Product Brochure/B.S.A Tools Ltd./No.s 48, 68, 98L, 138L, 168L Automatic Screw Machines/1956
Price List/B&G Tool Corp./Cutting Tools/1969
Brochure/B & W Precision Products Co./Tools, Dies, Gages/1954 TAKEN - Mark
Catalog/Babcock & Wilcox Co./Croloy Tubular Products/1952
Catalog/Balas Collet Manufacturing Co./Collets/1952
Brochure/Bald Eagle Corporation/Sine Plates and Sine Bars/1960
Brochure/Bald Eagle Corp./Sine Plates & Tools/1957
Catalog/Bantam Bearings Corp./Ball & Roller Bearings/1942
Product Brochure/Baptist Machine Co./S22 Microfinish Comparator/UNK
Catalog/Barber-Colman Co./Milling Cutters/1957
Catalog/Barber-Colman Co./Small AC Motors/1959
Product Brochure/Barber-Colman Co./Oil Feed Reamers/1952
Product Brochure/Barco Machine Products Co./Micro-King Drill Mill/1947
Catalog (2)/Barco Mfg. Co./High Pressure Swivel Joints/1954
Brochure/Barco Scraping Company/Accuracy Equipment (surface plates, straight edges, etc.)/1950
Catalog/Barden Corporation/Precision Ball Bearings/1953
Product Brochure/Barker Engineering Co./Bench Mill/1953
Brochure/Barker Engineering Co./Barker Model A-M Mill/1956
Catalog/Barnaby Manufacturing Co./Screw Machine Tools/1952
Brochure/Barnes Industries, Inc./Ball Screw Reconditioning Service/UNK (1980s?)Product Brochure/Barnor Products Co./Roberts Electrical Tube Caliper/UNK
Product Brochure/Baron Industries/Baronet Barrel Degreaser Model SBD-G/UNK
Catalog/Barry Air Tool Sales/All Brands of Air Tools/1966
Product Brochure/Bartelt Engineering Co./Pedestal Micrometers & Indicators/1950
Price List/John Bath & Co./Taps/UNK
Catalog/John Bath & Co./Reversible Plug Thread Gages/1954
Catalog/Bay State Abrasive Products Co./Abrasives/1952
Brochure/Beacon Brush Co./Oiler Brushes/1956
Catalog & Engineering Data/Bearings Company of America/Ball Bearings/1939
Catalog/Bearings Inc./Bunting Bearings/1952
Catalog/Andre Bechler Ltd./Automatic Bar Machines/1954
Product Brochure/BECO/Super-Lift Lever Dollies/1960
Bulletin/Beleden Mfg. Co./Portable Cord - Selecting the correct electrical cord/1944 TAKEN - Tom
Catalog/Bellows Co./Controlled-Air-Power Devices/1950 TAKEN - Ben
Catalog/Bellows Co./Drill Press Feeds/1955 TAKEN - Ben
Catalog/Belmont Packing & Rubber Co./"Ajax" Spiral Wound Gaskets/1960
Catalog/Beloit Tool Corp./Regal Taps & Drills/1963
Catalog/Beloit Tool Corp./Regal Taps/1963
Catalog No. 59/Benco Collet Manufacturing Co./Collets/1959?
Brochure/Benco Collet Mfg. Co./Master Pusher Kits/1947?
Product Brochure/Bernard Welding Equipment Co./Pro-Clamp/1950
Product Brochure/Charles H. Besley & Co./Disc Grinders/1946
Brochure/Besley-Welles Corp./Double Horizontal Disc Grinders/UNK
Catalog/Besly-Welles Corp/High Speed Steel Taps/1966
Catalog/Besly-Welles Corp/Chuck and Collets/UNK
Catalog/Besly-Welles Corp./"Modern Magic" Chucks & Collets/1962
Product Brochure/Besly-Welles Corp./Modern Magic Chucks & Collets/1970
Catalog/Black Drill Co./Drills/1960
Brochure/Besly-Welles Corp./X-Press Taps/1957
Catalog/Black & Decker Mfg. Co./Power Tools/1960 TAKEN-Glen
Catalog/Black & Decker Mfg. Co./Power Tools & Machines/1966 TAKEN - Mark
Catalog/Black & Decker Mfg. Co./Industrial Power Tools/1979 TAKEN - Mark
Brochure/Black & Decker Mfg. Co./Twiston Hole Saws/1964
Catalog/Black Drill Co./Drills/UNK
Catalog/Black & Webster, Inc./All Electric Impact Tools/1955
Product Brochure/Edward Blake Co./Blake Flute Grinder (for Taps)/UNK
Catalog/Bodine Electric Company/Adjustable Speed Torque Drive Systems/UNK (post '63)
Brochures/Bokum Tool Co./Precision Cutting Accessories/1955
Brochures/Bokum Tool Co./High Speed Tools/1954
Catalog/Bokum Tool Co./Internal Cutting Tools/1946
Brochure/Bokum Tool Co./Spotfacing & Boring Tools/UNK
Catalog/Charles Bond Co./Gears, Couplings, U Joints, etc./1957
Catalog/Bondhus Corp./Industrial Products/1981
Product Brochure/Bonk Machine Works/Viking Speed Mill/UNK
Booklet/Borel & Dunner (Distributor)/Parvus-Compac Indicators/1957
Product Brochure/Boyar-Shultz Corp./Surface Grinders/1953
Product Brochure/Boyar-Schultz/Model 6-18 Challenger Surface Grinder/1957
Product Brochures/Boyar-Schultz/T-Slot Bolts & Surface Grinders/1956
Brochure (2)/Boyar-Shultz/Copper Head Laps/1955
Product Brochure/Branch Manufacturing Co./Tap Guide, Tap Chuck, Auto Stop/1954
Brochure (2)/Breeze Corp./Aero-Seal Worm Drive Hose Clamps/1954
Brochure/Brewer Machine & Gear Co./Universal Drive Tensioner/1961
Catalog/Bridgeport Machines, Inc./High Speed Milling Attachments/1946
Product Specifications/Bridgeport Machines, Inc./Turret Milling Machine with Model J (1 H.P.) Head/1954
Brochure/Z. Brierley Inc./Drill Grinder Machines/UNK
Price List/Z. Brierley Inc./Twist Drill Grinding Machines & Accessories/1971
Catalog/Briney Bushing Inc./Drill Jig Bushings & Liners/1967
Catalog/Briney Manufacturing Co./Precision Adjusting Tools/1961?
Specifications/Brook Motor Corp/Electric Motors/1955
Product Brochure/Brookfield Inc./Tool Holder/1959
Brochure/Brookfield Inc./Tool Holder/1953
Catalog/Brown Corp./Sewer & Perforated Pipe/1948
Catalog 36P/Brown & Sharpe Mfg. Co. - Hydraulics Div./Pumps/1959
Catalog/Brown & Sharpe Mfg. Co./Permanent Magnet Holding Tools/1952 TAKEN - Glen
Catalog/Brown & Sharpe/Cutting Tools/1981
Price List/Nelco Tool Co. Inc. - Subsidiary Brown & Sharpe Mfg. Co./Carbide Tools/1958
Catalog 35M/Brown & Sharpe Mfg. Co./Machinists' Tools/1952 TAKEN - Mark
Product Brochure/Brown & Sharpe Mfg. Co./Automatic Pinion Turning Machine/1952
Manual/Brown & Sharpe Mfg. Co./Dial Indicators/1972
Product Brochure/Brown-Brockmeyer Co./Drill Grinder/1954
Catalog/Browning Manufacturing Co./FHP Drives & Sheaves/1956 TAKEN-Glen
Catalog/Browning Manufacturing Co./Gears/1963
Catalog No. 42/Brunner Manufacturing Co./Refrigeration Condensing Units/1948
Catalog/Charles Brunning Co./Jig Transit & Optical Transit Square/UNK
Instructional Booklet/Brush Research Manufacturing Co./Cylinder Boring, Honing and Wall Finishing/1974
Catalog/Brush Research Corp. (BRM)/Industrial Brushes and Flex-Hone Tool/UNK (1980s)
Product Brochures/Buck Manufacturing Co./Mag Drills, Mag Plate Clamps/1955-57
Catalog/Buck Tool Company/Buck Adjust=Thru Chucks/1951 TAKEN-Glen
Catalog/Buck Tool Company/Buck Chucks/1959 TAKEN-Glen
Product Brochure/Buck Tool Co./Saber-Tooth Expanding Mandrels/1980
Sales Receipt, Drawing & Flyer/Bullard Company/Precision Aligning Level/1957
Catalog/Buckeye Fasteners, Inc. (Distributor)/Maclean-Fogg, Decker, Carr, PEM, Plastiglide, Ohio Fasteners/1972?
Flyer/Buol Machine Company/Rapid Cut Reamers/1954
Specs/Burg Tool Mfg. Co./Tool-Flex Floating Tool Holders/1951 TAKEN - Mike
Product Brochure/Burgmaster Corp./Auto Indexing Turret Drill & Tap Machine/1958 TAKEN - Mike
Product Brochure/Burgmaster Corp./Bench Model Turret Drilling Machine/1958 TAKEN - Mike
Product Brochure/Burgmaster Corp./No. 2, Model A, 6 Spindle/UNK (Pre-1963
Price Quote, schematic, spec./Burke Electric Company/Electric Parts for a Drill to be Manufactured/1940
Product Brochure/Burke Machine Tool Co./Burke Bench Millers/UNK (Pre '63) TAKEN-Glen
Product Brochure/J. S. Busch Co./Milwaukee Surface Plates & Box Parallels/1955 TAKEN - Mike
Price List/J. S. Busch Co./Surface Plates & Planes/1955 TAKEN - Mike
Spec. Sheet/Bussmann Mfg. Co./Fuses/1954
Bulletin/By-Buk Co./Spray Paint Masks/1955
Information Sheet/Byco Industries/Tap Bushings/1958
Brochure/Byco Industries/Tap Bushings/UNK
T
twertsy
Reedville, VA
Company names starting with C:
Catalog/CA Manufacturing Co. (Div of Technology West Inc.)/Turret Lathe Tools/1970
Bulletin/Cadillac Stamp Co./Stamps/1953
Catalog/Cambridge Wire Cloth Co./Gripper Woven Wire Slings/1959
Product Brochures/Campbell-Hausfeld Co./Air Compressors/1956
Product Brochures/Campbell-Hausfeld Co./Air Compressors/1963 TAKEN-Glen
Brochure/Campbell-Hausfeld Co./No. 628 Utility Tank/1956
Catalog/Carboloy (General Electric)/Cemented Carbides/1959
Catalog/Carboloy (General Electric)/General Catalog/1970
Catalog/Carboloy (General Electric)/Carb-O-Lock Tool Holders & Boring Bars/1962
Product Brochure/Carb-O-Grip/Chuck Jaw Grippers/1974
Booklet/Carborundum Co./Center Type Cylindrical Grinding/1952
Product Brochure/Cardinal Machine Co./Cardinal Type B Speed Vise/UNK (Pre-1963)
Product Brochure/Carlyle Johnson Machine Co./MAXITORQ Automatic Overload Release Clutch/1950?
Product Brochure/Carlyle Johnson Machine Co./MAXITORQ Ring Type Driving Cup & "Disc-Pac"/UNK
Catalog/Carmet (Allegheny Ludlum Industries)/Carbide Cutting Tools/1977
Catalog/Carr Lane Manufacturing Co./Component Parts of Jigs & Fixtures/1986
Catalog No. 7/Carr Lane Manufacturing Co./Component Parts of Jigs & Fixtures/1959
Catalog/Carrol Dividing Head Co./Dividing Heads/1953 TAKEN - Glen
Catalog/Carter Controls, Inc./Fluid Power Controls/1957
Instructional Booklet/Cerro De Pasco Corp/CERROMATRIX Method of Punch & Die Setting/1951
Instructional Book/Cerro De Pasco Copper Corp./Cerromatrix Manual/1939?
Instructional Booklet/Cerro De Pasco Copper Corp./How to Make Chuck Jaws/1948
Instructional Booklet/Cerro De Pasco Copper Corp./Mold Making with Cerro-Alloys/1948
Instructional Booklet/Cerro De Pasco Sales Corp/Bending Thin-Walled
Tubing, Moldings and Extruded Shapes/1949
Catalog/Chain Belt Co./Shafer - REX Self Aligning Roller Bearings/1962
Catalog/Challenge Machinery Co./Precision Surface Equipment/1969 TAKEN - Mike
Catalog & Instructional (feeds & speeds, etc.)/Chase Brass & Copper Co./Free-Cutting Brass-Bronze-Copper/Copyright 1944, 2nd printing 1952
Catalog/A. W. Chesterton Co./Chesterton Mechanical Packings and Seals/1960
Product Brochures/Chicago Drillette Corp./Jigs, Speed Changer, etc./1947
Flyer/Chicago Electric Tachonometer Co./Tachs/1946
Catalog No. 51/Chicago Latrobe/ Drills, Bits, Reamers, etc./1953 TAKEN-Glen
Product Brochure/Chicago Rawhide Manufacturing Co./Sirvene Way Wipers/1956
Brochure/Chicago Rawhide Mfg. Co./Sirvis Protective Boots & Covers (with sample)/1956
Catalog/Chicago Rawhide Manufacturing Co./Perfect Oil Seals/1957
Catalog/Chicago Rivet & Machine Co./Rivets and Riveting Machines/1954
Catalog/Chisholm-Moore Hoist Division/Hoists/1964
Catalog & Flyers/Chrystler Corp. - Amplex Div./Extreme Duty Oil Cushion Bearings/1940
Flyer/Cincinnati Bickford Tool Co./Super Service Radials/1955 TAKEN - Mike
Flyer/Cincinnati Bickford Tool Co./Aircraft Tools/UNK TAKEN - Mike
Flyers/Cincinnati Dust Master Co./Dust Collectors/1959
Catalog/Cincinnati Electrical Tool Co. - Div. of R. K. Le Blond Machine Tool Co./Electric Drills & Buffers/1950 TAKEN - Mike
Brochure/Cincinnati Lathe & Tool Co./Hydrashift/1959 TAKEN - Mike
Product Line Brochure/Cincinnati Lathe & Tool Co./18" Cincinnati Royal Drills/1959 TAKEN - Mike
Product Line Brochure/Cincinnati Lathe & Tool Co./Hydraguide Tracer Lathes/1957 TAKEN - Mike
Product Brochure/Cincinnati Lathe & Tool Co./16" & 24" Infispeed Sliding Head Drills/1957 TAKEN - Mike
Catalog/Cincinnati Milling Machine Co./Milling Machines/1943 TAKEN - Mike
Spec. Sheets/Cincinnati Milling Machine Co./No. 1 and No. 2 Radius Grinding Attachments/UNK
New Product Brochure/Cincinnati Milling Machine Co./Toolmaster Milling Machine/UNK TAKEN - Mike
Flyer/Circle Machine Co./Offset Boring Bars/UNK
Flyer/Circle Machine Co./Boring Bars/1962
Catalog/Circular Tool Co., Inc./Metal Cutting Saws/1955
Catalog/CJT Industries, Inc./Durapoint Cutting Tools/1973
Catalog/Robert H. Clark Co./Clark Cutters/1957
Flyer/Robert H. Clark Co./Clark Hole-Maker"/1954
Flyers/Clark-Cutler-McDermott Co./Vibration Control Products/1961
Catalog/Clark Door Company/Shop & Factory Doors/1960
Catalog 54/H. C. Clatfelter Co./Gages, Fixtures & Bushings/1953
Product Brochure/Clausing Div., Atlas Press Co./Lathes/UNK (1950s) TAKEN-Thomas
Product Brochure/Clausing Div., Atlas Press Co./Burnerd Precision Chucks/UNK TAKEN-Thomas
Product Brochure/Clausing Div., Atlas Press Co./Burnerd Precision Chucks/1960 TAKEN-Thomas
Product Brochure/Clausing Div., Atlas Press Co./Drill Presses/UNK (1950s) TAKEN-Thomas
Brochure/Clausing Div., Atlas Press Co./Burnerd Precision Chucks/1960? TAKEN-Thomas
Mailer/Clements Manufacturing Co./Cadillac Blowers & Vacs/1963
Catalog/Clements Manufacturing Co./Cadillac Blowers & Vacs/1960
Catalog/Clements Manufacturing Co./Cadillac Blowers & Vacs/1967
Product Brochure/Cleveland Automatic Machine Co./"Cleveland Automatic"/1954 TAKEN - Mike
Catalog No. 54/Cleveland Twist Drill Co./Drills/1950 TAKEN-Glen
Catalog/Climax Manufacturing Co./Climax Key Mill/1985
Brochure/Climax Manufacturing Co./Climax Key Mill/UNK (80's)
Bulletins/Climax Portable Machine Tools Co./Flange Facers/1987
Catalog/Cogsdill Tool Products Inc./Deburring & Chamfering Tools/1956 TAKEN-Glen
Catalog/Colex International, LTD/Machine Tool Accessories/1970
Catalog No. 37/Collis Company/Chucks & Tooling/1956 TAKEN-Glen
Newsletter/Colonial Broach Co./Multiple Spline Processing/UNK (1950s)
Flyer/Colonial Broach Co./Broaching Machines/UNK (Prob 1959)
Newsletter/Colonial Broach Co./The Future of Broaching/1953/4
Catalog No. 62/Colonial Broach Co./Broach Equipment & Tooling/Copyright 1932
Catalog/Columbus McKinnon Corp., Chain Div./Herc-Alloy Sling Chains/1961
Flyers/Comet Tool Co./Cutting, tapping, drilling, milling tools/1954
Catalogs/Commander Mfg. Co./Production Tools - Multiple Drilling Heads, etc./1952-63 (Multiple in Group)
Catalog/Commander Mfg. Co./Drill Heads/1967 TAKEN-Thomas
Product Brochure/Comtor Co./Comtorplug Expanding Plug Gage/1954
Product Brochure/Comtor Co./Comtorplug Expanding Plug Gage/1957
Product Brochure/Comtor Co./Comtorplug Expanding Plug Gage/1962
Catalog/Conical Tool Co./Cutting Tools/UNK
Catalog/Continental Diamond Fibre Co./Celoron Silent Gears/1946
Catalog/Continental Rubber Works/Mechanical & Automotive Rubber Products/1953
Brochure/Contour Sales Corp./Contour Markers/UNK (Mid 60's)
Bulletin/Corning Glass Works/Industrial Glass/1953
Brochure/Cox Mfg. Co./"Wondaire" Warm Air Heating/1968
Flyers/Arthur A. Crafts Co., Inc./Drills, bores, cutters, etc./UNK
Product Brochure/Arthur A. Crafts Co./"Layaway" Clamped-on Carbide Circular Form Tool/UNK
Catalog/Criterion Machine Works/Boring Heads, Bars, Tools/1954 TAKEN - Ben
Flyer/Crobalt, Inc./Cutting Tools/1951
Product Brochure/The Cross Co./The Cross Tool Control Unit/1955
Product Brochure/Crossley Machine & Tool Co., Inc./Sure-Grip Drill Vise & Maxi-Cut Drilling Head/UNK
Catalog/Crown Industrial Products Co./Industrial Aerosols/1969
Product Brochure/Crozier Machine Tool Co./Bushing & Bearing Extractor/UNK
Catalog/Crystal-X Corp./Plastics/1961
Product Brochure/Cullen Manufacturing Co./Erick Magna-Holder/1957
Catalog/Curtis Universal Joint Co./Universal Joints/1995
Product Brochure/Curtiss Engineering Co./Curtiss Adjustable Fixture/UNK
Price List/Cushman Industries/Manual and Power Chucks (Also multiple engineering diagrams of the use of the Chucks from the 1950s)/1975
Catalog/Cutler-Hammer, Inc./Appliance Switches/1947 TAKEN-Thomas
Flyers/KEO Cutters Inc./Cutters, Lathe Mandrils, etc./1956
Company names starting with D:
Catalog/Dake Engine Co./Dake Presses/1953 TAKEN - Glen
Catalog 129/Dake Engine Co./Hydraulic Presses/1953 TAKEN-Thomas
Catalog DA44/Dake Engine Co./Arbor Presses/1946 TAKEN-Thomas
Catalog/Dalton Gear Co./Overload Safety Devices, Torque Limiters, Couplings/Sprockets/1979?
Catalog/Dana Industrial - Formsprag Div./Over-Running Clutch Couplings/1980
Brochures/Danly Machine Specialties, Inc./Die Set Accessories/1954 & 1956
Catalog/Danly Machine Specialties, Inc./Precision Die Sets/1952
Catalog/Danly Machine Specialties, Inc./Tool-Gage Die Maker's Supplies/UNK (1940s?)
Brochure/Danly Machine Specialties, Inc./Die Springs/1951
Catalog/Danly Machine Specialties, Inc./Die Springs/1991
Story/Davis Boring Tool Div. - Larkin Packer Co./"The Story of Engineered Boring In Picture Form/UNK TAKEN - Mike
Bulletin No. 300/Davis Boring Tool Div. - Larkin Packer Co./Expanding Block Type Boring Tools/UNK TAKEN - Mike
Catalog/A. G. Davis Gage & Engineering Co./Standard Gage Units/UNK
Catalog/Davis Tool Co./"Incre-Mike" Micrometer-Adjustable, Cartridge-Type Boring Tools/1968
Catalog/Daystrom - Weston Instruments Div./Switchboard Instruments/1960
Brochure/Dayton Perforators Inc./"Fractional Plus" Punches & Insert Dies/1957
Brochure/Dayton Rogers Mfg. Co./Metal Stampings in Small Lots/1952
Brochure/Dayton Rogers Mfg. Co./Metal Stampings in Small Lots/UNK (Pre-1963)
Brochure/Dayton Rogers Mfg. Co./Metal Stampings in Small Lots/1948
Brochure/Dayton Rogers Mfg. Co./Precision Combination "Angle Plate - Holocator"/UNK (Pre-1963)
Catalog/Dean Brothers Pumps Inc./Centrifugal Pumps/1961
Brochure/J. W. Dearborn/Automatic Chucking & Indexing Fixture/UNK
Catalog/J. W. Dearborn/Chucking & Indexing Fixtures for Milling Machines & Drill Presses/UNK
Brochure/DeCastro & Assoc./Speedex Automatic Dial Index Feed/1952
Brochure/Decatur Engineering Co./Anchors for Machinery to Concrete/1973
Product Data/Friederich Deckel/Universal Tool Milling Machine Prices, Specs, Uses, etc./1951
Catalog/DeLaval Steam Turbine Co./Worm Gearing/1946
Data Sheets/DeLaval Steam Turbine Co./Data for Determining Stresses, Torques, Bending Moments & Deflecting in Steel Shafts/1945
Catalog & Operating Manual/Delta Equip. Co. - Rockwell Mfg. Co./Model 19-150 Air-Hydraulic Drill Unit/1951
Brochure/Deltronic Corp./Tenth Plug Gauges/UNK
Catalog/F. W. Derbyshire Inc./Precision Lathes, Micromills, Automatics for Instrument and Watchmaking/1956
Brochure/A. P. De Sanno & Son/"Radiac" Dry Cut-Off Machine/1957
Brochure/Detroit Ball Bearing Co./Spacer Bushings & Thrust Washers/1963
Brochure/Detroit Boring Bar Co./Boring Bars/1955
Catalog/Detroit Die Set Corp./Die Sets, Die Maker's Supplies/1951
Brochure/Detroit Milling Cutter Co./Futurmill Research Report/1954
Brochure/Detroit Milling Cutter Co./Furturblade Cutter/UNK
Brochure/Detroit Milling Cutter Co./Load Meter/1954
Catalog/Detroit Mold Engineering Co./Standard Mold Bases & Moldmakers' Supplies/1952
Catalog/Detroit Power Screwdriver Co./Power Screwdrivers/1946
Brochure/Detroit Reamer & Tool Co./Circularity-Grinding Attachment/1949
Brochure/Detroit Stamping Co. (De-Sta-Co.)/Toggle Clamps/1953
Brochure/Detroit Stamping Co. (De-Sta-Co.)/Fixture Framers/1955
Brochure/Detroit Stamping Co. (De-Sta-Co.)/Toggle Clamps/1957
Catalog/Detroit Stamping Co. (De-Sta-Co.)/Toggle Clamps/1968
Brochure/Detroit Stamping Co. (De-Sta-Co.)/Spacers, Collars, Feeler Stock/1955
Brochure/Detroit Stamping Co. (De-Sta-Co.)/Arbor Spacers & Shims/UNK
Brochure/Detroit Stamping Co. (De-Sta-Co.)/Concentric Precision Washers/1953
Catalog/Detroit Stamping Co. (De-Sta-Co.)/Toggle Clamps/1953Brochure/Detroit Stamping Co. (De-Sta-Co.)/Toggle Clamps/UNK
Brochure/Detroit Stamping Co. (De-Sta-Co.)/Toggle Clamps/1955
Brochure/Detroit Stamping Co. (De-Sta-Co.)/Arbor Spacers & Shims/1955
Brochure-Price List/De-Sta-Co Corp - Subsidiary of Dover Corp/Clamps/1963
Catalog/Detroit Tap & Tool Co./Taps, Gages, Thread milling Cutters/1966
Product Brochure/Devcon Corp./Plastic Steel/UNK
Thick Unopened Envelope/Devcon Corp./UNK/UNK
Catalog/Devcon Corp./Compounds for Maintenance Product Design & Fabrication/1968
Product Brochure/DeVilbiss Co./Multi-Mister Cooling & Lubricating/1959
Distributer Brochure/DeWitt Equipment Corp./DTC-Bernerd Rotary Milling Table, Chucks & Arbors/1962
Brochure/Di Machine Co./Diebel Hi-Production Presses/1952
Catalog/Diagrind, Inc./Carbide Mandrel - Internal Wheels/1977
Brochure/Diamond Tool Co./Diamond Tooling, Wheels, Dressers, etc./1980
Catalog/Diamond Tool Research Co./Diamond Wheels & Hones/1954
Catalog/Diamonite Products Div. - US Ceramic Tile Co./Machine Turning & Cutting Tools/1956
Brochure/DICO Co./Small Wheels & Tires/1959
Catalog/Die Supply Co./Die-Co Springs/1950
Catalog/Die Supply Co./Tool, Die, & Machine Shop Supplies/1950
Brochure/Dilley Mfg. Co./"Dilley" Magnetic Grip Machine Shields/UNK
Catalog/W. C. Dillon & Co., Inc./Pressure Gauges, Scales, Thermometers, "In-Range" Testers, Dynamometers, Hoist Overload Switches, etc./1953
Brochure/Dimension Products/TruGrip Tool Holders/1960
Product Brochure/Henry Disston & Sons, Inc./Disston-Mercury Gasoline Driven Chain Saw/1944
Brochure/Joseph Dixon Crucible Co./Graphite Plugs for Bearing Lubrication & Graphite Plungers/1941
Catalog/Joseph Dixon Crucible Co./Crucibles, Refractories, Specialties for Induction Melting (Mr. Geisler made Railroad Bells)/1970
Brochure/DoAll Philadelphia Co./Automatic Crush Form Grinding/UNK
Brochure/DoAll Philadelphia Co./Cutting Tooling/UNK
Brochure/DoAll Philadelphia Co./Black Granite Plates/UNK TAKEN - Mike
Brochures/DoAll Philadelphia Co./Centers & Cutters/1952
Brochure/DoAll Philadelphia Co./Variable Speed System for Speedmaster/1947-48
Brochure/DoAll Philadelphia Co./Safety Center Drills/UNK
Catalog/DoAll Philadelphia Co. (Mfg. by Savage Tool Co.)/Hydraulic Surface Grinders & Accessories/UNK
Digest/DoAll Philadelphia Co./Band Saw Machines, Tools & Processes/UNK TAKEN - Karl
Brochure/DoAll Philadelphia Co./Black Granite Working Flats/1954 TAKEN - Mike
Brochure/DoAll Philadelphia Co./Drills & Cutting Tools/UNK
Brochure/DoAll Philadelphia Co. (Mfg. by Walsh Press & Die Co./Power Press Line/UNK
Brochure/DoAll Philadelphia Co./Tool Steel/1950
Brochure/DoAll Philadelphia Co./Metal Cut-Off Machine & "Claco-Tooth" Saw Blade/UNK
Engineering Catalog/Dodge Mfg. Corp./Power Transmission Machinery/1956
Catalog/Dodge Mfg. Corp./Speed Reducers/1952
Catalog/Doerr Electric Corp./Electric Motors/1955 TAKEN - Glen
Brochure/Dorden & Co./Horizontal to Vertical Mill Converter/1955
Brochure/Dollinger Corp/"Staynew" Filters/Unk
Brochure/Donovan Mfg. Co./Machinists Vises/1955
Bulletin/Dow Chemical Co./Safety Precautions for Chlorothene/UNK
Catalog/Downs Crane & Hoist Co./Crane Wheels & Wheel Assemblies/1962
Brochure/Drafting Equip. Co./Model "B" Drafting Machine/1956
Brochure/Detroit Mold Engineering Co./Socket Head Cap Screws/UNK
Catalog/Dreis & Krump Mfg. Co./Power & Hand Brakes/1943
Catalog/Drive-All Mfg. Co./Speed Control Equipment/1953
Brochure/Dugas Machine Works, Inc./Dugas Indexing Chuck/1961
Catalog/DuMont Mfg. Co./Tool Bits/1954
Catalog/DuMont Mfg. Co./Minuteman Keyway Cutters/1948 TAKEN - Karl
Catalog/DuMont Mfg. Co./Minuteman Keyway Cutters/1955 (2) 1 TAKEN - Glen 1 TAKEN - Karl
Brochure/DuMont Mfg. Co./Keyway Broach Kit/UNK TAKEN - Glen
Brochure/DuMore Co./Automatic Drilling Heads/1954
Catalog/DuMore Co./Tool Post Grinders, Hand Grinders, Flex-Shaft Tools, Quills/1950 TAKEN - Glen
Catalog/DuMore Co./Precision Grinding Tools/1963 TAKEN - Mike
Catalog/Dunham Tool Co., Inc./Collets, Mandrels, Air & Vacuum Chucks/1969
Catalog/Dunham Tool Co., Inc./Expanding Collets, Air & Vacuum Chucks/UNK
Catalog/Dunham Tool Co., Inc./Milling Machine Chucks, Arbors & Adapters/1969
Catalog/Dunham Tool Co., Inc./Simplified Workholding/1975
Brochure/DuPage Machine Co./Jaws for Cushman Chucks/1957
Bulletin/DuPont/Neoprene/1953
Bulletin/DuPont/Facts about Neoprene for the Engineer/1953
Brochures/DuPont/Neoprene/1954
Brochure/Durable Punch & Die Co./Punches, Quills, Die Buttons/UNK (2)
Brochure/Durable Punch & Die Co./Punches/UNK
Brochure/Durable Punch & Die Co./Quills/1950
Brochure/Durable Punch & Die Co./Quills/1952
Instruction/Durable Punch & Die Co./Quills-Uses & Abuses/UNK
Brochure/Durant Mfg. Co./Machine Counters/1954
Brochure/Durant Tool Supply Co./Scrap Chopper/UNK (2)
Brochure/Durant Tool Supply Co./"Shur-Pull" Die Set Puller/UNK
Catalog/Durkee-Atwood Co./V-Ribbed Belts/1980
Catalog/Durkee-Atwood Co./V-Belt Drive Design/UNK
Bulletin - Price List/F. W. Dwyer Mfg. Co./Instruments for Science & Industry/1959
Catalog/F. W. Dwyer Mfg. Co./Instruments for Science & Industry/1954
Brochures/Dynabrade Inc./Dynafile Power Hand File/UNK TAKEN - Karl
T
twertsy
Reedville, VA
Company names starting with E:
Catalog/Eagle Mfg. Co./Safety & Oily Waste Cans/1961 TAKEN - Glen
Study/Eastman Chemical Products, Inc./Effect of Various Chemicals and Reagents on Tenite II/1953
Product Brochure/Eastman Machine Co./"Plastic Master" Cutting Machines/1954
Product Brochure/East Shore Machine Products Co./Glenny Adjustable Expansion Push Broach/1945
Product Brochure/East Shore Machine Products Co./Glenny Adjustable Expansion Push Broach/1955
Catalog/Eaton Mfg. Co./Reliance Rings, Eaton Springtites, Reliance Spring Lock Washers/UNK
Catalog No. 43/Eaton Mfg. Co./Snap, Bearing, Lock, Retainer Rings/UNK (Poss. 1943)
Product Brochure/Eaton Mfg. Co./Hoz-Fas-Ner Spring Hose Clamp/UNK
Brochure/Eclipse Counterbore Co./Counterbores/UNK
Catalog/Eclipse Counterbore Co./Cutting tools for Mills/1957
Catalog/Eclipse Counterbore - Div. of Illinois Tool Works/Cutting tools for Mills/1967
Catalog/Eclipse Counterbore - Div. of Illinois Tool Works/Cutting tools for Mills/1970
Catalog/Economy Bushing Co./Bushings/1974
Data Sheet - Price List/Economy Tool & Machine Co./Drill Jig Bushings/1950
Brochure/EDCO Tool Co./Turbomil Milling Cutters/1966
Catalog/Edgcomb Steel of New England, Inc./Feed Finger Pads/UNK
Catalog/Edgewater Steel Co./Welded Rings/1958
Brochure/Edroy Products Co./"Magni-Focuser" Binocular Magnifier/1955
Catalog/Edwards Co. Inc./Signaling Equipment/1955
Catalog/Eisler Engineering Co., Inc./Indexing Turntables & Variable Speed Controls/1956
Brochure/Elasticone/Covers/1971
Notebook/Elastomer/Elastomers Notebook/1957
Product Brochure/Eldorado Tool & Mfg. Corp./Nose Grinding Fixture for Gun Drills/1962
Catalog/Eldorado Tool & Mfg. Corp./Engineering & Design data for Precision Gun/deep hole drilling & boring applications/1959
Brochure/Electric Furnace Co./Furnaces/1946
Catalog/Electric Motor Corp. & Cyclohm Motor Corp. - Divisions of Howard Industries, Inc./Sub-Fractional H. P. Motors/UNK
Catalog/Electric Motor Corp. - Div. of Howard Industries, Inc./Sub-Fractional H. P. Motors/1946
Product Brochure/Electri-Flex Co./Liquatite Flexible Conduit/1959
Product Brochure/Electro Products Labs./Model 4700 Variable Speed Motor Control/1955
Product Brochure/Electro-Mechano Co./Model 105 High Speed Precision Drill Press/UNK (2)
Mailer/Electro-Mechano Co./16" Precision Drilling Machine/UNK
Brochure/Electro-Mechano Co./Automatic Drilling Units/1953
Brochure/Electro-Mechano Co./Portable Electric Tachometer/1953
Brochure/Electro-Mechano Co./Air-Hydraulic Unit/1958
Brochure/Electro-Mechano Co./Automatic Drilling Units/1958
Catalog/Elgin National Watch Co./Diamond Wheels/1960
Brochure/Elk Tools Inc./Elk Universal Tool Holder/UNK
Brochure/Elliot Co./Roller Burnishing Tools/UNK
Brochure/Elliot Co./Jiffy Gun Tube Cleaner & Tube Gage/UNK (Prob 1945)
Folder/Elox Corp of Michigan/Information on Electrical Discharge Machining/1955
Brochure/Empire Merchandising Co./Electro-Plating at Home & Equipment/1957
Catalog/Empire Tool Co./Screw Machine Tools/1968
Catalog/Empire Abrasive Equipment Corp./Blast Cleaning and Finishing Systems/1969-70
Brochure/ENCO Mfg. Co./"Tiny Titan" Electric Magnetic Bases/1960
Catalog/ENCO Mfg. Co./Tool Posts & Magnetic Bases/1964
Catalog/ENCO Mfg. Co./Tool Posts & Magnetic Bases/1963
Catalog/ENCO Mfg. Co./Tool Posts & Magnetic Bases, Tailstock, Nexturrets/1956
Brochure/ENDS Co./Disposable Tool Holder/UNK
Catalog/Engineering Devices Inc./ENDS Disposable Tool Holder/1961
Catalog & Example Use Book/ENERPAC/Using Hydraulic Tools & Tooling - Hydraulic Clamps/1964
Catalog/ENERPAC/Hydraulic Presses/1967
Supplier Catalog/Engis Equipment Co./Mostly Gauges (British)/1955
Catalog/Equipto/Steel Shelving, Bins, Tables, etc./1967 TAKEN - Glen
Catalog No. 195/Equipto/Steel Shelving, Bins, Tables, etc./UNK TAKEN - Glen
Catalog/Equipto/Steel Shelving, Bins, Tables, etc./1957 TAKEN - Glen
Catalog 3/Erickson Tool Co./Precision Holding Tools/1952 TAKEN - Mike
Catalog K/Erickson Tool Co./Precision Tools, Chucks & Holders/1954 TAKEN - Mike
Brochures/Erickson Tools - Div. of Erickson Steel Co./Collets & Holders/1952 TAKEN - Mike
Catalog & Brochures/Errington Mechanical Lab/Drill Press - Multiple Heads, Skeleton Bridle-Clamps, etc./UNK (Prob 1940's"
Product Brochure/ESCO S. A., Engineering Works/Rotomatic DS-1 & DS-3/UNK
Product Brochure/ESCO S. A., Engineering Works/Escomatic DS-2 & DS 2a/1960
Catalog/ESCO - Div. of Evangaline Products Co., Inc./Traffic Signs/1981
Catalog/Etaline/Precision Measuring Tools & Fixtures/1954
Catalog No. 31/Ettco Tool Co., Inc./Ettco-Emrick System for Multiple Drilling & Tapping of Small Parts/UNK
Brochure/Everede Tool Co./Boring Bars & Holders/UNK(Pre-1963)
Catalog/Everede Tool Co./Boring Bars & Holders, Jigs, etc./1955
Brochure/Everede Tool Co./Quills/UNK(Pre-1963)
Catalog/Everett Industries/Abrasive Cut-off Machines & Wheels/1974
Brochures/Exact Machine Tool Co./Lathes, Band Saws, Sanders/UNK
Catalog/Ex-Cell-O Corp/Drill Jig Bushings/1950
Catalog/Ex-Cell-O Corp/Carbide Tool Grinders/1946
Tool Tips/Ex-Cell-O Corp/June -> December, 1953 - May, August & Sept., 1954
Bulletin 11882 (x3)/Ex-Cell-O Corp/Drill Jig Bushings/1941
Story/Ex-Cell-O Corp/Rebuilding Hydra-Matics from GM Transmission Plant Fire/UNK
Catalog/Ex-Cell-O Corp/Thread Grinders/UNK
Catalog/Ex-Cell-O Corp - Continental Tool Works Div./Interchangeable Counterbores/UNK
Catalog/Ex-Cell-O Corp/Quill-Type Hydraulic Power Units/1952
Bulletin 46337/Ex-Cell-O Corp/Tool Grinders/UNK
Company names starting with F:
Brochure/F&D Machine & Tool Works/Special Cutting Tools/UNK
Catalog/Fabroid Division - American Metal Products Co./Self Lubricating Bearings/1964
Product Brochure/Factory Tool Supply Co./BUX Magnetic Drill Press/UNK
Tolerance Charts/"Fafner" (Hand written by Mr. Geisler, but Keuffel & Esser Co. is in the bottom corner in very small print)/Tolerance charts for Fafnir Ball Bearings/UNK
Catalog No. 19/Fafnir Bearing Co./Ball Bearings & Ball Bearing Transmission Units/1954
Catalog No. 21/Fafnir Bearing Co./Ball Bearing Power Transmission Units/1971
Catalog/Fafnir Bearing Co./Precision Ball Bearings/1956 Taken - Glen
Catalog/Fairbanks Co./Casters/1956 Taken - Glen
Product Brochure/Fairbanks, Morse & Co/Squirrel Cage Induction Motors/1954 TAKEN - Ben
Brochure/Fairfield Gauge Co., Inc./Micro-Height Gauge/1954 TAKEN - Mike
Brochure/Fairfield Mfg. Co./Gears/1959
Brochure/Fairfield Tool Co./Micro-Height Gauge/1953 TAKEN - Mike
Catalog/Falcon Tool Co./Reamers, End Mills, Counterbores, etc./1953
Brochures/Falls Products Inc./Roto Centers/1954
Brochure/Falls Products Inc./Roto Centers/1951
Brochure/FAMCO Machine Co./Air Presses/1951
Brochure/FAMCO Machine Co./Metal Cut-Off Machines/1950
Small Brochure/FAMCO Machine Co./Shears & Presses/1944
Brochure/FAMCO Machine Co./Vertical Milling Machines/1957
Brochure/Farmington Engineering Co./Cylindrical Gages/UNK (1950s)
Brochure/Farmington Mfg. Co./Air Bearing Rotary Tables/UNK (1950s)
Brochure/Farrel-Birmingham Co, Inc./Drill-Point Thinning Machine/1961
Catalogs/Farrel Products/1-Pins & Punches, 2-Hex Inserts & Wafers, 3-Feed Rolls, 4-Fingers, 5-Dies & Cases/1977
Brochure/Fastcut Tool Co./Keyseat Cutters & other Tooling/UNK
Catalog/Federal Bearings Co., Inc./Ball Bearings/1966
Product Brochure/Federal-Bryant Machinery Co. (distributor)/Jay-Dee Universal Attachment1960
Catalog/Federal Press Co./Presses/UNK
Brochure & Tracing Templates/Federal Products Corp./All Kinds of Dial Gauges/UNK
Product Brochure/Fellows Gear Shaper Co./No. 3 & No. 4M Involute Measuring Machines/1937 TAKEN - Ben
Catalog with Samples/Felters Co./Precision Cut Felt Parts Manual/1945
Product Brochure/Ferance Construction Co./Beam Compass/UNK (2)
Product Brochure/Ferguson Tool & Engineering Co./"Magic Point" Center/1962
Catalog/Jos. T. Fewkes & Co./Slo-Sin Synchronous Stepping Motors, Controls & Drives, Bodine Motors & Speed Controls, Minarik D.C. Motor Controls/1970
Brochure/Fibre Products Mfg. Co./Salesman Sample Cases/UNK
Brochure/Walter W. Field & Son/Hart Milling Fixtures/1965
7 Price Charts, Brochures/Field Tool Supply Co./Taps & Dies, Milling Cutters, Tooling, etc./1960s
Product Brochure/Finnell System, Inc./Dry Floor Scrubber/1954
Catalog No. 1/Firth-Loach Metals, Inc./"Firlomet" Cemented Carbides/UNK
Catalog/Firth Sterling Co./"Firthite" Inserts, Toolholders, Tools, Tips/UNK
Product Brochure/Firth Sterling Co./Posished Drill Rod/1962
Brochure/Fischer Special Mfg. Co./Aluminum Nuts/1954
Brochure/Fischer Special Mfg. Co./Fischer Turned Brass Nuts/1953
Brochure/Fischer Special Mfg. Co./Fischer Turned Aluminum Nuts/1954
Brochure/Fischer Special Mfg. Co./Fischer Turned Brass & Aluminum Nuts/1958
Brochure/Fischer Special Mfg. Co./Fischer Turned Brass & Aluminum Nuts/1955
Brochure/Fischer Special Mfg. Co./Fischer Turned Brass & Aluminum Nuts/1954
Brochure/Fischer Special Mfg. Co./Fischer Turned Brass Nuts/1954
Product Brochure/L. A. Fitzer Tool Works/"Taper-Tail" Taper Attachment for Lathe Tailstock/UNK
Brochure/Fleet Tools & Devices, Inc./Fluma Fix Magnetic Work Supports/UNK (Post-1963)
Brochure/Flennor Inc./Timing Belt Drives/UNK (Post 1963)
Brochure/Flexaust Co./Hose & Dust/1960?
Brochure/Flexible Tubing Co./"Flexflyte" Flexible Ducting/1956
Brochure/Flexible Steel Lacing Co./Alligator V-Belt Fasteners/1960
Brochure/Flexible Steel Lacing Co./Alligator V-Belt Fasteners/1957
Catalog/Flexrock Co./Building Maintenance Materials/1956
Brochure/Flood Safety Products Co./Goggles, Spectacles & Respirators/1962
Brochure/Flynn Mfg. Co./Boring Tools & Accessories/1954
Catalog/Foote Brothers/Duti-Rated Lifetime Gearing/1954
Catalog/M. A. Ford Mfg. Co./End Mills & Other Cutters/1963
Catalog/M. A. Ford Mfg. Co./End Mills & Other Cutters/1952
Product Brochure/Foredom Electric Co./Chuxrite Rapid Action Collet Vise/1954
Product Brochure/Forney Arc Welders, Inc./Model C-2 Combination Farm Repair Unit/UNK
Product Brochure/Gale Forssen Co./STARCO Master Grinding Attachment/1958
Brochure/Foster Supplies Co./DIATEST Small Bore Gauge & Gauge Kits/1959
Brochures/Foster Supplies Co./All kinds of Gauges & Gauge Kits/1959
Brochures/Foster Supplies Co./All kinds of Gauges & Gauge Kits/1960
Catalog/Foster Engineering Corp./All kinds of Electric Sizers, Gauges, and Controls/1954
Product Brochure/Fry Tool Mfg. Co./Fry Multi-Duty Lathe Tooling System/1957
Product Brochure/Fuller Co./Rotary Compressor/1956
Catalog/Furnas Electric Co./Drum, Foot & Limit Switches/1957 Taken - Glen
Catalog/Furnas Electric Co./Furnas Electric Drum Switches/1964
Company names starting with G:
Brochure/Gahr Machine Co./Soft Blank Chuck Jaws/UNK (1950s)
Brochure/Gahr Machine Co./Adjustable Flanged Tool Holder/UNK (1950s)
Brochure/Gahr Machine Co./Tool Holder Bushings/1956
Catalog/Gairing Tool Co./Conner Spade & Core Drills/1953
Catalog/Gairing Tool Co./Standard Tools - Boring, Cutting, Milling/1952
Catalog/Gammons-Hoaglund Co./Reamers/1950
Catalog No. 400/Gammons-Hoaglund Co./Reamers & Special Tools/UNK (1960s)
Brochure/Gammons-Hoaglund Co./Reamers/1956
Brochure/Gardner-Denver Co./Compressors & Vacuum Pumps/1954
Brochure/Gatco Rotary Bushing Co./Rotary Tool Bushings/1951
Catalog/Gates Rubber Co./Heavy Duty V-Belt - Drive Selection Manual/1971
Catalog/Gates Rubber Co./VT Vulcomount Sheaves - T Standard Sheaves/1956
Product Brochure/Gay-Lee Co./"Thinsaw" Cutter/UNK
Product Brochure/Gay-Lee Co./Carbide Commutator Under-Cutting Saw/UNK
Product Brochure/Gay-Lee Co./"Thinsaw" Cutter/1956
Brochure/Gear Specialties/Small Gearing/1948
Catalog/General Electric Co./Magnetic Starters for AC & Refrigeration/1963
Catalog/General Electric Co./"Tri55Clad" Motors (Single-Phase)/1954 or 1962? Taken - Glen
Catalog/General Electric Co./Wires, Cables, Cords for Product Designers/1951
Quote & Engineering Drawing/General Electric Co. (Fort Wayne Works)/Motor for 1/2" Steel Drill/1944
Handbook/General Electric Co./Shell-Type Induction Motors/1947 Taken - Glen
Catalog/General Industrial Co./Office & Factory Equipment/1956
Letter-Response/General Industrial Co./Response to Inquiry regarding "Port-A-Phone" Intercom System/1954
Product Brochure/General Plastics Corp./Shrink-Fit Teflon FEP Tubing/1965
Brochure/General Roto Co./"Roto-Head" Lathe Head/1953 TAKEN - Mike
Index/General Tool Sales Co./Index of Products & Manufacturers Represented/UNK (1950s)
Catalog No. 54/Genesee Mfg. Co./Adjustable Hollow Mills, Facing & Counterboring, and Special Production Tools/1954
Catalog/Gildemeister/Turret Lathes, Multi-Spindle Automatics, Plano Milling Machines/1960 TAKEN - Mike
Catalog/John Gillen Co./Taper Pins & Keys/1953
Catalog/John Gillen Co./Keys - Groove & Taper Pins/1955
Catalog/John Gillen Co./Keying & Pinning Devices for Production Assembling/1957
Brochure/Russell T. Gilman, Inc./Spindle Assemblies, Spindle Mounting Brackets, Slide Assemblies/1954
Catalog/Russell T. Gilman, Inc./Machine Modules/1969
Product Brochure/Gisholt Machine Co./2L High Production Saddle Type Turret Lathe/1951 TAKEN - Mike
Product Brochure/Gisholt Machine Co./No. 3 Ram Type Universal Turret Lathe/UNK TAKEN - Mike
Product Brochure/Gisholt Machine Co./4L High Production Saddle Type Turret Lathe/1951 TAKEN - Mike
Catalog/Gisholt Machine Co./HD Air, Wrench, Power, Wrenchless Chucks/UNK TAKEN - Mike
Product Brochure/Gisholt Machine Co./Simplimatic Automatic Lathe/UNK TAKEN - Mike
Catalog/Gits Brothers Mfg. Co./Shaft Seals & Lubricating Devices/1951 Taken - Glen
Catalog/Gleason-Avery, Inc./Instrument & Timing, Gear, & Synchronous & Non-Synchronous Motors/1954
Catalog/Gleason-Avery, Inc./Instrument & Timing, Gear, & Synchronous & Non-Synchronous Motors/1956
Catalog/Edward R. Glenn (Distributor)/Ace Drill Bushing, Marshall Flat Stock, Holo-Krome Screw Sockets, Noble & Stanton Studs & Nuts, Porter Precision Punches, Everede Tools, Chandler Tool Heads, Heinrich Fixture Lock & Grip-Master Machinists Vise/1952 Taken - Glen
Brochure/Globe Heat-Seal, Inc./Hand Screw Machine/1952
Catalog/Golden Bear Equipment Corp./Materials Handling & Storage/1963
Catalog/George Gorton Machine Co./Accessories - Cutters & Grinders/1948
Catalog/J. D. Gould Co./Gould Solenoid Valves/1950?
Product Brochure & Engineering Drawing/Govro-Nelson Co./Two-Unit Opposed Drilling Machine/1953
Engineering Drawings/Gra Art Industries/Angle Laters & Flooded Boring Bar/UNK (1950s)
Product Brochure/Graham Mfg. Co., Inc./Multi-Purpose Machine Vise/1953
Catalog/Graphite Metallizing Corp./Graphalloy Material - Bushings, Seals, Packing Rings, & Electrical Contacts & Brushes/1954
Price List/Graymills Corp./Centrifugal Pumping Systems/1954
Brochure/Green Mfg. Co./Full Floating Reamer Holders/UNK (1950s)
Brochure/Greenerd Arbor Press Co./Arbor & Hydraulic Presses/1953 TAKEN - Karl
Catalog/Greenerd Arbor Press Co./Arbor & Hydraulic Presses/1953 TAKEN - Karl
Brochure/Greenfield Tap & Die Corp./Little Giant Screw Plates, Drills, Extractors & Pipe Sets/1949 Taken - Glen
Catalog No. 65/Greenfield Tap & Die - Div. of TRW/Thread Cutting Tools & Gauges/1974 TAKEN - Mark
Catalog/Greenleaf Corp./Indexable Insert Tool Holders/1967
Newsletter/Greenlee Bros. & Co./Calculating the corrected step for flat & dovetail form tools/1957
Brochure/Greenlee Tool Co. - Div. of Greenlee Brothers & Co./Hydraulic & Hand Benders/1948 Taken - Glen
Brochure/Greenlee Tool Co. - Div. of Greenlee Brothers & Co./Hydraulic Benders/1949
Catalog No. 35-H/Greenlee Tool Co./Hand Tools for Woodworkers/1953 Taken - Glen (SCAN b4 sending)
Brochures/Gries Reproducer Corp./GRC Die Cast Gears & Pinions/1954
Catalog/Grinnell Co., Inc./Pipe Hangars & Supports/1958
Brochure/F. T. Griswold Mfg. Co./"Scan-A-Scale" Precise Linear Measurer, Microscope, Voltage Controller & Scale/1957
Catalog/Groov-Pin Corp./Groove Pins & Drive Studs/1951
Catalog/H. A. Guden Co., Inc./Hardware for Industry/1970
Catalog No. 19/Gwilliam Co./Ball & Roller Bearings/UNK (1940s or 50s)
T
twertsy
Reedville, VA
Company names starting with H:
Stapled Fliers & Correspondence/Hall Mfg. Co./Eccentric Valve Seat Grinding Equipment/1941-1987
Catalog/Hammond Machinery Builders, Inc./Abrasive Belt Grinders & Polishing and Buffing Lathes/1960 TAKEN - Ben
Catalog/Hammond Machinery Builders, Inc./Abrasive Belt & Wheel Grinding, Polishing and Deburring Machinery/1950 TAKEN - Ben
Brochures/Hanchett Magna-Lock Corp./Magnetic Chucks & Devices/1959
Brochures (about 8)/Handy & Harman/Sil-Flos & Easy-Flo Silver Brazing/1941 through 1944
Catalog/Hanna Engineering Works/Hydraulic Cylinders/UNK (Poss. 1934)
Catalog/Hannifin Corp./Control Valves/1955
Folder/Hannifin Corp./"Crown Line" Airline Regulators, Filters, Lubricators & Combo Units/1956
Brochure/Hannifin Corp./Valves, Cylinders and Hydraulic Presses/1960
Brochure (2)/Hannifin Corp./Hydraulic (oil) Cylinders/1956
Brochure/Hannifin Corp./Air Power Cylinders/1956
Bulletin & Brochures/Hannifin Corp./Hydraulic Presses/UNK (1950s / Poss. 1 1940s)
Catalog/Hanson-Whitney Co./Gages/1953
Guide/Hanson-Whitney Co./Tap Selector & Price List/1959
Price List/Hanson-Whitney Co./Gages/1960
Catalog/Hanson-Whitney Co./Thread Milling Machines & Taps/1957
Brochure/Hardinge Brothers, Inc./Draw-In Collets & Hardinge-Sjogren Speed Collet Chucks/1950 Taken - Glen
Brochure/Hardinge Brothers, Inc./Emergency Collet Pads/1952? Taken - Glen
Product Booklet & Quote/Hardinge Brothers, Inc./HS Precision Second Operation Machine with Variable Speed Drive Model DSM59/1958
Product Booklet/Hardinge Co., Inc./BLM Clutch/1946
Catalog/Harrisville Tool Co. - Affiliate of Dawson Carbide Ind., Inc./Quality Carbide Inserts/UNK
Product Brochure/Hartford Special Machinery Co./V-Block Fixture/1945
Catalog/Hartford Special Machinery Co./Super Spacers/1962
Catalog/Hartford Steel Ball Co., Inc./Precision Balls/UNK (Pre-1963)
Brochure/Hartmann Mfg. Co./Adjustable Pressure Production Vise/UNK
Brochure/Hartwood Glass & Metal Co./Glass Tipped Slotted Set Screws/1960
Brochure/Hayden Twist Drill Co./Adjustable Drill/1954
Product Brochure/Heald Machine Works/No. 1B Milling Machine/UNK TAKEN - Mike
Assembly & Use Books/Heath Co./Amps W-5M (x2), W3-AM -- Preamps SP-2, WA-P2 -- FM Radio GR-21 -- Multiplex Adapter AC-11 -- AM-FM Stereo Tuner PT-1/Range 1957-1959
Catalog/Hecht Rubber Corp./Rubber Products/1971
Catalog/Heim Co./Bearings/1961
Brochures/Heimann Mfg. Co./Point for Point Transfer Screws/UNK
Catalog & Brochures/Heinrich Tools Inc. (formerly National Machine Tool Co.)/Air & Hand Vises & other Products/1952-1956 Taken - Glen
Catalog/Hendley & Whittemore Co./Metal Working Machines/1966
Product Brochure/Alfred Herbert Ltd./No. 8 Preoptive Combination Turret Lathe/1956
Brochure/Heuser Mfg. Co./"John's" Drill Jig/UNK (1950s)
Catalog/Hewlett-Packard Co./Voltmeters, Oscilloscopes, Generators, Electronic Counters, etc./1959 TAKEN - Glen
Brochure/Hi-Duty Drill Works/HS Drills & Tools/1950
Catalog/Hill Acme Co./Metal Shearing Aids by the Cleveland Knife Division/1959
Product Brochure/Hilliard Corp./Over-Running Clutch/Materials date from 1941-1946
Catalog/Hi-Shear Rivet Tool Co./Anchor Bushing/1954
Catalog/Hi-Standard Mfg. Corp./Deep-Hole Drills (Gun Drills)/1956
Catalog/Hoefer Mfg. Co./Multiple Spindle Heads/1945 TAKEN - Karl
Catalog/U. S. Hoffman Machinery Corp./Stationary Vacuum Cleaning Equipment/1954
Brochure/Holub Industries, Inc./Live Centers & Inserts/1958
Handi-Book/Hoover Ball & Bearing Co./Anti-Friction Bearings/1957
Catalog/Hoover Ball & Bearing Co./Ball, Power Transmission, and Integral Shaft Bearings/UNK (1970s?)
Catalog/Charles A. Hones, Inc./"Buzzer" Furnaces & Burners/1978
Brochure/Horspool & Romine Mfg. Co., Inc./Acme Screws & Nuts/1981
Brochure/E. Horton & Son Co./Drill Chucks/1941
Product Brochure/Howe & Fant, Inc./"Lign-O-Matic" Self-Centering Drill Turret/1950
Product Brochure/Howe & Fant, Inc./Turret Drilling Machine/1955
Product Brochure/Hjorth Lathe & Tool Co./"Success" Marking Machine/UNK
Catalog/Houston Grinding & Mfg. Co., Inc./Live & Bull Nose Centers/UNK
Product Brochure/Hudson Automatic Machine & Tool Co./"R-Filemaster" Multi-Purpose Rotary Power Tool (Table Grinder with File)/1959
Brochure/Hudson Automatic Machine & Tool Co./MILEX Master Collet Holder/UNK
Brochure/Huot Mfg. Co./Drill Indexes/1950 Taken - Todd
Catalog (2)/Huron Machine Products Co./Gage Supplies/1957
Catalog/Hyatt Bearings Div. - United Motors Service - Div. of GMC/Hyatt Roller Bearings/1955
Catalog/Hypneumat Inc./Automatic Drilling and Tapping Units (Air & Hydraulic)/1958
Company names starting with I:
Catalog/Ideal Commutator Dresser Co./Tools & Equipment for Maintenance, Production & Construction/1943 TAKEN-Glen
Product Brochures/Ideal Industries, Inc. - (Successor to Ideal Commutator Dresser Co.)/Insulation Resistance Tester, Coil Winder Drive, Live Centers, Surface Plates, Die Grinders/1946
Brochures/Ideal Industries, Inc./Plastic Wire Connectors, Electric Connector Driver, Price List/1957-59
Product Brochure/Ideal Industries, Inc./Electric Etchers/1952
Brochure/Ideal Industries, Inc./Live Centers/UNK
Price List/Ideal Industries, Inc./All Products/1952
Engineering Manual/Ideal Industries, Inc./Driving Centers/1960
Catalog/Ideal Industries, Inc./Live Centers, Electric Etchers, Demagnetizers, & Tachometers/1960
Brochures/Ideal Industries, Inc./Live Centers, Electric Etchers, Demagnetizers, & Tachometers/1963
Brochure/Illinois Metal Products/IMP "Hold-Down" Vise/1955
Brochure/Illinois Metal Products/IMP "Hold-Down" Vise/1959
Catalog/Illinois Tool Works/"Spiroid," "Helicon," & "Planoid" Gears/1959
Catalog/Illinois Tool Works/Fine Pitch Hobs/1950
Brochure/Illinois Tool Works/"Illinite" Power Blades/1954
Catalog/Illinois Tool Works/"Illinite" Standard End Mills & Milling Cutters/1957
Catalog/Illinois Tool Works/"Illinite" Standard Hobs & Shaper Cutters/1957
Catalog/Imperial-Eastman/Tubing Tools/1970 TAKEN-Glen
Catalog/Imperial-Eastman/Tube Fittings/1960
Foldout/Imperial/Tubing Tools/1947? TAKEN-Glen
Catalog/Impero Tool Corp./Uni-Kit for Internal & External Lathe Machining/UNK (Pre-1963)
Product Brochure/Industrial Engineering Co., Inc./Lock-Type "XACTOR" Protractor/UNK
Catalog/Industrial Filtration Co./"DELPARK" Industrial Filtration/1956
Catalog/Industrial Handling Equipment Co., Inc./Trucks, Shelving, Conveyors, Benches, etc./1957 TAKEN-Glen
Brochure/Industrial Machinery & Equipment Co., Inc./Moriseiki Lathes/1975
Manual/Industrial Mineral Wool Institute/Holding Low Temperatures with Better Insulation/1949
Catalog (with samples)/Industrial Retaining Ring Co./Industrial Stacked Retaining Rings/1956 TAKEN - Ben
Catalog (with samples)/Industrial Retaining Ring Co./Industrial Stacked Retaining Rings/1954 TAKEN - Ben
Catalog/Industrial Scientific Instruments, Ltd./Machining Time, Weight, Inertia, Flow, Central Heating, Tank Capacity, Costing, & Trig Calculators (wheels)/UNK (Post-1963)
Technical Bulletin/Industrial Techtonics, Inc./"Ballizing" for HS / High - Precision Hole Sizing & Finishing/1957 TAKEN-Mike
Technical Bulletin/Industrial Techtonics, Inc./"Ballizing" for HS / High - Precision Hole Sizing & Finishing/1954
Catalog/Industrial Techtonics, Inc./Super-Precision Master Balls/1957
Brochures/Industrial Techtonics, Inc./Precision Balls & Ball Sets/1954
Brochures/Industrial Techtonics, Inc./Synthetic Sapphire Balls/1955
Catalog/Industry Mart/Machinery, Tooling, All Shop Tools & Supplies/1970 TAKEN-Glen
Catalog/Ingersoll Milling Machine Co. - Cutter Div./Cutters, Blades, Set-ups, etc./1958 TAKEN-Mike
Catalog/Ingersoll-Rand/Electric Power Tools/1964 TAKEN-Glen
Catalog/Insulation Manufacturers Corp./Electrical Insulation/1958
Brochure/International Ball & Roller Bearing Corp./All types of Bearings/UNK
Brochures/International Machine & Tool Corp/IMTCO-KL Quick-Bit 40 Tool Holder, IMTCO-KL Live Centers, Tooldex Turret Toolpost Type 48/1970?
"Helpful Publications"/International Nickel Co., Inc./Nickel Alloys/1946 & 1954
Engineering Book/International Nickel Co., Inc./INCO Casting Data - Engineering Properties of "S" Monel/1954
Brochure/International Register Co./"Intermatic" Time-All Appliance Timer/1953
Brochures/Interstate Tool Co./2-piece Standard Centers/1952
T
twertsy
Reedville, VA
Re: Machinery & Equipment Catalogs
Company names starting with J:
Catalog/J & S Tool Co./Fluidmotion & Form-Master Series Wheel Dressers/1982 TAKEN-Glen
Brochures/J & S Tool Co./Fluidmotion & Form-Master Series Wheel Dressers/1955 TAKEN-Glen
Catalog/J & S Tool Co./Live Centers/1958 TAKEN-Glen
Brochures/J & S Tool Co./"Square-Per-Fect" Vise, Jaw Clamps, Work Holding Fixtures/1954 TAKEN-Glen
Catalog/J & S Tool Co./Arbors, Adapters, and Live Bearing Supports/1959 TAKEN-Glen
Catalog/J & S Tool Co./All Purpose Jaw Clamps/1955 TAKEN-Glen
Catalog/Jackes-Evans Mfg. Co./Solenoid Valves for Automatic Flow Control of Liquids & Gases/1957
Brochure/JACO Devices, Inc./Press Room Equipment/UNK
Brochures/JACO Devices, Inc./Accessories for Punch Press Automation/1958
Catalog/Jacobs Mfg. Co./Chucks/1970 TAKEN-Glen
Catalog/Jacobs Mfg. Co./Chucks/1940 TAKEN - Steve
Catalog/Jacobs Mfg. Co./Chucks/1944 TAKEN - Steve
Catalog/Jacobs Mfg. Co./Drill & Tap Chucks/1955 TAKEN - Tom
Product Brochure/Jacobs Mfg. Co./Model 96 Collet Chuck & Arbors/1954
Catalog Supplement/Jacuzzi Bros., Inc./Pumps & Water Systems for Deep & Shallow Wells/1947
Catalog/D. O. James Mfg. Co./Cut Gears/1944
Brochures (3)/Jancy Engineering Co./Roto-Bor/1971
Catalog/Janitrol Aero Div. - Midland-Ross Corp./Couplings, Flanges and Bands/UNK
Brochure/Jarrow Products/Refrigerator Door Gaskets/1949?
Catalog/Jarvis Products Corp./Machine Tools/1977
Brochure/JEDCO, Div. of Jessup Engineering & Development Co./Micro Drill Guide/UNK
Engineering Data/C. O. Jelliff Mfg. Corp./Industrial Wire Cloth/1954
Brochure/C. O. Jelliff Mfg. Corp/Dipping Baskets/UNK
Brochure/C. O. Jelliff Mfg. Corp/Fuel Strainers/UNK
Brochure/C. O. Jelliff Mfg. Corp/"Lectromesh" Metal Screens/UNK
Catalog (2)/J. G. Jergens Div. - Donley Products, Inc./Live Pilot Bearing Bushings/UNK
Booklet/John G. Jergens/2nd Edition Handbook on Tool Designing & Engineering/Wartime - "Let's Keep 'em Flying" - UNK Year TAKEN - Steve
Catalog/J. G. Jergens Div. - Donley Products, Inc./Live Pilot Bearing Bushings/1956
Catalog/J. G. Jergens Co./Roller Bearing Pilot Bushings/1951
Price Quote/J. G. Jergens Div. - Donley Products, Inc./No. 1125 Needle Bearing Live Bushing/1954
Catalog/Jergens Tool Specialty Co./Quality Products for Tooling & Manufacturing/UNK (Post 1963)
Catalog/Jergens Tool Specialty Co./Jig & Fixture Standards/1952
Catalog/Jergens Tool Specialty Co./Quality Products for Tooling & Manufacturing/1961
Catalog/JET/Equipment & Tools/1974 TAKEN - Mark
Product Brochure/I. O. Johansson Co./Model 8-18 Drilling Machine & Tooling/1954
Instruction & Specs/Johns-Manville/Thermobestos Pipe & Block Installation/1965
Catalog/Johnson Bronze Co./Mechanical Plastics for Bearing Surfaces/1965 TAKEN - Mark
Catalog/Johnson Bronze Co./Sleeve Bearings and Bars/1965 TAKEN - Mark
Brochure/Johnson Gas Appliance Co./Gas Burning Appliances/1941 TAKEN - Ben
Catalog/Johnson Metal Hose Inc./Flexible Metal Hose/1959?
Brochure/Jones & Lamson Machine Co./"Modern-Magic" Chucks & Collets/1954
Catalog/Jones & Laughlin Steel Corp./10 Cold Finished JALCASE Grades/1954 TAKEN - Mark
Catalog/Jones Motrola Corp./Tachometers/1946 & 1949 Price List
Company names starting with K:
Specs & Instructional/Kaiser Aluminum/Aluminum for Product Design & Manufacture/1955
Brochure/Kaiser Tool Co./Thinbit Grooving Tools/1970
Brochure/Kasenit Co./Surface Hardening & Heat Treating Compounds/UNK
Brochure/Kasenit Co./Surface Hardening & Heat Treating Compounds & Furnaces/UNK
Catalog/Kaydon Engineering Corp./Turntable Ball Bearings/1963
Blueprints (Outlines & Specs)/H. W. Kearns & Co., Ltd./Kearns No's 1 & 4 Boring Machines/1968
Product Marketing Materials/Kearney & Trecker Corp./Tri-D Milling Head Dimension Sheet, Brochure, & Cardboard Mockup/UNK TAKEN-Mike
Catalog/Keller Tool Co./Pneumatic Tools/1952 TAKEN-Glen
Brochure/Kenco Mfg. Co./Punch Presses, Rotary Tables, & Mill Vises/1953 TAKEN-Glen
Brochures/Keystone/Penetrating Oil/1949? TAKEN-Glen
Product Brochure/J. F. Kidder Mfg. Co./56BMP Ironworker Machine/UNK
Brochure/Kingmann-White, Inc./Sine Bars/1968
Catalog/Kipp/Elesa/Machine Handles/1969
Catalog/Kipp/Elesa/Machine Handles/1985
Catalog/Koh-I-Noor Rapidograph, Inc./Drawing Inks & Paper, Drafting Film, Lead Holders Leads, & Pencils/1979
Product Brochure/Kohler of Kohler/Air Cooled Engine/1953
Catalog/Knu-Vise, Inc./Toggle Action Clamping Tools/1942 TAKEN-Steve
Product Brochure/Knu-Vise, Inc./"C" Clamp with Quick Acting Toggle Movement/1941 TAKEN-Steve
Brochure/R. Krasberg & Sons Mfg. Co./Universal Automatic & Primary Stops/1953
Catalog (2)/Kurt Mfg. Co./Anglock Precision Machine Vises/UNK (Post 1963) TAKEN-Glen (1)
T
twertsy
Reedville, VA
Company names starting with L:
Brochure/Lach Diamond Inc./Turning Tools/1984
Brochures/Lad Gage Co./Indicator Stop Gage for Turret Lathes/1959
Catalog No. 20/Lambert Tool Supply/Taps, Gauges, Drills, Reamers, End Mills/UNK (1950s) TAKEN - Glen
Catalog/Lamina, Inc./Hydraulic Motors, Springs, Wear Plates, etc./1973
Catalog/Laminated Shim Co., Inc. - Stamping Div./Stampings/1954
Catalog No. 35 (2)/A. Landau Co./Industrial Diamond Tools/UNK
Catalog/A. Landau Co./Diamond Wheels/1957
Quote/Landis Machine Co./LandMatic Die Head, Chaser Holders/1950
Catalog/Landis Machine Co./Thread Rolling Button Dies/UNK
Quote/Landis Tool Co./Work Drive Dogs/1960
Price Schedule/F. H. Langsenkamp Co./Master Dockboard/1965
Catalog/Lapeer Mfg. Co./Knu-Vise Products/1960 TAKEN - Glen
Brochures/Lassy Tool Co./Tapping & Threading Equipment & Work Holders/1954 TAKEN - Mike
Catalog/Last Word Sales Co./Last Word Wheel Dresser/UNK (1950s)
Catalog/Lavellee & Ide, Inc./Reamers/1960
Brochure/Lawley Granite Surface Plate Co./Surface Plates/UNK TAKEN - Mike
Brochure/Lebanon Steel Foundry/Steel Castings/UNK
Catalog/LeCount Tool Works, Inc./Expanding Mandrels & Clamps/1954
Catalog/LeCount Tool Works, Inc./Expanding Mandrels/1954
Catalog/Lee Co./Lee Plugs for the Design & Manufacture of Fluid Devices/1961
Catalog/K. O. Lee Co./Tool & Cutter Grinders/1981
Catalog/Lee Spring Co./Stock Springs/1966
Catalog/Leeds & Northrup/Analysis Equipment, Controllers, Furnaces, Metallurgical Analysis/1975
Brochure/Lehigh Chemical Co./Anderol Rust Preventative/1944?
Catalog/Lehigh Inc. - Air Control Div./Double Acting Air Motors/1954
Brochure/Leiman Bros./Blasting Equipment/1952
Catalog/E. Leitz, Inc./Monocular & Binocular Microscopes/1954
Product Brochure/Le Maire Tool & Mfg. Co./Match-It Gear Chuck/UNK (Prob. ~1944 or 5 - Contains reprint of 1943 Article)
Product Brochure/Lempco Products, Inc./Adjustable Saf-T-Prop (for Presses)/UNK
Catalog/Lepel High Frequency Laboratories, Inc./HF Induction Heating Equipment/1961
Catalog/Lepel High Frequency Laboratories, Inc./Heat Treating & Metal Joining Units/UNK (Prob Late 1940s - Contains reprint articles from '44 and '45)
Product Brochure (2)/Lepel High Frequency Laboratories, Inc./Model 2kw HF Heating Unit/1950
Brochure/Libby, Owens, Ford Glass Co./Glass for Product & Engineering Design/1953-4
Catalog/Liftex Slings, Inc./Nylon Webbing Slings/1962
Instructional/Lincoln Machine Parts Corp./Skiving...What it is & can do, where to use, how to design & make cutters, new ideas in toolholders/1955
Brochure (2)/Lindberg Products Co./Portable Sand Blast Gun/1955
Catalog/Link-Belt Co./Silent Chain Drives/1956 TAKEN - Glen
Catalog/Lisl Corp./Magnetic Plugs & Chip Detectors/1964
Catalog/Lixie, Inc./Industrial Soft Face Hammers/1963 TAKEN - Glen
Catalog No. 10/Lodding, Inc./Jig & Fixture Components/1954
Product Brochure/Lodge & Shipley Co./24" Speed Shear/1954 TAKEN - Mike
Catalog/Lovejoy Tool Co./Joydex Face, End, & Half Side Mills with Indexable Disposable Blades/1968
Catalog/Lucas Machine Div. - New Britain Machine Co./Precision Horizontal Jig Boring, Drilling, Milling Machines/1967 TAKEN - Mike
Catalog/Lucifer Furnaces, Inc./Electric Heat Treating Furnaces/1962
Catalog/Lufkin Rule Co./Dial Indicators/1959 TAKEN - Tom
Catalog, Price List, Brochure/Lufkin Rule Co./Precision Tools & "Miti-Mite" Magnetic Base Tools/1959 TAKEN-Glen
Brochure/Lug-All Co./Tripod Winch/1959
Catalog/Lund Mfg. Co./Jet-Cut Radius Form Tools/1958
Catalog/Edward A. Lynch Machinery Co./Deepfreeze Industrial Sub-Zero Chilling Equipment/1944
Brochure/Lynn Mfg. Co./Turrets/UNK
Small Catalog/Lyon Metal Products, Inc./Steel Equipment/1953 TAKEN - Glen
Catalog/Lyon Metal Products, Inc./Steel Equipment/1954 TAKEN - Glen
Company names starting with M:
Brochure/MB Mfg. Co. - Div. of Textron Inc./Isomode Pads for Large Machinery/1956
Brochure/M-B Products/Pneumatic Tools & Line Filters/UNK
Brochure/M. B. I. Export & Import, Ltd. - Div. of Machinery Builders, Inc./Machine Shop Equipment (Calipers, Vises, Drill Chucks, Tapping Attachments, etc.)/1958
Catalog/M & M Tool & Mfg. Co./Roto-Grind Precision Rotary Table/1963
Product Brochure/M. S. D. Tool Grinding/Grinding Fixture/1965
Catalog/Mac-It Parts Co./Socket Screw Products/1948
Booklet/Mac-It Parts Co./Socket Screw Products/UNK
Magazine Article/Machinery/Economical Short-Run Production of Elevator Parts/Vol. 56, July 1950
Product Brochures/Madison-Faessler Tool Co./Microllen Finishing Tool, Madison Adjustable Boregage/1959
Catalog/Madison Industries, Inc./Drilling, Reaming, Boring, Recessing, etc. Tooling/1960
Catalog/Madison Industries ("Affiliated with Madison Mfg. Co.)/Madison Gun Drills/UNK (1950s?)
Catalog/Magnaflux Corp./Magnetic Particle Inspection (Tools & Instructions/1956
Brochure/Magna-Lock, Inc./Sine Chucks & Magna-Vise/1958 TAKEN - Mike
Catalog/Mahr Gage Co., Inc./Bore Gages, Comparators, Micrometers, etc./1962
Foldout-Mailer/Makita/Power Tools/1990
Catalog/Robert A. Main & Sons Sales Corp./Hooks, Points & Teeth/UNK
Catalog/Main Tool Supply Corp./Local Tooling, Jig, Clamp, etc. Supplier (Mostly WESPO Products)/1961
Brochure/Malcus Tool Co./SEVO Adjustable Vises/1966?
Brochures/Mall Tool Co./Electric Drills & Saws/1942 TAKEN-Steve
Catalog/Manchester Tools - Div. of The Warner & Swasey Co./Carbide Cutoff, Grooving & Trepanning Systems/1969
Catalog/Manhattan Supply Co., Inc./Helios, JC Chesterman and Fowler Precision Measuring Tools/1946
Catalog/Manheim Mfg. & Belting Co./VEELOS Adjustable V-Belt/1954
Catalog/Manheim Mfg. & Belting Co./VEELOS Link V-Belt/1958
Catalog/Manheim Mfg. & Belting Co./Variable Speed Belts/1958
Catalog/Manheim Mfg. & Belting Co./Link-V Belting/1982
Catalog/Manufacturers Industrial Suppliers Corp./RHINO Ground Flat Stock, Tool Bits/1963
Instructional Booklet/Mapp Products/How to Weld, Braze & Solder with Mapp Gas/1980
Brochures/Marcellus Mfg. Co./Tap & Reamer Holders, Cam Rollers & Pins, Adapter Bushings/1956
Catalog/Marcellus Mfg. Co./Precision Screw Machine Tooling/1958
Catalog/Marcellus Mfg. Co./Precision Screw Machine Tooling/1959
Catalog/Marlin-Rockwell Corp./General Ball Bearings & Airframe Ball Bearings/1956
Brochures (2)/Marshall Steel Co./WaterCrat, OilCrat & AirCrat Precision Ground Flat Stock/1952
Brochure/Marshalltown Mfg. Co./Open Back, Inclinable Punch Presses/1954
Brochure/Marshalltown Mfg. Co./Open Back, Inclinable Punch Presses/UNK
Brochure/J. E. Martin Machine Co./GEM Machine Vises/1954
Brochure/Martindale Electric Co./Undercutting Saws, Mica-Millers, Cleaning Stones, Insulation Testers, Volt/Ohm Meters, Blowers & Cleaners/1982
Catalog/Masonite Corp./Masonite Presdwood/1950 TAKEN - Mark
Brochure/Master Appliance Mfg. Co./MAMCO Heat Gun/1954
Catalog/Master Electric Co./Electric Motors/1957 TAKEN-Glen (SCAN b4 sending)
Brochure/Master Pattern Co./Permanent Molds/1954
Brochure/Master Specialty Co. Inc./Optical Center-Locator/1953 TAKEN - Mike
Brochure/Master Taper Co./Master-Taper Attachment for Lathes/1967
Brochure (2)/Mathewson Machine Works, Inc./Adjustable Drill Jig/1954
Brochure/Maurey Mfg. Corp./Drives, Pulleys, Tensioners/1980
Brochures/Maxwell Co./Recess-O-Matic Tool Holders, Mastur Precision Boring Head/UNK
Brochure & Drawings/Maxwell Co./E-Z Set Boring Heads/UNK
Specification & Brochures/Maxwell Co./Recess Tool Holder Model RR Engineering Drawing & Specs, Boring & Facing Heads Brochures/UNK
Catalog/Maxwell Industries/MASTUR Precision Boring Heads/1956
Catalog/Maxwell Industries/Boring & Recessing Tools/1961
Specifications/McCrosky Tool Corp./Tool Post Replacement Blueprints/1960
Product Brochure/McDonough Mfg. Co./Sterling Universal Tool & Cutter Grinder/1951
Product Brochure/McDonough Mfg. Co./Sterling Model D Universal Tool & Cutter Grinder/1950
Catalog/McGill Mfg. Co./Nyla-K Mounted Ball Bearings/1982
Brochure/McGonegal Mfg. Co./High Speed Precision Tool Post Grinders/UNK (1950s)
Catalog/P. O. McIntire Co./POMCO Adjustable Boring & Reaming Tools/1955
Brochure/Mechanical Industries Production Co./Mighty Mite Thermostat/1954
Catalog/Meinhardt Products - Div. of Fence Painter Corp./Safety, Maintenance & Paint Products/1973
Product Brochure/Melard Mfg. Corp./"Mel-O-Ho" Coolant Aerator/1955
Catalog/Melin Tool Co./End Mills/1954
Brochure/Mera Machine & Mfg. Co./Automatic Driving Center/1954
Catalog/Mercury Clutch Div., Automatic Steel Products, Inc./Mercury Clutches/1948
Catalog/Merit Material Handling Equipment, Inc./Material Handling & Shop Equipment/1964
Catalog/Metal Carbides Corp./Tungsten Carbide Drawing Dies & Wear Resistant Parts/1946
Catalog/Metal Carbides Corp./TALIDE Tools & Tips/1946
Catalog/Metal Carbides Corp./Cemented Carbide Tooling/1967
Product Brochure/Metal Cutting Tools Inc./METCUT Pin-Mount Core Drills/1956
Catalog/Metallizing Engineering Co./METCO Type K Electronic Control-Electric Drive Metallizing Machine/1959
Catalog/Metalloid Corp./Universal Metal Cutting Agent/1953
Article/Metallurgical Labs, Inc. (METLAB Co.)/"Nitrided Tool Steels"/UNK (1940s-50s)
Catalog/Metals & Controls Corp. - Spencer Thermostat Div./Klixon Thermo Snap Built-In Temperature Controls/1955
Catalog/Metal Removal Co./Abrasive Products/1960
Brochure/Metra-Tech Corp./Metra-Scan 100 Positioning Unit/1970
Brochure/Metro-Vise Co./Model S Metro Positioner/UNK
Catalog & Brochures/Metron Instrument Co./Hand Tachometers, All Type of Tachometers and Related Equipment/1954
Catalog/W. F. Meyers Co. Inc./MEYCO Carbide-Inserted Drill Jig Bushings/1951
Catalog/W. F. Meyers Co. Inc./MEYCO Carbide-Inserted Drill Jig Bushings/1954
Brochures/W. F. Meyers Co., Inc./MEYCO Precision Circular Cutters & Carbide-Inserted Drill Jig Bushings/UNK
Operating Instructions/W. F. Meyers Co., Inc./Radiform Wheel & Tool Former/1952
Brochure/Micromatic Hone Corp./Odee-Hone External Surface Hone/UNK
Catalog/Micromatic Hone Corp./Honing Machines (Mr. Giesler had inquired about equipment for honing model aircraft engines)/1945
Brochure/Micrometrical Mfg. Co. (Formerly Physics Research Co.)/"The Final Step in Tool Sharpening/1952
Product Booklet/Micrometrical Mfg. Co. (Formerly Physics Research Co.)/Practical Features & Applications of The Profilometer/1954
Brochure/Micrometrical Mfg. Co./Amplimeters/1954
Brochure/Micrometrical Mfg. Co./Surface Finish Measure/1953
Brochure/Micrometrical Mfg. Co./Profilometer/1953
Brochure (2)/Micrometrical Mfg. Co./Profilometer/1954
Catalog/Micrometrical Mfg. Co./Profilometer Equipment - Shop Equipment for Measuring Surface Roughness Height/1953
How To Guide/Micrometrical Mfg. Co./How To Specify Surface Roughness/1952
Catalog/Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./Micro-Switch Switches, Micro-Tips Snap-Action Switches/1984?
Catalog/Micro Switch Corp./Precision Snap Action Switches/1941
Brochure/Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./Micro-Switch Switches, Micro-Tips Snap-Action Switches/1984?
Newsletter/Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./"Uses Unlimited"/UNK (1950s?)
Catalog/Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./Micro-Switch Switches, Micro-Tips Snap-Action Switches/1953
Catalog/Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./Industrial Enclosed Switches/1955
Mailer/Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./Micro-Switch Switches/1955
Brochure//Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./Precision Snap-Action Switches/UNK
Catalog/Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./Honeywell Mercury Switches/1984?
Catalog/Micro Switch - Div. of Minneapolis-Honeywell Regulator Co./Switches for Industry/1956
Brochure/Midwest Automation Inc./Centra-Matic Live Internal Steady Rest/UNK (Post-1963)
Instructional Booklet/Midwest Precision Castings Co./"How to Design Precision Investment Castings/1954 TAKEN - Mike
Brochures/Mill-Rose Co./Industrial Brushes/1959
Catalog/Millers Falls Tools/Electrical Tools/1943 TAKEN-Steve
Guide/A. Milne & Co./Tool Steel Selector/UNK
Product Brochure/Milwaukee Lock & Mfg. Co./Heat-Blo Guns/1969
Catalog/Mimik Tracers Inc./Hydraulic Tracer for Vertical Turret Lathes & Turning Machines/1973
Catalog/Miniature Precision Bearings, Inc./Miniature Ball Bearings/1953
Instructional Booklet & Catalog/Minnesota Mining & Mfg. Co. (3M)/"Sealers as Engineering Materials" & Catalog of Sealers, Coatings & Adhesives/1953
Instructional Booklet & Catalog/Minnesota Mining & Mfg. Co. (3M) ("In Cooperation with Hammond of Kalamazoo")/Carbide Tool Sharpening Method & Machine/UNK (1950s)
Mailer/Minnesota Mining & Mfg. Co. (3M)/General Info/1953
Brochure/Modern Mfg. Co., Inc./Chatterless Boring Bar/UNK
Catalog/Modernair Corp./Fluid Power Devices/1955
Brochure/Modglin Co., Inc./"PERMA" Cleaning Products & Implements/1955
Product Brochure/Mohawk Tools, Inc./Mohawk Model 302 Drill Sharpening Machine/1971
Product Brochure/Mohawk Tools, Inc./Mohawk Model 308 Subland Step-Angle Grinder/1974
Catalog/Mohawk Tools, Inc./Drills, Reamers, etc./Multiple Years 1954 - 1964 TAKEN - Mark
Brochure/Mohr Tool & Mfg. Co./"Handy Six" Threading Die Holder/1958
Catalog/Monarch Machine Tool Co./Monarch Lathes/1942 TAKEN-Steve
Product Brochure/Monarch Machine Tool Co./Specifications & Features Monarch 12" x 30" Model C Helical Geared Toolmaker's Lathe/1943 TAKEN-Steve
Catalog/Monroe Engineering Products, Inc./Mechanical & Magnetic Fixtures with Setup Blueprints/1963
Catalog/Montgomery & Co, Inc./Machine Tool Attachments, Work Holding Tools, Surface Plate Equip., Light Machine Tools/1960 TAKEN-Glen
Brochure/Montgomery & Co., Inc./Tools & Methods for Machinists (Drills, Vises, Die Grinders, etc.)/1956
Catalog/George W. Moore, Inc./Set Screws/1956
Brochure-Mailer/H. E. Moore Co./HEMCO Fast Acting Retractable Tool Holder/1972
Product Brochures/Moore Special Tool Co./Model 2 Moore Jig Grinder & Moore Model 2 Precision Jig Borer/1953 TAKEN - Mike
Catalog/Moraine Products Div. of GM Corp./DUREX Tools List of Bronze Bearings/1940
Brochure/Morey Machinery Co., Inc./Lathes, Shapers, Profilers, Milling Machines/1951 TAKEN-Mike
Brochure/D. C. Morrison Co./Morrison 1" Keyseater/1971?
Catalog/Morse Chain Co./Stock Drive, Chains, Belts, Systems/1948
Catalog C45-56/Morse Chain Co./Stock Drive, Chains, Belts, Systems/UNK
Catalog/J. W. Mortell Co./NoDrip Condensation Stopper (Tape and Liquid)/1957
Brochure/Morton Machine Works/Fixture Clamp & Details/1953
Catalog No. 4/Morton Machine Works/Fixture Clamps & Standard Fixture Details/1950
Brochure (2)/Morton Machine Works/Fixture Clamps & Standard Fixture Details/UNK (1950s)
Catalog/Motch & Merryweather Machinery Co./Notching, Grinding and Cut-Off Blades/1956
Brochure/Motor Tool Mfg. Co./Live Centers/1952
Brochure/Muelhausen Spring Corp./Die Springs for Presses/UNK
Catalog/Mueller Brass Co./Brass & Bronze Forgings/UNK
Catalog/Mueller Brass Co./Brass, Aluminum & Bronze Forgings/1953
Catalog/Mueller Brass Co./Fabricated and Mill Products/1946
Catalog/Mueller Brass Co./Forgeable 600 Series Bearing Metal/1958?
Catalog/Mueller Brass Co./Fabricated & Mill Products/1946
Catalog/Mueller Brass Co./Alloys with Equivalent Specs (Fed, Mil, Navy, Army)/1953
Catalog/Mueller Electric Co./Battery and Test Clips & Insulators/1953
Brochure/Multiplex Co./Multiplex Motorized Indexing Head/1956
Product Brochure/Multi-Point Tool Co., Inc./4-way Quick Change Tool Post/UNK (Post-1963)
Brochure/Muskegon Tool Industries, Inc./Spade Drills/1961
Catalog/Muskegon Tool Industries, Inc./Cutters, Reamers, Bars, etc./1960
Brochure/Mutual Engineering Service/Diametrick Inside Diameter Gage/1954
Brochure (2)/Mutual Engineering Service/Diametrick Inside Diameter Gage/1955
T
twertsy
Reedville, VA
Company names starting with N:
Product Brochure/J. M. Nash Co. - Nash-Zempel Tools/Boring Bar Insert/UNK - Prob Pre-War
Product Brochure/J. M. Nash Co. - Nash-Zempel Tools/Micrometer Adjustable Boring Bar/1942 TAKEN-Steve
Product Brochure/J. M. Nash Co. - Nash-Zempel Tools/Counter Boring Tool/UNK - Prob Pre-War
Catalog/National Acme Co./Self Opening Die Heads & Collapsible Taps/1950
Product Brochure/National Automatic Tool Co./Model E-5 Driller-Tapper/UNK TAKEN - Mike
Mailer/National Acme Co./Collets/UNK
Product Brochures/National Acme Co./"Fette" Self-Opening Thread Rolling Heads/1954
Catalog No. 3/National Bearings Co/Bearings/UNK (prob 40s/50s)
Catalog/National Broach & Machine Co./"Red Ring" Products (Machines)/1954
Catalog/National Machine Tool Co./Tooling/1962
Product Brochure/National Motor Bearing Co./"Micro-Torc" Leather Oil Seals/1956
Catalog No. 44 Supplement/National Motor Bearing Co./Seals/1939
Catalog/National Stationers/Visible Products Displays/1953
Publication/National Twist Drill & Tool Co./Design & Application of Form Milling Cutters/1957
Product Brochure/Nebel Machine Tool Co./Model LA Medium Duty Lathe/1954 TAKEN-Mike TAKEN - Mike
Brochure/Nebel Machine Tool Co./Engine Lathes/1954
Catalog/James Neill & Co., Ltd./Eclipse Saws, Hand Tools, Lathe Tools, Magnetic Tools, Permanent Magnets/1967
Product Pages/Karl A. Neise, Inc./Vises, indexing tables, dividing heads/1957
Product Brochure/Karl A. Neise, Inc./Boremaster & R. B. Cutting Tools/1952
Product Brochure/Karl A. Neise, Inc./Boremaster, Ringspan, Tool Holders, Gauges, Prewo Vises, etc./1953
Product Brochure/Karl A. Neise, Inc./Boremaster/1962
Catalog Mailer/Karl A. Neise, Inc./Schnorr Disc Springs/UNK
Catalog/Nelco Tool Co./Mills, Cutters, Tooling/1955
Product Brochure/D. L. Nelson Manufacturing Co./Turning & Facing Tools/1970
Catalog No. 12-53/Nesen Diamond Tool Corp./Diamond Wheels and Hones/1953
Catalog/Nesen Diamond Tool Corp./Wheel Dressing Tools/1954
Brochure/Newage Industries, Inc./Electric Pen, Transformer/UNK
Product Brochure/Newage International Inc./RINDIS Model EF 52/12 Universal Machine/1953
Catalog/New Albany Machine Co./Punch Presses/1956
Brochure/New Britain Machine Co./New Britain Automatics/1947
Brochure/New Britain Machine Co. - New Britain-Gridley Machine Div./Automatic Chucking Machines/1951
Letter/New Britain Machine Co. - Cir-Cut Div./Invitation to Vist Plant/1953
Product Brochure/Newcomer Products, Inc./RC Milling Cutters/1957?
Product Brochure/Newcomer Products, Inc./NewMet High Speed Cutters/1958?
Product Brochure/New England Tap Co./NETCO Cromeclad Taps/1955
Product Brochure/New England Tap Co./NETCO Cromeclad Taps/1974
Catalog/Newton Insert Company/Keenserts Inserts & Studs/1962
Catalog/New York Belting & Packing Co./Timing Belt Standard Drive Manual/1957
Brochures/Niagara Cutter (Div. of Bollier-Damerell)/Special Cutting Tools/1957
Catalog/Niagara Cutter (Div. of Bollier-Damerell)/Special Cutting Tools/UNK
Catalog/Nice Ball Bearing Co./Ball Bearings & Related/1935
Catalog/W. H. Nichols Co./Milling Machines/1954
Product Brochures/W. H. Nichols Co./Expanding Mandrels & Arbor Presses/UNK (poss 1943?) TAKEN-Steve
Product Brochure/Nichols-Morris Corp./Ellis Rapid Indexer/UNK TAKEN - Glen
Catalog/W. H. Nicholson & Co./Thermostatic Steam Traps, Expansion Traps, Strainers/UNK
Catalog/Nielson, Inc./Live Centers/1954
Catalog Supplement/Noble & Stanton, Inc./Diagrams of Component Parts of Jigs & Fixtures/1949
Product Brochure/Nobur Manufacturing Co./Deburring tool/1954
Product Brochure/North American Philips Company, Inc./Norelco Geiger Counter X-Ray Spectrometer/1951
Product Brochure/C. A. Norgren Co./Spray Lube System/1954
Catalog/Norma-Hoffmann Bearings Corp./Bearings/1956
North American Viking Drill Co./Viking Twist Drills/1968 TAKEN - Tom
Tool Catalogs/Northwestern Tool Co./Setup Equipment/1985, Cat 20 (1952), Cat 29 (UNK), 1984, Cats 33B & C (UNK), Cat 21 (2) (1954)
Brochure/Northwestern Tool & Engineering Co./Strap Clamps/UNKBrochure/NOVI Tool & Machine Co./Slotted Sleeves/UNK
Product Brochure/Nu-Matic Grinders, Inc./Pneumatic Grinder/UNK
Catalogs/Numberall Stamp & Tool Co./Marking Tools/1982, 1980, 1969
Catalogs/Nusbaum & Co. Inc./Belting, Hose & Industrial Rubber Products/1959, 1960, 1963, 1970
Mailer/Nutting Truck & Caster Co./Trucks and casters/1961 ***TAKEN
Catalog/Nutting Truck & Caster Co./Trucks and casters/1960 ***TAKEN
Company names starting with O:
Catalog/Ohio Machine Tool Co./Machine Tools/1954 TAKEN - Mike
Catalog/Ohio Nut & Bolt Co./Stock Parts Catalog/1960 TAKEN - Mark
Catalog/Ohio Nut & Bolt Co./Ohio Weld Screws/1957
Bulletin 552/Ohio Nut & Bolt Co./Ohio Weld Screws/1956
Catalog/OK Tool Co. Inc./Single Point Tools with Inserted Bits/1957
Catalog/Oliver Instrument Co./Die Making Machines/1956 (I have 2) 1 Copy TAKEN-Mike
Catalog/Oliver Instrument Co./ACE Universal Tool and Cutter Grinders/1959
Product Brochure/Olson Industrial Products Inc./Wedge-Lock Turret/1953
Product Brochure & Spec Sheet/Omark Industries/Winslomatic HC Drill Point Grinder/1972
Quotation & Brochure/Opto-Metric Tools Inc./Microfix Micrometer/1959
Quotation & Brochure/Opto-Metric Tools Inc./Precision Levels/UNK (1955?)
Instructional Booklet/Orange Roller Bearing Co./Roller Bearings Lubrication Guide/UNK (Pre-1963, Prob 1956)
Engineering Data/Orange Roller Bearing Co./Orange Roller Bushings/UNK (Pre-1963)
Catalog/Orange Roller Bearing Co./Roller Bearings/1956
Catalog/Kurt Orban Co. Inc./Precision Machine Tools/1960
Catalog/Wm. H. Ottemiller Co./Screw Machine Products/1954 ('57 Price List)
Company names starting with P:
Catalog/P & F Lite Co./Commercial, Industrial & Residential Lighting/1953
Product Brochure/Pace Engineering Co./Live Centers/1959
Product Flyers/Pacific Tool & Mfg. Co./"Tri-Mark" Quick Change Chuck/1959
Catalog/Palmer-Shile Co./Materials Handling Equipment/1954
Brochure/Pannier Corp./Steel Stamps & Equipment/1986?
Catalog/Parker-Kalon/Self Tapping Screws/UNK (Pre 1963)
Catalog/Parker Stamp Works, Inc./Marking Dies/1953
Catalog/J. Parkinson & Son, Ltd./Gear Testers/UNK
Product Data Sheet/Parlec Inc./Autofacer 2100/UNK]
Catalog/Pass & Seymour, Inc./Wiring Devices/1956 TAKEN-Glen
Brochures/Peck & Harvey/Whiteprinters/1953
Product Brochure/Peddinghaus/Pipe Vises/1967?
Product Brochure/Peddinghaus/Bench Vises/1968?
Product Brochure/Peddinghaus/Bench Vises/1969
Catalog/Penn Engineering & Mfg. Corp./Template Drill Bushings/1956
Catalog/Penn Pipe Hanger Co./Pipe Hangers/UNK (Pre 1963)
Penn Scientific Products Co./Diamond Lapping Compound/UNK
Catalog/Pennsylvania Malleable Iron Corp/Thumb Screws & Nuts/UNK TAKEN-Glen
Brochure/Perfecthole Industries/Speed Lap/UNK (Pre-1963)
Brochure/Perkins Machine & Tool Co./Precision Spring Coiler Machines & Tools/1960
Mailer/T. G. Persson Mfg. Co./Deburring & Chamfering Machine/UNK
Product Brochure/Jos. Petermann/P-7 Automatic Lathe/1954
Brochures/Physicists Research Co./Precision Measuring Devices/1950
Product Brochure/Pi-Tape/Pi-Tape Diameter Measurement/UNK
Product Brochure/Pioneer Broach Co./VM 215 Broaching Machine/1954
Catalog/Pipe Machinery Co./Gages, Pipe Making Machines & Tooling/1952?
Catalog/Pittler Maschinenfabrik (Germany)/Turret Machines/UNK (1950s)
Catalog/Pittsburgh Plate Glass Co./Wire Wheels & Brushes/1950 TAKEN - Mark
Catalog/Pittsburgh Stamp Co. Inc./Brass Checks, Metal Tags, Tag Markers/UNK (Guessing 30s-50s) TAKEN - Mark
Catalog/Pivot Punch & Die Corp./Precision Punches/1953
Engineering Drawings/Joseph Player/Horizontal Boring Mill/UNK (1950s)
Catalog/Podlin Tool Co. (Po-Ro Products)/Machine Shop & Tool Room Specialties/1957
Product Brochure/Poly-Choke Co./PC-101 Sharpening Fixture/UNK (Post 1963)
Catalog/Pope Machinery Corp./Precision Spindles for Internal Grinding/1961
Catalog/Pope Machinery Corp./Precision Spindles & Boring Machines/UNK
Catalog/Portable Electric Tools, Inc. (PET)/Electric Tools/UNK (1952?) TAKEN - Mark
Brochure/Portable Electric Tools, Inc./Charts-Starting Torque vs. Voltage - Permanent Magnet Synchronous Timer Motor/1955
Brochures/Portage Double Quick Tool Co./Quick Change Tools, Boring Tools, etc./UNK (Pre-1963)
Catalog/Portage Double Quick, Inc./"Tap A troll" Controlled Tapping System/1969
Catalog/Portage Double Quick, Inc./Quick Change Tool Holders & Adapters, Cut-Off Tools, Boring Bars, etc./1957-1959
Catalog/Porter-Cable Machine Co./Abrasive-Belt Machines/1952
Catalog/Porter Precision Products/Precision Punches/UNK
Catalog/Potter & Johnson Co. (Subsidiary of Pratt & Whitney, Division of Niles-Bement-Pond Co.)/Automatic Turret Lathes/UNK
Product Brochure/Powergrip, Inc/Power Grip Chuck Actuators/1960
Product Brochure/Powergrip, Inc/Power Grip Power Chucks/1962
Product Brochures/Pratt Burnerd America/Power Chucks/1978
Catalog/Pratt & Whitney - Div. of Niles-Bement-Pond Co./Monocone & Duocone Dies & Die Holders/1952
Catalog/Pratt & Whitney - Div. of Niles-Bement-Pond Co./Cutting-Off Blades/1953
Catalog/Pratt & Whitney - Div. of Niles-Bement-Pond Co./Precision Gage Blocks/1952
Catalog/Pratt & Whitney - Div. of Niles-Bement-Pond Co./Precision Gage Blocks/1951
Catalog/Pratt & Whitney - Div. of Niles-Bement-Pond Co./Model C Thread Millers/1956
Catalog/Prebco Bushing Co./Precision Miniature Drill Jig Bushings/UNK
Brochure/Precise Optical Co./Micro-film Reader/1960?
Catalog/Precision Equipment Co./Industrial Equipment/1957
Handbook (2)/Precision Rubber Products Corp./O-Ring & Dyna Seal Packings/1953
Brochure/Precision Spring Corp./Die Springs with Load & Deflection Chart/UNK (1950s)Catalog/Precision Twist Drill & Machine Co./Twist Drills/1953 TAKEN-Glen
Catalog/Precision Twist Drill & Machine Co./Twist Drills/1955 TAKEN-Glen
Brochures/H. P. Preis Engraving Machine Co./PANTO Dividing Head, Engraving Machines/1954
Product Brochure/Price Machine Products/Paragon Self-aligning Sub-Presses/1953
Catalog/Procunier Safety Chuck Co./Tapping Equipment/1954 TAKEN-Glen
Catalog/Procunier Safety Chuck Co./Tapping & Drilling Equipment/UNK (1970s-80s) TAKEN-Glen
Brochure/Production Devices Inc./Airlox Pheumatic Vises/1952
Brochure/Production Instrument Co./Stroke Counters/1954
Brochures/Production Parts Co./Tool Holder Bushings, Soft Blank Chuck Jaws, Spade Drills/UNK
Catalog/Producto Machine Co./Die Sets & Die Accessories/1957
Catalog/Progressive Welder Co./Resistance Welders/1944
Brochure/Thomas Prosser & Son/Carbide Tool Grinders/1952
Catalog/Thomas Prosser & Son/Carbide Tool Grinder Machines/1953
Brochure/Pull-Gear Co./Drill Press Speed Reducer/UNK (1950s)
Brochure/Punch-Lok Co./Hose Clamps/UNK
Catalog/Punch Products Corp./Punching & Notching Equipment/1965
Catalog/Puritan/Residential Light Fixtures/1940s-1950s)
Company names starting with Q:
Product Brochures/Q-C Engineering Products/Standardized Fixtures/UNK
Product Brochures (3)/Q-C Engineering Products/Vise Fixtures/UNK (wartime?)
Product Brochure/Q-C Engineering Products/Index Tables/UNK
Brochure/Q-C Engineering Products/Standardized Production Tooling/UNK
Brochure/Q-C Engineering Products/Actuating Q-C Fixtures (converting from hand to air operated) Airlok Motors/UNK
Catalog/Q-C Engineering Products/Index Tables/1955
Product Brochure/Q-C Engineering Products/"Sure Clamp" Fixtures/UNK
Product Brochure/Q-C Engineering Products/Clamp Locks and Foot Control Valves/UNK
Reference/Q-C Engineering Products/Tool Engineers Reference & Standards Book/1948
Catalog/Q-T Tool Co., Inc./H.S.S. Cutting Tools/1970
Catalog/Quadriga Mfg. Co./Washers & Metal Stampings/1965
Catalog/Quality Tool Works/Woodruff Keyway Cutters & Special Cutting Tools/1956
Catalog/Q-T Tool Co./H.S.S. Cutting Tools/1970
T
twertsy
Reedville, VA
Company names starting with R:
Catalog/R.B. Tool Co., Inc./Boring Tools, Tool Holders, Centers/UNK
Brochures/R.B. Tool Co., Inc./Precision Tools/UNK
Catalog/R.B. Tool Co., Inc./Boring Tools, Tool Holders, Centers, etc./1962
Booklet/R & L Tools/R & L Turning Tool/UNK (likely ca. 1950)
Catalog/R & L Tools/Precision Tools for Screw Machines/1953
Brochure/R & L Tools/Tap & Die Holder/UNK
Correspondence/Racine Universal Motor Corp./Electric Motor Specs/1940
Catalog/Radiator Specialty Co./"TiteSeal" Solder Seal/1957
Instruction Manual/Realistic - Radio Shack Div. of Tandy Corp./Model CTR-8 Radio Cassette Recorder1970
Brochure/Rahn Granite Surface Plate Co./Surface Plates/1953 TAKEN - Mike
Catalog/Ralmike Tool Corp./Tools & Gages/1964
Catalog/Ramsey Corp./"SpirOLox" Retaining Rings (Specs)/1954
Catalog/Ranco Inc./Controls for Refrigeration/1955
Catalog/Raybestos-Manhattan, Inc./Industrial Rubber Products/1969?
Catalog/Raymac Div. of Dexco Corp./Solid Carbide Tools/1956
Catalog/Raymond Mfg. Div. - Associated Spring Corp./Springs/1959
Catalog/Ready Tool Co./Red-E-Centers/1958 TAKEN - Mike
Catalog/Ready Tool Co./Red-E-Centers & Dogs/1958 TAKEN - Mike
Catalog/Red Jacket Mfg. Co./Water Systems & Power Pumps/1949
Catalog/Reed & Prince Mfg. Co./Recessed Heads Screws & Drivers/1941
Brochures/Reed Rolled Thread Die Co./Thread Rolling Attachment/UNK
Brochure (2)/Reed Rolled Thread Die Co./Reed Knurls for Circular Pitch Knurling/1956
Brochure/Reed Rolled Thread Die Co./Thread Rolling Equipment/UNK
Brochure/Reed Rolled Thread Die Co./Reed Knurls for Circular Pitch Knurling/1970
Instructions & Data Book/Reed Rolled Thread Die Co./'Circular & Diametral Pitch Knurling"/1970
Brochure/Reed Small Tool Works/Reed Knurls/UNK
Catalog/Regal Div. - Beloit Tool Corp./Taps, Dies, Reamers, Milling Cutters, Gages/1970
Catalog 59-2 (2)/Regal Div. - Beloit Tool Corp/Taps, Drills, Gages/UNK (1959?)
Catalogs/Reid Tool Supply Co. (Distributor)/Machine Shop Tooling & Equipment/1968, 1969, 1981, 1982, 1984 1968 TAKEN - Glen
Catalog/Reiff & Nestor Co./Free Cutting R/N Taps/1951
Catalog/Reiff & Nestor Co./Free Cutting R/N Taps/1968
Catalog/Relco Carbide Tool Co./HS & Carbide Tools/1954
Instructional/Reliance Electric & Engineering Co./Reliance Motor Selector/1954
Catalog/Reliance Electric Co./Industrial A-C Motor Catalog/1984-85
Catalog/Reltool Corp./Metal Cutting Tools/UNK (Pre-1963)
Product Brochures/Remington Arms Co./Model 450 Stud Driver/1955 TAKEN - Glen
Brochure/Remont Mfg. Co./Solder for Stainless Steel/1953
Product Brochure/REO Motors, Inc./MW-2181 Kit - Silent Muffler/1954
Product Brochure/Retor Developments Inc./"MIMIK" 2000 Series Vertical Milling Machines/UNK
Catalog (2)/Reuland Electric Co./Industrial Pedestal Grinders & Buffers/UNK
Catalog/Revere Copper & Brass Corp./Aluminum Extruded Products/UNK (Pre-1963)
Product Brochure/Rev-Del Mfg. Co./Revolving Turret Head Adaptor/1952
Catalog/Rex Chainbelt Inc./Self-Aligning Roller Bearings/1950?
Catalog, Brochures/Reynolds Machine & Tool Corp./Multiple Spindle Drill Heads, Pratt Burnerd Self Centering Chucks, Criterion Machine Works Tooling, Universal Houdaille Tooling, RMT Lead Screw Tap Units, Procunier, Cushman Burs & Bits/1979?
Folder-Brochures/Reynolds Metals Co./Metal Roofing & Walls/1958
Catalog/J. E. Rhoads & Sons/Texalon All-Synthetic Belting/1958
Product Brochure/Rice Pump & Machine Co./Milwaukee Die Filer/UNK
Brochure/Richard Brothers Div. - Allied Products Corp./Punches & Dies/1953
Catalog/Richard Brothers Div. - Allied Products Corp./Punches & Dies/1953
Catalog/Richard Brothers Div. - Allied Products Corp./Punches & Dies/1955
Brochures/J. A. Richards Co./Multiform Bending Machines/1953
Brochures/J. A. Richards Co./Multiform "Big Brother" Bending Machine/1954
Brochures/J. A. Richards Co./Multiform Bending Machines/1958
Brochures/J. A. Richards Co./Multiform Bending Machines/1967
Brochures/J. A. Richards Co./Multiform Bending Machines/1982
Catalogs/J. A. Richards Co./Multiform Bending Machines/1983
Brochures/Richards Micro Tool Co. Inc./Center Drills, End Mills/ 1962
Catalog (2)/Rickert & Shafer Co./Tap & Die Heads/1964
Product Brochure/Supreme Products Corp. - Div. Ridge Tool Co./Chucks/1964
Catalog/Ridge Tool - Subsidiary of Emerson Electric Co./Ridgid Products/1980 TAKEN - Glen
Brochure/Ridge Tool Co./LongGrip Pipe & Screw Extractors/1943? TAKEN - Glen
Manual of Information/Rife Ram & Pump Works/Hydraulic Water Rams/1949
Data Cards/Ring Punch & Die Co./Punch & Button Die Data Cards/1952
Catalog No. 105 (3)/Ring Punch & Die Co./Punches & Dies/1957
Catalog/Rite-O Tool & Gage Co./Gages & Gaging Fixtures/1958
Info Folder/Riverside Foundry/Metal Products/UNK (1980s?)
Brochures/Riverside Mfg. & Electrical Supply Co./Wiring Harnesses, Cords, Switches, Relays, etc./1952
Brochure/Rivett Lathe & Grinder, Inc./Collets & Chucks/1956 TAKEN - Glen
Product Brochure/Robbins & Myers, Inc./Type J Electric Wire Rope Hoist/1960
Catalog/Robbins & Myers, Inc./Matched Motor Parts/1944 TAKEN - Tom
Brochure/Rockford Clutch Division - Borg-Warner/Clutches & PTOs/1948
Catalog/Rockford Clutch Division - Borg-Warner/Clutches, Gear Reduction Units, & PTOs/1956
Product Brochure/Rockford Clutch Division - Borg-Warner/Pull-More Multiple Disc Clutches/1956
Product Brochure/Rockford Die & Tool Works, Inc./Rocket Tap Sharpener/1955
Brochures/Rockford Engineered Products Co./Repco Jigs, Arbors, Vises, Live Centers, Tool Holders/1957-59
Brochures/Rockford Engineered Products Co./Repco 2-Piece Vise/1956
Brochures/Rockford Engineered Products Co./Repco Timesaving Tools/1978
Catalog/Rockford Iron Works/Presses/UNK (ca. 1950)
Exploded Diagram - Poster/Rockford Machine Tool Co./12" Economy Lathe/UNK TAKEN - Mike
Catalog/Rockwell International/Commander Drill Heads/1979
Catalog/Rockwell Mfg. Co./Machine Tools/1966 TAKEN-Thomas
Product Brochure/Rockwell Mfg. Co./Delta Vertical Milling Machine/1962
Catalog/Rockwell Mfg. Co./Rockwell Delta Industrial Woodworking Machines/1967 TAKEN-Thomas
Brochure/Rockwin Mfg. Co./Knurlmaster Hand Knurler/UNK
Product Brochure/Rockwood Pulley Mfg. Co., Inc./Auto-Tension Motor Base/1954 TAKEN - Glen
Catalog/Rohm & Haas Co./Plexiglass Replacement Glazing/1959
Catalog/Rohm Tool Corp./Chucking Tools/1980
Catalog/Roller Bearing Co. of America/RBC Roller Bearings/UNK (WWII-type graphics)
Product Brochure/Roll-In Saw Co./Band Saw with Power Feed Table/UNK TAKEN - Mike
Brochure/Rolyan Metal Products (succeeded by L. C. Kenney Co.)/Legs & Buttons for Jigs & Fixtures/1947
Brochure/Rome-Turney Radiator Co./Finned Tubing/1950
Catalog/Rotary Seal Co./Seals for Rotating Shafts/1952
Product Brochure/Rothlan Corp./Marla Open Gear Spray Lubricant/UNK
Catalog/Roton Products Div. - Anderson Co./Power & Motion Transmission/1961
Product Brochures/H. B. Rouse & Co./Rouse Hand Miller/1951-1954
Catalog/Rowbottom Machine Co./Cam Milling & Grinding Machines/1956
Brochure/Royal Electric Co./Electric Cord Assemblies/1955 TAKEN - Tom
Product Brochure/Royal Oak Tool & Machine Co./DS Grinder/1947
Catalog/Royal Oak Tool & Machine Co./Gage Blanks/1955-57
Catalog/Royel Tools/Tool Holders/1956
Catalog/Royersford Foundry & Machine Co., Inc./Machine Line/1950 TAKEN - Ben
New Product Brochure/Royersford Foundry & Machine Co., Inc./22" Power Drill/UNK TAKEN - Ben
Catalog/Ruland Mfg. Co., Inc./Collars & Couplings/1981
Catalog/Rusnok Tool Works/Mill Heads/1946 TAKEN-Glen
Brochure/Russell Mfg. Co./Rusco Ultra Speed Transmission Belt/1958
Quote/Russell Holbrook & Henderson, Inc./Drilling Attachments/1956
Catalog/Rust-Lick, Inc./Rust Prevention Solutions/1959
Catalog/Rust-Oleum Corp/Rust Prevention Solutions/1955 TAKEN - Glen
T
twertsy
Reedville, VA
Company names starting with S:
Brochure/S & D Engineering Co./Studler All-Purpose Grinding Fixture/UNK (Pre-1963)
Catalog/S-P Manufacturing Corp. (Bassett Company)/Power Chucks, Air Cylinders & Valves/1951
Catalog & Engineering Diagrams/Saginaw Steering Gear Div. of GM/Steering Mechanisms (Screws, Races, Splines, etc.)/1978
Info Sheets/Sales Service Machine Tool Co./Punch Presses/1953
Info Sheets/Sales Service Machine Tool Co./Punch Presses/1954
Brochure/Harry Sall & Co./Shop Hardware/1948
Brochure/Salvo Tool & Engineering Co./Thread-Rolling Attachment for Screw Machines/UNK
Brochure/Salvo Tool & Engineering Co./Thread-Rolling Attachment for Turret Lathes/UNK
Mailer/Charles Salzberg & Co./Spinning Lathes/UNK
Catalogs (2)/Sandvik Steel Inc./Coromant Carbide Blanks, Inserts, Tools/1959
Catalog/Sandvik Steel Works Co., Ltd/Coromant Carbide Tipped Tools/1953
Catalog/Sanford Mfg. Co./Benchtop Surface Grinders & Accessories/1950 TAKEN-Glen
Brochure/Saxton Mfg. Corp./Kant-Twist Clamps/UNK
Brochure & Quotation/George Scherr Co./Leitz Toolmakers Microscope/1953
Catalog No. 18/Schrillo Aero Tool Engineering Co./Cutting Tool & Gage Catalog/UNK (1940s) TAKEN-Steve
Instructional Bulletins/Sciaky Brothers, Inc./Resistance Welding at Work/UNK (Pre-1963)
Instructional Bulletins/Sciaky Brothers, Inc./Resistance Welding at Work/1946
Quotation & Brochures/George Scherr Co., Inc./Koepfer and CIMA Gear Hobbing Machines/1956
Brochure/Scientific Machine Co./Onteco Outboard Mill Support/1963
Brochure/C. U. Scott & Son/Super Scottsonizing (SS Hardening)/1953
Brochure/Screw Machine Tool Co./Shaving Tool Holders/1954
Catalog/Lloyd Scruggs Co./4 Pole Shaded Motors/1954
Brochure/Scully Machine Co./Thread Wire Holder/1952
Catalog/Scully-Jones & Co./Drill Stops/1950-52
Brochure/Scully-Jones & Co./Drill Stops/1952
Catalog/Scully-Jones & Co./Automatic Recessing Tools/1948
Catalog/Scully-Jones/Standard Tooling Combinations/ca. 1968
Tech. Bulletin/Sealube Co./Z.R.C Galvanizing Solution/1959
Catalog/Seibert & Sons, Inc./Precision Tooling/1950 TAKEN - Mark
Brochure/Self Centering Spring Chuck Co./Self Centering Spring Chuck/1951
Brochure/Self Centering Spring Chuck Co./Self Centering Spring Chuck/UNK (Pre-1963)
Brochures/Seneca Falls Machine Co./Model LR "So-swing" and other Lathes/UNK
Product Bulletin/Seneca Falls Machine Co./Automatic Work Driver (also has lathes, drilling & centering machines)/1960
Catalog/Seneca Falls Machine Co./Machine & Engineering Drawings/1950
Brochures/Service Machine Co./Rousselle Presses/1950
Catalog/Service Machine Co./SEMCO "32 Year Brake Dies," Brakes, Folding Machines, Grinders, etc./1953
Product Brochure/Service Machine Co./Nibbler Press/UNK
Catalog/Set Screw & Mfg. Co./SETKO Set Screws/1954
Catalog/Set Screw & Mfg. Co./SETKO Set Screws/1957
Brochure/Set Screw & Mfg. Co./Self-Tapping Set Screws/UNK
Brochure/Severance Tool Industries/Countersinks/1945?
Catalog/Severance Tool Industries/Midget Mills (tooling)/1950
Leaflet/Severance Tool Industries/Midget Mills (tooling)/1950
Catalog/Severance Tool Industries/Cutting Tools/1975
Brochure/Louis A. Sgro Co./Industrial Diamond Tools/UNK
Catalog/Shafer Chain Belt Co./Roller Bearings/1959
Catalog/Shamrock Tools/Precision Inspection Equipment/1968
Brochure/Shauer Mfg. Corp./Speed Lathes/1950
Brochures/Shearcut Tool Co./Thread & Rotary Broaches, End Mills & Taps/1956
Catalog/Shearcut Tool Co./Precision High Speed & Cobalt Shearcutter End Mills/1969
Unk - Unopened Manilla Envelope/Shear Speed Chemical Products/Soluble Oil?/1953
Catalog/Sheffield Corp./Sheffield Gauges/1948
Catalog/Sheldrick Mfg. Co./Boring & Cutting Tooling/1952
Product Brochure/Sheridan Products/B-K 7 Cement/1954
Brochure/Max Shur, Inc./Drill Rods, Drill Indexes, Set Cap Screws/1960
Brochure/Sibley Machine & Foundry Corp./Model E-25 Drill Press/1954 TAKEN - Karl
Brochure/Sierra Engineering Co./Miniature Mechanical Chains/1951
Catalog/Siewek Tool Co./Clamps, Fixtures, Spring Plungers, Torque Screws/1967
Brochure/Siewek Tool Div. of Domestic Industries, Inc./Die Table & Shop Lifter/UNK
Catalog/Siewek Tool Div. of Domestic Industries, Inc./Clamps (engineer drawings & specs/1943 TAKEN-Steve
Product Brochure/Simmons Machine Tool Corp./No. 2 Precision Turret Lathe/1951
Brochure/Simmons Machine Tool Corp./Micro-Speed Turret Lathe/1944?
Info Sheet/W. T. Simmons Co./Triangle Thread Measurement Method/1952
Catalog/Skandinaviska Chuckfabriks Aktienbolaget (SCA)/Chucks & Accessories/1958
Product & Accessories Price List/Simmons Machine Tool Co./No. 2 Simmons Micro-Speed Turret Lathe/UNK (List 6951)(Prob 1951)
Catalog/Sumitomo Electric Ind., Ltd./Throw Away Milling Cutters/1969
Catalog/SKF Industries/Engineering Data - Bearings/1980
Engineering Data Sheets/SKF Industries Inc./Bearings/1945
Engineering Data Sheets/SKF Industries Inc./Bearings/1971 TAKEN-Glen
Engineering Data/SKF Industries, Inc./Machine Tool Bearings and Spindle Design/1954
Product Service Guide/SKF Industries Inc./Bearings & Gears/1985
Catalog/SKF Industries Inc./Ball Bearings/1981
Catalog/SKF Industries Inc. - Tyson Bearing Co. (Subsidiary)/Tyson Tapered Roller Bearings/1969
Catalog/Skil Corp./Skil Industry & Construction Power Tools/1970 TAKEN - Glen
Brochures/Skinner Chuck Co./Vises & Geared Scroll Chucks/1960 TAKEN-Glen
Catalog/Skinner Chuck Co./Chucks/1953 TAKEN-Glen
Catalog/Skinner Chuck Co./Chucks/1973 TAKEN-Glen
Catalog/Skinner Chuck Co./Power Chucks/1960 TAKEN-Glen
Brochure/Skinner Electric Valve Div. - Skinner Chuck Co./Solenoid Valves/1954
Brochure/J. T. Slocum Co./Micrometer/1957
Brochures (2)/J. T. Slocum Co./Micrometer/1958
Catalog/Anton Smit & Co./ASCO Industrial Diamonds & Diamond Tools/1950
Catalog/Anton Smit & Co./ASCO Industrial Diamonds & Diamond Tools/UNK (Pre-1963)
Catalog/Anton Smit & Co./ASCO Industrial Diamonds & Diamond Tools/1951
Brochure/Anton Smit & Co./Industrial Diamonds & Diamond Tools/UNK
Brochure/Smith Bearing Co./Cam Following Rollers/1952
Product Brochure/Smith Engineering & Tool Co./Standard Jig & Fixture Body/1946
Brochure Folder/Elwin G. Smith & Co., Inc./Products for Roof & Wall Construction/1959
Brochure/F. E. Smith/Multi-Angle Grinding Fixture/1957
Brochure/Smith-Johnson Corp/Senacon Air Motors/1942 TAKEN-Steve
Brochure/Smith-Keser & Co./Piercing & Notching Toolset/1953
Brochure/S. B. Smith Machine & Tool Co./Smith 4 Ton Punch Press/UNK (Pre-1963)
Brochure/Smiths Industrial Instruments, Ltd./Hand Tachometers/UNK (Poss. 1935)
Catalog/Snap-Tite Inc./Quick Connect/Disconnect Couplers/1955
Catalog/Snow Manufacturing Co./Machines & Master Fixtures/1963
Catalog/Snow Manufacturing Co./Air Operated Drilling, Tapping & Threading Fixtures & Machines/UNK
Catalog/Snow Mfg. Co./Drill Press Tap Heads & Machines/UNK
Brochure/Somerset Tool Co./Model "SS" Radius Dresser/UNK
Catalog/Somma Tool Co./Tools for Screw Machines & Turret Lathes/1982
Brochure/Somma Tool Co. (Mfg. by Ballard Associates)/"Ballard Boy" Multi-purpose Tool/UNK
Catalog/Somma Tool Co./Standard Circular Form Tools & Blanks/1960
Brochure/Somma Tool Co./Reamrite Adjustable Reamers/1962
Catalog/Somma Tool Co./Standard Circular Form Tools & Blanks/1963
Catalog/Somma Tool Co./R & L (Right & Left) Tooling for Screw Machines & Turret Lathes/1961?
Brochure/Somma Tool Co./Standard Circular Form Tools/1950
Catalog No. 69/Somma Tool Co./Tools for Screw Machines & Turret Lathes/1969
Brochure/Sonnet Tool & Mfg. Co./Helical Carbide Slab & End Mills/1954
Price List/Sonnet Tool & Mfg. Co./10050 Port Contour Tool/1955
Brochure/Sonnet Tool & Mfg. Co./Helical Carbide Cutters/UNK
Brochure/Sonnet Tool & Mfg. Co./Cutting Tools for Hydraulic Port Contours/1958
Brochure/Sonnet Tool & Mfg. Co./Roller Bearings/1959
Insert/Sonnet Tool & Mfg. Co./Port Contour Cutter No. 10050/UNK
Catalog/Wm Sopko & Sons Co./Tool Room & Grinding Room Accessories/1957
Brochure/Sorensen Center-Mikes, Inc./Center-Mike/1953
Catalog/Sossner Steel Stamps, Inc./Stamps & Related Equipment/1979
Catalog/Sossner Steel Stamps, Inc/Roll-a-Matic Roll Marking Attachments/1979
Catalog/Sossner Tap & Tool Corp./Taps/1962
Mailer-Brochure/South Bend Lathe Works/7" Bench Shaper/1954 TAKEN - Joel
Mailer-Brochure/South Bend Lathe Works/Lathes & Collets/1956 TAKEN - Joel
Brochure Form 3547/South Bend Lathe Works/Vertical Milling Machine/UNK (Pre-1963) TAKEN - Joel
Catalog No. 5243/South Bend Lathe Works/Lathes, Drill Presses, Shaper/UNK (Pre-1963) TAKEN - Joel
Mailer/South Bend Lathe Works/Lathes & Equipment/1953 TAKEN - Joel
Catalog No. 551/Southwest Products Co./"Monoball" Self-Aligning Bearings & Rod End Bearings/1953
Catalog/Spartan Saw Works/Saws/1952
Brochure/Special Chemicals Corp./Manufacturing Chemicals/UNK
Manual No. 11/Speedgrip Chuck Co./Speedgrip Chuck/1950
Brochure/Chas W. Speidel & Co., Inc./Duplomat Printer/1953
Brochure/R. L. Spellman Co./Transfer Punches/1956 TAKEN - Glen
Brochure/Spencer Thermostat Co./Klixon Thermo-Stop Temp Controls/1947
Catalog/Spiral Step Tool Co./Special Cutting Tools/UNK (Pre-1963)
Brochure/Split Ballbearing Corp./Divisible Race Bearings/UNK
Brochure/Spraymaster Corp./SCA Chucks/1960
Catalog/Sprayon Products Inc./Spray Lubricants/1966
Catalog/Spray Systems Inc./Spraying Systems/1953
Catalog/Square D Co./Motor Starters/1960 TAKEN - Tom
Catalog/Stackpole Carbon Co./Stackpole CeraMagnet/1957-59
Brochure/Stackpole Carbon Co./Stackpole Coldite Resistors/UNK (Pre-1963)
Catalog/Stacor Corp./Drafting Furniture & Equipment/1970
Brochure/Stadoil Mfg. Co./Diamond Lapping Oil/UNK
Catalog/Standard Automotive Parts Co./Woodruff Key Specifications/1956
Catalog/Standard Electrical Tool Co./Precision Spindles w/ Machine Brochure Inserts/UNK (likely 1950-1955)
Brochure/Standard Electrical Tool Co./Machinery, Mostly Large Grinders & Buffers/1945 TAKEN-Steve (SCAN b4 sending)
Catalog/Standard Electrical Tool Co./Precision Spindles/1962
Brochure/Standard Electrical Tool Co./Vani-Tool Finisher/1953
Catalog/Standard Horse Nail Corp./Machine Keys, Pins, Special Parts/1970?
Brochure/Standard Locknut & Lockwasher, Inc./Locknuts & Lockwashers for Ball & Roller Bearings/1945
Catalog/Standard Machinery Co./Power Presses/1945 TAKEN-Steve
Catalog/Standard Parts Co. (Manufacturers of Noble & Stanton Parts)/Gages, Jigs, Fixtures, Build Up Parts/1963
New Product Brochure/Standard Parts Co./Lift-N-C Jig/1962?
Product Brochure/Standard Parts Co./Tumble Box Jig/UNK (Pre-1963)
Brochure/Standard Parts Co./Screwzon Swivel Toggle Shoe Clamps/UNK (Pre-1963)
Catalog/Standard Parts Co./"Everyday Standards, Clamp Assemblies, Basic Fixtures"/1962
Catalog/Standard Parts Co./Component Parts of Jigs & Fixtures/1953
Brochure/Standard Parts Co./Fixture Key, Tumble Box Jig/UNK (Pre-1963)
Catalog/Standard Parts Co./Ready-Made Fixtures/1964
Brochure/Standard Parts Co. (Manufacturers of Noble & Stanton Parts)/T-Slot Bolts/1956
Catalog/Standard Parts Co./Fixtures/UNK (Pre-1963)
Brochure/Standard Portable Cord Co./Magic Shield Eye Protector/UNK
Catalog/Standard Pressed Steel Co. (SPS)/Socket Screws, Spring Pins/1966
Brochure/Standard Pressed Steel Co. (SPS)/Socket Screws, Self-Locking Nuts, Collars, Spring Pins/1954
Instructional/Standard Pressed Steel Co. - Hallowell Shop Equipment Div./How to Select a Workbench/1953 TAKEN - Mark
Catalog/Standard Pressed Steel Co. - Hallowell Shop Equipment Div./Shop Equipment/1954 TAKEN-Glen
Brochure/Standard Steel Specialty Co./Woodruff Keys/1952
Brochure/Standard Steel Specialty Co./Fellows Rack Shapers & G & E Rack Millers/1953
Catalog/Standard Tube Co./Welded Tubing/1957
Brochure/Standard Transmission Equipment Co./Variable Speed Transmission/1950
Brochure/Standard Transmission Equipment Co./Variable Speed Transmission/UNK
Brochure/Standard Transmission Equipment Co./High Speed Hack Saw/1951
Product Brochure No. 606/Stanley Works/Stanley Router-Shaper/UNK (Pre-1963) TAKEN - Karl
Catalog/Staples Tool Co./Precision Carbide-Tipped Reamers/1950
Mailer/Stark Machine & Mfg. Co./"Proper Stopper"/UNK
Catalog/Starlite Industries/Pneumatic Tools & Tooling/1982-83
Brochure/Starr-Kimble (Div. of Miehle Printing Press & Mfg. Co.)/A-C & D-C Brake Motors/1953
Catalog/Steel Products Engineering Co./Brehm Trimming Dies/1949
Catalog/Steel Products Engineering Co./Brehm Trimming Dies/1951
Catalog/StenCLabl Inc. - Div. Elliott Business Machines, Inc./Marking & Addressing Labels/1963
Catalog/Sterling Electric Motors/Electric Motors/1954
Brochure/Sterling Factory Equipment Co./Bins, Shop Boxes, etc./1952 TAKEN-Steve
Brochure/Sterling Factory Equipment Co./Bins, Shop Boxes, etc./1955 TAKEN-Steve
Brochure/Sterling Factory Equipment Co./Bins, Shop Boxes, etc./1956 TAKEN-Steve
Catalog/John B. Stevens Co./Rotary Tables/1966
Brochure/Stilson Corp./Replaceable Grippers for Chuck Jaws & other Workholding Applications, 1969
Catalog/Stites Tool Co./Cams & Tools/1951
Brochures/Stokvis Multiton Corp./Heavy Machinery Trucks & Roller Skids/1963
Catalog/Wales Strippit Inc./Punching & Notching Machines/1961
Brochure/Stuhr Mfg. Co./Static Balancing Tools/1982-83
Brochure/Sturdi-Bilt Steel Products, Inc./Workbenches/1952 TAKEN-Steve
Brochure/Sturdi-Bilt Steel Products, Inc./Workbenches/1954 TAKEN-Steve
Info Sheets/Sturdy Broaching Service/Square Hole Boring Bar Sleeves/1953
Info Sheet/Sturdy Broaching Service/Square Hole Boring Bar Sleeves/1949
Product Brochure/Sundstrand Machine Tool Co./Model 33 Fluid-Screw Rigidmil/UNK TAKEN - Mike
"How To" Book/Sundstand Machine Tool Co./How to Increase Production on Short Range Turning with an Automatic Lathe/UNK (1940s or 50s) TAKEN - Mike
Engineering Drawing/Sundstrand Machine Tool Co./Adjustable Headstock Center, Model 8, 10 & 12 Lathe/1950 TAKEN - Mike
Brochure/Sunnen Products Co./Portable Hones/1960?
Brochure/Super Tool Co./Finishing & Reaming Blades/1955
Brochure/Super Tool Co./Carbide Drill/UNK (Pre-1963)
Brochure/Super Tool Co./Carbide Twist Drills/1954
Brochure/Super Tool Co./Reamers/1956
Brochure/Super Tool Co. (Div of Van Norman Industries)/Drills, Reamers, End Mills, etc./1958
Brochures/Super Tool Co./End Mills, Drills, Centers/1955
Brochure/Super Tool Co. (Div of Van Norman Industries)/Miniature Drills, Reamers and End Mills/1959
Brochure/Superior Indicator Co./Dial Indicators & Holders/UNK (Pre-1963)
Catalog/Superior Linkage Div., Tuthill Corp./Ball Joints, ADD Ends, Swivels, etc./1979
Brochure/Superior Mfg. Co./Face Plates & Boring Heads/1948
Data-Price Sheets/Superior Products Corp./Versa-Tapper II & General Products/1963
Tech Pub/Superior Steel Products Corp./4 Post, 3 Platen Hydraulic Presses/UNK (Post 1963)
Tech Pub/Superior Steel Products Corp./Ball Bearing Die Sets & Components/UNK (Post-1963)
Catalog/Superior Steel Products Corp./Die Sets & Components/UNK (Post-1963)
Catalog/Superior Steel Products Corp./Die Sets & Components/UNK (Pre-1963)
Product Brochure & Tracing Template/Suprecision Products/Pneumatic Double Acting Jig-Vise/1953
Brochure/Supreme Keyseat Cutters Co./Cutters, Drills, Countersinks, etc./1958
Brochure/Supreme Keyseat Cutters Co./Keyseat Cutters/1957
Brochure/Surface Checking Gage Co./Surfchek Gage/1952
Brochure/Surface Chemicals Inc./Isothane (Poly Foam for Thermal/Sound Insulation)/1955
Bulletin/Sutton Tool Co./Sutton Collets/UNK TAKEN-Pat
Catalog/Sutton Tool Co./Diamond Grip Collets & Feed Fingers/1943 TAKEN-Pat
Catalog/Sutton Tool Co./Levermatic & Handmatic Collet Chucks/1954 TAKEN-Pat
Catalog/Swartchild & Co./General Machine Shop Machines, Equipment, Tools, etc./1949 TAKEN-Glen
Catalog (2)/Swartz Standard Fixture Div. - Universal Vise & Tool Co./Fixtures/1963
Catalog No. 941/Swartz Tool Products Co./Fixtures, Engineering Drawings, etc./1941?
Catalog No. 700/Swiss Precision Instruments, Inc. (SPI)/Machine Tooling, Guages, Holders, Collets, etc./1970?
Sample Book/Synthane Corp./Technical Plastics/1956
Company names starting with T:
Data Sheet/T & S Engineering Co./Engine Lathe Multiple Carriage Stop/UNK
Catalog/Taft-Peirce Mfg. Co./Permanent Magnetic Chucks/1954
Catalog/Taft-Peirce Mfg. Co./Superpower Magnetic Chucks/1957
Brochure/Taft-Peirce Mfg. Co./Permanent Magnet Chucks/1953
Mailer/Taper Micrometer Corp./Taper Micrometer/1954
Catalog/Taper Micrometer - Div. T. M. Electronics/Taper Micrometer/1983
Catalog/Tapmatic Corp./Tapping Attachments/UNK
Brochures/Taylor Fiber Co./Silent Gear Material/1946
Catalog/Techalloy Co./Precision Rolled Strip and Flat Wire/1989
Catalog/Telco Machine Tools - Div. of Jarvis Corp./Drill Head Attachments, Multi Spindle Heads, etc./1970
Catalog/Telco Machine Tools - Div. of Jarvis Corp./Drilling & Tapping Attachments/1968
Catalog/Templeton, Kenly & Co./Simplex Mechanical Jacks/1960
Catalog/Tennessee Eastman Co. (Eastman Kodak)/Tenite Fittings for Pipe Extruded/1954
Bulletin/Thomas Hoist Co./Barker Wrenchless Chucks & Vises/1950
Bulletin/Thomas Hoist Co./Barker Wrenchless Chucks & Vises/UNK
Catalog/Thomson Industries, Inc./Ball Bushings for Linear Motors/UNK
Guide/Thomson Industries/Case Shaft Designer's Guide/1984
Catalog/Thomson Industries/Ball Bushings/1953
Catalog/Thomson Industries/Hardened & Ground Shafts, Rolls, Guide Rods/UNKCatalog/Thomson Industries/Nylon Lined Bearings/1952
Catalog/Henry G. Thompson & Son Co./Milford Metal Cutting Saw Blades/1957
Brochure/Threadwell Tap & Die Co./Taps/1952 TAKEN - Stuart
Foldout/Threadwell Tap & Die Co./Hex, Adjustable, & Round Split Dies/1951 TAKEN - Stuart
Catalog/Threadwell Tap & Die Co./Gages/1956 TAKEN - Stuart
Specifications/Thriftmaster Product Corp./Multiple Spindle Drill Heads & Dorman Tapping Attachments/1953
Catalog/Thriftmaster Products, Inc./Multiple Spindle Drill Heads/1966
Product Brochure/Thriftmaster Products, Inc. - Div. of Thomson Industries, Inc./U620B - U1012B Universal Drillheads/UNK
Brochure/Tietzmann Tool Corp./Indicator Height Gauge/1953
Catalog/Tietzmann Tool Corp./All kinds of Fixture Pieces and Gages/1955
Catalog/Tietzmann Tool Corp./Jigs, Gages, Blocks, etc./1953
Catalog/Tinnerman Products Inc./Speed Nuts/UNK (Pre-1963)
Brochure/Titan Tools/"Presto" Quick Change Collet/UNK
Brochures/Titan Tool Supply Co., Inc./Precision Layout Compass/1960
Brochures/Titan Tool Supply Co., Inc./Dial Height Gauge, Comparators, Needle Pins & Files, etc./1965
"T" COMPANIES CONTINUED BELOW
T
twertsy
Reedville, VA
CONTINUED - Companies Starting with T:
Catalog No. 23 & 23/Tocco Div. - Ohio Crankshaft Co./Induction Heating/UNK (Pre-1963)
Brochure/Todd Co. Inc./Karge Turnomat Turning & Tapering Attachment/1950
Mailer/Tokheim Oil Tank & Pump Co./Pump/UNK
Foldout/Toledo Pipe Threading Machine Co./Pipe Threading Tools/UNK
Catalog/Toledo Standard Commutator Co./Cummutators/1946 // Also Hullhorst Mica Undercutter No. 10 by Hullhorst Micro Tool Co. - Div. of Toledo Standard
Catalog/Tolhurst Centrifugals - Div. of American Machine & Metals, Inc./Centrifugal Chip Wringers/1955
Catalog/Tomco Products Co./Machine Hand Wheels, Knobs, Handles, etc./1950
Catalog/Tomco Inc./Hydraulic Work Holding Equipment/1968
Booklet/Tomkins-Johnson Co./T-J Interchangeable Head Reamers/1957
Catalog/Toolset - Div. of General Riveters, Inc./Toolset Piercing Units/1955
Catalog/Torit Mfg. Co./Dust Collectors/1955
Product Brochure/Torrington Co./Taper Pins/1958
Brochure/Torrington Co./Dowel Pins/1959
Catalog/Torrington Co./Bearings/1970
Brochure/Torrington Mfg. Co./Blower Wheels & Fan Blades/UNK
Instructions/Torrington Mfg. Co./Designing Air Impelling Units/1946
Catalog/J. J. Tourek Mfg. Co./Tourek Ball Joints/1956
Catalog/Townsend Co./Tapping Screws/1953
Catalog/H. P. Townsend Mfg. Co./Automatic Second Operations Machines/1951
Catalog/Trade Circle Products/Cobalt Cutting Tools/1969]Catalog/Transocean Trading Co./Precision Measuring Gages/1957
Catalog/Triangle Conduit & Cable Co./Building Wire/UNK
Catalog/Trico Fuse Mfg. Co./Chain Oilers & Oil Applicators/1957
Brochure/Trinity Tool Co./Dry Blasters/1971?
Catalog/Troyke Mfg. Co./Rotary Tables/1965 TAKEN-Glen
Catalog/Troyke Mfg. Co./Rotary Tables/1957 TAKEN - Glen
Catalog/Tru-Tex Div. - H & R Supply Co./Blade Perforators & Retainers/1962
Brochure/Tru-Tex International Corp./Punches & Dies/1969
Brochure/Trumpf Corp. - Widder Corp/Portable Edge Beveling Machine/1967
Product Brochure/Trumpf America Inc./Plate Shears/1970
Catalog Pages/Trumpf America Inc./Shears & Nibblers/1970
Catalog/Tru-Seal Div. - Flick-Reedy Corp./Pipe Thread Seals/1956
Catalogs/TRW/Geometric Threading Tools & Chasers - Geometric Threading Tool Guide/1984
Brochure/Turner Brass Works/Halide Gas Leak Detector/1954
Catalog/Turner Brothers Inc./Turner Chucks (Kirkland Patent 2069527/UNK
Brochures/Turnomat Co., Inc./Turnomat Lathe Attachments/1955
Catalog/Tweco Products Inc./Welding Electrode Holders, Grounding Devices, Cable Connectors, Lugs, Splicers & Cable Accessories/1966 TAKEN - Glen
Brochure/Twentieth Century Mfg. Co./Superream Stub Reamer/1951
Brochure/Twentieth Century Mfg. Co./Ejection, Guide, Gage or Stop Pins & Finger Stops/UNK
Brochures/Twentieth Century Mfg. Co./Superream Chucking, Ejection, Guide, & Gage Reamers, Superbore Counterbores/1950-54
Brochure/Twentieth Century Mfg. Co./Garberding Ejection, Guide, & Gage/1951
Brochure (2)/Twentieth Century Mfg. Co./Uneeda Light Precision Shop Light/1951
Brochure/Twentieth Century Mfg. Co./Uneeda Light Precision Shop Light/1953 TAKEN - Glen
Mailer/E. F. Twomey Co./Drafting Templates/1958
Brochure/E. F. Twomey Co./Drafting Templates/UNK
Companies Starting with U:
Catalog/Unimet Carbides - Div. of United-Greenfield Corp./Carbide Tooling/UNK (Pre-1963)
Catalog/Union Carbide/Welding Products/UNK (Post 1971)
Catalog/Union Mfg. Co. - Union Chuck Div./Union Chucks/1960 TAKEN-Glen
Catalog/Unipunch Products Inc./Punching Machines & Products/1968
Catalog/Uniroyal/PowerGrip HTD Systems/1981
Catalog/Uniroyal/Power Transmission Products/1983
Catalog/United-Carr Fastener Corp./Plug Buttons/1946
Catalog/United States Diamond Wheel Co./Diamond Wheels/1953
Catalog/United States Drill Head Co./Multiple Spindle Heads/1946 TAKEN - Mike
Brochure/United States Drill Head Co./Adjustable Multiple Spindle Drill Heads/UNK TAKEN - Mike
Product Brochure/United States Machine Co./#1 Air Hydraulic Milling Machine/UNK
Catalog/Universal Ball Co./Precision Balls/UNK (Pre-1963)
Catalog/Universal Metal Hose Co./Steel Hose/1970
Catalog/Universal Steel Equipment Corp./Parts Bins, Shelves, Displays, etc./1954 TAKEN-Glen
Catalog/U. S. Tool Grinding Inc./Tool Grinding Services/1973
Company names starting with V:
Catalog/Valenite Metals - Div. of Valeron Corp./Tooling Systems/1959
Catalog/Valenite Metals - Div. of Valeron Corp./Carbide Throwaway Inserts & Brazed Tools & Blanks/1965
Catalog/Valenite Metals - Div. of Valeron Corp./MicroDex Adjustable Boring Units/UNK
Catalog/Valenite Metals - Div. of Valeron Corp./Mill Tooling/1963
Catalog & Manual/Valenite Metals - Div. of Valeron Corp./Milling Manual/1968
Catalog/Valentine Metals Corp/Blanks & Tooling/1955
Catalog/Vascoloy-Ramet Corp./Toolholders/1954
Catalog/Vee Bee Mfg. Co./Boring Bars & Cutters/1959
Catalog/Vereinigte Drehbank-Fabriken (VDF)/Turret Lathes/UNK
Catalogs (5)/Vickers Inc./Vane Pumps & Hydromotive Controls/1944
Catalog/Viking Pump Co./Pumps/1957
Catalog/Viking Tool Co./Mills, Single Point Tools/1953
Brochure/Viking Tool Co./Throwaway Insert Boring Bars/UNK
Product Brochure/Vinco Corp/Wheel Dresser/1979
Product Description Sheet/Vita Needle Co./Needles/1970
Catalog/Vlier Engineering Inc./Clamps, Torque Thumb Screws, Fisture Keys, Plungers, etc./1956
Brochure/Volstro Mfg. Co./Volstro Rotary Cross Slide Milling Head/1970
Catalog/Vortec Corp./Enclosure Cooling Systems/1973
Catalog/VR/Wesson Co./Boring Bars/1963
Company names starting with W:
Product Brochure/E. H. Wachs Co./Trav-L-Cutter Model E Pipe Saw/1962
Product Brochure/Wade Tool Co./No 45 Precision Profiling Machine/UNK (Pre-1963)
Technical Manual//Waldes Kohinoor Co./TRUARC Retaining Rings/1970
Brochure/Waldes Kohinoor Inc./Grooving Tool/1952
Catalog/Waldes Kohinoor Co./TRUARC Retaining Rings/1982
Engineering Data & Specifications/Waldes Kohinoor Co./Waldes TRUARC Retaining Rings/1952
Catalog N/Wales - Strippit Corp./Wales Notching Units/1951
Catalog/Wales - Strippit Corp./Hole Punching Units/1956
Catalog/Wales - Strippit Corp./Notching Units/1956
Catalog/Wales-Strippit Corp./Hole Punching Units/1952
Brochures (2)/Walker-Turner Div. of Kearney & Trecker Corp./Air Feed Drill Presses/1954? 1-TAKEN - Tom
Catalog/Walker Turner Div. of Rockwell Mfg. Co./Light-Heavyweight Machine Tools/1957 TAKEN-Glen
Engineering & Design of Mechanical Springs Handbook/Wallace Barnes Company - Div. of Associated Spring Corp/Mechanical Springs/1946
Catalog/Walls Sales Corp./Abrasive Band Grinders/UNK (Early Pre-1963)
Catalog No. 43/Walls Sales Corp./Abrasive Grinders of all Types/1950
Brochure & Specification Chart/Walsh Press & Die Co. - Div. of American Gage & Machine Co./Presses/1953Foldout/Waltham Machine Works/Pinion & Gear Cutting Machines/
Brochure/Ward-Leonard Electric Co./Chromalizing/1957
Foldout/Ward Machinery Co./Metal Brakes, Punches, Dies, etc./UNK
Brochure/Ward-Riddle Co./Turret Lathe Drill Speeders/1957
Bulletin, Brochures, Specs/Ware Brothers/Renewable Fuses/UNK
Payment Plan/Warner & Swasey Co./Deferred Payment & Rental Plans/1959
Product Brochure/Watson Mfg. Co./Watson Roller Rest Turning Tool/UNK (Pre-1963)
Catalog/Waukesha Cutting Tools Inc./Spade Drills/1977
Catalog/Waukesha Tool Co./Quality Cutting Tools/UNK (1950s)
Catalog Waukesha Tool Co./Quality Cutting Tools/1954
Catalog/Wetherhead Co./Refrigeration Equipment/1949
Catalog/Wedin Corp./Precision Lead Screws & Nut Assemblies/1967
Catalog/Wedin Corp./Reversing Screws/1983
Catalog/Weldon Roberts Rubber Co./Brightboy Abrasives with Samples Attached/1952
Product Brochure/Weldon Tool Co./Countersinks & Deburring Tools/1957
Product Brochure/Weldon Tool Co./End Mill Sharpening Fixture/UNK (Copyright 1942)
Catalog /Wendt Sonis/Drills, Mills, Reamers, Tooling Holders, etc./1953
Catalog /Wendt Sonis/Drills, Mills, Reamers, Tooling Holders, etc./1963
Product Brochure (s)/Wesel Mfg. Co./Precision Milling Head/1967
Product Brochure/Wesel Mfg. Co./Precision Milling Head/1968
Bulletin/Wessen Corp/End Mills with Indexable, Throw-Away Inserts/1962
Brochure/R. C. West/Automatic Die Stop/UNK (Pre-1963
Catalog/Westcott Chuck Company/Chucks/UNK TAKEN-Glen
Catalog/West Point Mfg. Co./WESPO Clamp Assemblies & Fixtures/UNK (Pre-1963)
Brochure/Western Reserve Labs/Rust Prevention & Removal (Manganesed Phospholend No. 7)/UNK
Catalog No. 60/Wetmore Reamer Div.-Industrial Mills Inc./Cutting Tools/UNK (Prob 1960)
Data & Spec Sheet/Wetmore Tool & Engineering Co./AND10050 Port Tool/1954
Catalog No 48/S. B. Whistler & Sons, Inc./HD Adjustable Perforating Dies/1951
Catalog/S. B. Whistler & Sons, Inc./HD Adjustable Perforating Dies/1947
Catalogs (2)/S. B. Whistler & Sons, Inc./Magnetic Perforating Dies/1948
Catalog/S. B. Whistler & Sons, Inc./Adjustable Perforating Dies/1954
Catalog/S. S. White Dental Mfg. Co./Flexible Shafts/1945
Catalog/Whitehead Stamping Co./Stampings, Washers, Specialties/1954
Product Brochure/Whitfield Mfg. Co./MAC Revolving Center/1950
Service Bulletins/G. Whitfield Richards/Lube-Well S-43 Soluble Oil/1951
Catalog/Whitney Chain Co./Silent Chain Drives/1953-58
Catalog/Whitney Metal Tool Co./Whitney-Jensen Punches & Dies/1961 TAKEN-Glen
Mailer/Whitney Jensen/Angle Iron Shears/UNK TAKEN-Glen
Catalog/W. H. Whitney Mfg. Co./Lever Punches/1957 TAKEN - Tom
Catalog/Whiton Machine Co./Geared Scroll & Independent Hardened Plate Type Chucks/1960
Product Brochure/Wickman Mfg. Co./Precision Tapping Attachment/1952
Product Brochure/Wickman Mfg. Co./Tapping Attachments/UNK (Pre-1963)
Catalog No. Y81/Wiedeke Plant, Elliott Co. - Div. of Carrier Corp./1971
Catalog/Edwin L Wiegand Co./Electrical Heating Units & Equipment/1959
Brochure/Alwin Fr. Wilkens, Inc./Grinding Machine for Small Drills/1970
Catalog/Carl Wirth & Son, Inc./Kutmore Hollow Mills/1954
Catalog/Carl Wirth & Son, Inc./Kutmore Hollow Mills/1976
Catalog/T. S. Wood's Sons Co./Motion Control Variable Speed Drives, V-Pulleys/1960
Catalog/N. A. Woodworth Co./"Cone-Lok" Jig/1951
Catalog No. 20/Woodruff & Stokes Co./Small Cutting Tools of Extreme Precision/UNK
Catalog/Wysong & Miles Co./Squaring Shears/1967
Company names starting with X:
RESERVED
Company names starting with Y:
Product Brochure/Yale & Towne Mfg. Co./Load King Hand Hoist/1963 TAKEN - Ben
Company names starting with Z:
Catalog/Zephyr Manufacturing Co./Precision Tools/1943 TAKEN-Steve
Catalog/W. M. Ziegler Tool Co./Roller Drive Tool Holders/1948
Catalog/W. M. Ziegler Tool Co./Roller Drive Tool Holders/1965
T
twertsy
Reedville, VA
Re: Machinery & Equipment Catalogs
I loaded up all the "A" companies, added some B's and C's.
VocaTexas
I might be interested in some Lodge and Shipley information from 1900 to about 1970 if there is any.
T
twertsy
Reedville, VA
I updated Q and R companies today
T
twertsy
Reedville, VA
Ok Gents, I finished off S, T, and W with what I have out, and added a couple to A, P, and a few others. I have 1 box remaining to go which I hope to polish off next Saturday.
T
twertsy
Reedville, VA
Whatever happened to this project?
Tom
Apologies Tom, life has gotten in the way lately, plus it's 90+ degrees in my shop. When the weather breaks I'll finish up the final box, finish the inventory and begin packing up and shipping those catalogs requested.
Todd
Zarek
What a huge job Todd, I know what it's like to be busy. Any chance on moving forward with this Literature. Also, I'd be glad to help cover my my share of the costs. Pat
itsme_Bernie
Northern NJ
I have a bunch of catalogs I would like to buy.. I already see the Whiton Catalog in your list that I would like
"Catalog/Whiton Machine Co./Geared Scroll & Independent Hardened Plate Type Chucks/1960"
Is this still possible?
Drunkonunleaded
Detroit Rock City
Has anyone had success reaching out to OP? I have reached out via email twice in July and August. OP has been online since then but has not replied to my emails or in this thread.
Thanks. I shot him another email and a PM. Good call on the archive link. Unfortunately, this is for a Christmas gift and thus I am in need of a hard copy.
Have you looked here?
Drunkonunleaded
Detroit Rock City
No, but that's a good link. I appreciate you sharing it.
For what BRAND of tool are you looking for a hard copy of a catalog?
Gatco Rotary Bushing Co. A few of the periodicals in that internet archive link have some of their old ads. I'm going to try to have them blown up into something more suitable for framing. Long story short, I know someone with a sentimental attachment to that company. I was hoping to surprise them on Christmas with something that they were not expecting.
