I use sendcutsend and they can be a great value. But when cutting 0.25” or thicker there is a noticeable taper on the cut surface. So if I need to mount to the cut surface. I need to face it off square on a mill if I want perpendicular parts. This is probably an issue for thick gears.Linn Gear Co.
Linn Gear manufactures stock and custom sprockets, gears and other mechanical power transmission components for industrial applications.www.linngear.com
If the gear is not that precision then you could contact Send cut send to cut it for you. A friend uses them a lot and is amazed at what they can do. He has had gears cut for small instruments.
lg
no neat sig line
I don't think so !bore is likely 12.5 mm. Is this metric?
It is from a late 70s/early 80s Craftsman (made by DeWalt) drill, model No. 900.27121You could also give out the information of what this gear comes off of. That information may help in tracking down basic information of the gear.
Because the faces of the crack look like PM ! Could it be cast iron ?Why would you think this gear is made from PM? Gears of all sorts have been made for decades before PM was ever an option.
Because the faces of the crack look like PM ! Could it be cast iron?
You can find a gear blank from someone like Boston gear or Martin much cheaper than having a whole gear machined
Their gears are Hobbed or skived and are going to be stronger and longer wearing than gears made on a milling machine with an indexer/rotary table with and an involute cutter
They usually have an undersize hole so the machinist only has to bore the center out and broach the keyway
https://www.martinsprocket.com/docs//catalogs/power%20transmission/4_gear%20catalog/gear-catalog.pdf
I couldn’t imagine one of them not having the correct blank for a simple spur gear.
If you don’t have the measuring equipment you can enter what you think you have into a gear calculator program, have it output to dxf and print in 1:1 scale. Then you can put the original gear on top of the print to check.
Gear generator
Yes, easily. Even our old, well used WardJets can hold +/-.020"Can a water jet cut teeth this small ?
-A .040 spread on gear engagement? If we add in the draft from cutting a thick section it may/will be more. Sure it's possible but doesn't sound like good results.Yes, easily. Even our old, well used WardJets can hold +/-.020"
That is what it meshes into.Does this look like the correct part ? Maybe start searching e-bay etc or calling some tool dealers and see if someone has one old stock.
This! I had some gears made custom for an expensive machine tool that was already EOL. It was near 3K if i remember correctly.Buying a new drill will be less expensive than having the gear cut by custom order.
Depends on the jet, to be honest. Flow has a nice tilting stream feature that compensates for the taper and the cuts are very precise, even in thicker steel.Why would you think this gear is made from PM? Gears of all sorts have been made for decades before PM was ever an option.
As for using a water jet, the tolerances for a gear will be tighter than most water jets can achieve in the state most shops keep them in. Furthermore, the thickness of the gear would likely cause it to be tapered (draft) and that's not acceptable for a gear subject to high torque.
Firebrick43 had the best advice about checking Boston Gear or Martin. Most shops I've worked at used either and I'd be surprised if one of them didn't have an off the shelf solution. A straight cut spur gear may look like a simple job but cutting gears is not as simple as it looks.
-I've only been out of the shop for a few years and things are already changing faster than I can keep up with, the thread on 3D printing is also educating me. I'd like to thank you for updating me on what's possible. Retirement has me in one shop downstairs and I don't get to keep informed about machinery I can't afford.I would bet a competent waterjet operator with a taper-compensated head could hold .005" without breaking a sweat. I've welded 3"+ thick steel plates that have had features cut in them on the waterjet to within .005" and it wasn't proclaimed to be a big deal.
