Some more boating tools. Aluminum was a poor choise to make the gimble alignment tool from. I recut one from Stainless. Much beefier. Tool on the bottom of the first pic is of the u-joint bellows ring installer. Handle is stainless, driver is D2 tool steel (was laying in the scrap pile).
Next, the tool to remove the drive shaft retaining nut, which holds the driveshaft/bearing assembly in the outdrive.
Started off as a hunck of steel.
Half way through the machining process,
I don't have a pic here of the final tool, but I welded on a handle. I'll try to get a pic tonight..
lastly, the tool to crimp the shift link bellows crimp. A nut welded to an old pair of pliers, then cut. Bottow of pic is the tool to expand the exhaust bellows to get it on the bellhousing. Made from some scrap steel 1/2 tubing.
It's almost as fun to make tools as it is to use them.
R
